Z4 M Coupe mods, the ongoing tale...
In November 2006 I took delivery of the 2007 Z4 M Coupe now named "Scatha". She is named after the warrior maiden who taught the fabled Irish hero Cuchulain. Scatha was also a dragon of the Third Age in Tolkien mythology, which is in keeping with our habit of naming our BMWs after dragons: Tiamat (M5), Ancalagon (540iT), Scatha (Z4 MC). You can see the first pics of the Coupe in my first thread HERE
In the other thread I listed the first few mods, but I now realize that it would be more appropriate to start a new thread to serve as an ongoing chronicle of Scatha's trials and tribulations. Speaking of which, my buds at BMS and I have some serious plans for performance mods, some of which may become products suitable for other Z4 M owners. My goal with Scatha is to better the already stellar performance of a great sports car without sacrificing reliability or comfort. While it is close to perfect, there are some features the Z4 M Coupe did not come with that I would like. There are also performance increases that for cost reasons are not suitable for mass consumption. The Coupe mods will be kept in the vein of BMW's original design; a comfortable, semi-luxurious sports car equally at home on the track or commuting. As Scatha is modded I will update this thread (so bookmark/add subscription) with pics and descriptions of the mods. I am also continuously updating an Excel spreadsheet that tracks her weight, parts cost, hours invested, suppliers and part numbers. I will post that later on once there are a sufficient number of mods. On with the show... Mod 01 11-13-06 I swapped the dealer plate for one from a shop that understands customer support! Mod 02 11-15-06 I changed out the plain silver OEM valve stem caps to OEM "M" caps. Note: Thanks to Ron Stygar I was alerted that 2007 M Coupes MUST use the plastic caps instead of the brass-core ones. Part number for the plastic ones: 36 11 0 421 543 Mod 03 11-16-06 I added a calculator to the inside of the waterfall storage compartment door. I keep a fuel log, so having a calculator in the car is quite handy. Mod 04 11-18-06 BMS hardwired my Valentine 1. If you don't already have one, go to www.valentineone.com now! Mod 05 11-21-06, revised 1-19-07 iPod integration. My relatively frugal setup uses a Monster car charger with a 3mm/3mm cord mounted to a ProClip mount and holder. It outputs to the factory-installed 2007 Aux input. Pictured is the most updated setup, I plan to have the power hardwired and the wires shortened. Mod 06 12-22-06 I added a www.bmsracecars.com sticker to the Coupe's rear glass. They work on all my BMWs, so all of my BMWs have the sticker as a way to say thanks. Mod 07 1-19-07 BMS installed my Zeckhausen CDV today (http://www.zeckhausen.com/CDV.htm). I was surprised to feel that the difference is actually noticeable. The clutch travel is more linear and you can "feel" the clutch engage more precisely. I highly recommend this mod, which only costs about $40 shipped (+ labor, or DIY)! Sorry, I forgot to take a picture of this one, but you can see pics on Dave Z's website. Mod 08 1-22-07 I added a 4" micro antenna. I think it looks a little better than the stock piece and will cut down on wind resistance Mod 09 1-23-07 I installed (with a little help from BMS) the OEM nav tv retrofit kit. The instructions say it should take about 3 hours. This is accurate, IF you've done it before. I also took some extra time removing interior pieces from the trunk out of curiosity. There were some oddities during installation: The tv unit bracket already existed in my car, and the replacement carpet pad is not remotely close to fitting the Coupe. I suspect it was designed for the Roaster, as my stock piece still fits mine after installation. More irritatingly, there is no ideal place to tie down the antenna wires to the rear bumper. I tied them to the license plate light clips and I think that will be ok. Also, the two studs to which the antenna tips should mount didn't exist on my car! So I found two other studs used by another antenna (AM?) behind the bumper foam and mounted them there. The reception is as good as the same kit in our two E39s, so I guess it worked! I also got the TvFree cable so the system doesn't shut off over 3mph. Later will come a DVD player and remote IR eye. The trunk, stripped: Now with the bumper and battery removed: All the panels that I pulled out: It is necessary to remove the waterfall trim in order to pop out the DVD player to connect the new wires. This isn't actually difficult to do, but very tricky to figure out how it's held in when you are sans ETK: The new tv module, now located next to the Premium Package amp: It works! I know, the traffic report isn't very exiting. FYI: The picture quality is MUCH better when stationary or with a DVD playing through the systems Aux input. Mod 10 1-24-07 I noticed a few weeks ago that the roundels and M badges on the sides of my Coupe were not installed correctly by the factory. Their horizontal lines, on BOTH sides did not line up. Figuring that I had to remove them to fix the problem I might as well see what the car looks like without the M badges. To my surprise I think it looks much better - cleaner. I AM leaving the trunk M badge on, and I plan to add another badge back there later on... Residue from the logo. This rubs off fairly easily: A poor quality indoor shot of the Coupe without the badges. Look for better pictures in future posts: When I parked her at BMS to work on the NavTv project we decided that now was as good a time as any to see about replacing the huge OEM battery with a smaller race battery that would free up a lot of trunk space. This mod is not yet finished, but here is a pic of the cardboard template they are going to use to create a prototype billet aluminum battery tray: I will also be relocating the M Mobility Kit and BMW Tool Kit. Here is a pic of the air compressor and an old MkIII nav DVD player where I plan to install a Microvision DVD player: I will also have to fab up a trunk lining system to cover the new contours. I don't know how to do that, but I look forward to figuring it out. Btw, the new battery setup isn't by any means finished yet, but the battery weight difference is 34lbs! That's quite a weight savings, and it should free up about 2cu' of trunk space too And speaking of weight, we weighed it last week on the BMS's scales. This was pretty much bone stock, with all my "stuff" out of the car, and 7/8 of a tank of fuel. She weighed in at 3277lbs - pretty much right on for the expected curb weight (full fluids/fuel) of 3303lbs. Front weight was 1649lbs (50.3%), rear weight was 1628lbs (49.7%). These percentages flipped when I was in the car, and of course would change as fuel burns off. To-date I have added 17.33lbs (net) to the car, but that doesn't count the unfinished battery relocation mod. That would bring the car's curb weight down from 3303lbs to 3289lbs. We have some plans to cut that number down a bit more too Monday I'll be taking her to StopTech's headquarters to be used as a measurement/fitting mule. StopTech has not yet confirmed that they will in fact produce brakes for the Z4 M Coupe, but I think it's likely. Stay tuned for more... |
looks good bro.
Mods
Nice to see some interesting mods.
Subscribed....
Nice work, look forward to updates on the project.
I am getting a new Z4M coupe this spring. I like the aluminum trim and noted that your car has it. Have you noticed any downside to it, specifically, annoying glare? Does it get broiling hot to the touch when the car is parked in the sun? Would you order it again or try the "carbon leather" Thanks in advance for your answers, your car is terrific and your posts are inspiring me to make some mods on my car as soon as possible, epscially the CDV.
) and it left a small black mark that I need to fill. I didn't really care for the CF cloth thing. Aluminum suited my color scheme for the car best. Funny thing, but even when parked in direct sun, I have still to find the interior hot. Maybe it's the Ti Silver paint?Quote:
I'm sure Stoptech will make a BBK for 18" wheels, what I'm not sure of (yet) is if they are going to build a 4-wheel set with a rear rotor as small and lightweight as the Performance Friction setup TC Kline has on his Carbon Coupe. As for wheels, stay tuned... Quote:
-Hopefully we'll see each other's Coupes at an upcoming meet! |
My $.02
WTB: Minty Seat Belt Receptacles - Front |
Car info: http://www.cardomain.com/ride/2799368/ |
As for the iPod, I just really don't want to be without interesting music and such on long solo drives to/from track events. I get bored and bored drivers are not safe drivers. |
Love the garage! Congrats also on all the work you have done yourself.
I have to say though - keeping a calculator for fuel consumption tracking? I'm sure you're married, I'm just envisioning though picking up a date, and then at the end of the night making her wait while I calculate my MPG's, lol! |
I luv America's fascination with weight loss! & no where is the benefit more acute than in cars! Can't wait to see the modify battery area! |
Hey dude, I know where you're going with the mods and can't wait to see the progression.
Will the stock rims clear the ST BBK, or are you gonna swap them out for something else? BBS LM's, man! Why are plastic valve stem caps a must? Something to do with the tire pressure monitoring, I assume?
Valve stems are aluminum. Brass and aluminum will eventually weld together due to corrosion.
09 E92, IB, DCT. |
Yikes! No bueno.
Nice ride...I'll definitely stay tuned.
I notice you have the oval rearview mirror - do you have assist?
Nice job Earl...I'm finally putting some KM (up to 420 total) on mine so we'll compare notes when I get back to SoCal!
im about to go buy a v-1.
Nice job so far.
Quick word of advice for anyone that wants to install a racing battery. Like I did in my Z3. Z3Power Batter Replacement You will also need to get one of those smart battery chargers to maintain a charge in the battery. Especially if you leave your car parked for more than a week. I purchased the so simple Battery Tender Jr. ($40). Battery Tender Website Oh yeah - - Love that garage! Wish I had the room. It's already packed with by 330i and Z3 and all my tools and other stuff.
Ciao! - - Nathan 2000-2.8L Z3 StahlGrau Roadster (some mods) ~ 2001-335i (BONE STOCK!) BMWCCA Tejas Chapter & iZ3 Project Coordinator for the San Antonio area FEAR MY TWO SEATER!!!!!!! Hello, I'm a MOD-A-HOLIC, check out my site to see my addictions! www.Z3POWER.net Member Since May 17, 2002 |
Wow, very nice; you've been busy.
conorb |
Update: Not technically, since this event is in the past, but I should include it. It's the thread I made for the Coupe's first trip to the dyno:
http://www.m5board.com/vbulletin/sho...275#post967275 |
Update: On 1-31 I took the Coupe over to StopTech in Torrance for brake kit measurement. It didn't take too long, as the components are mostly interchangeable with the E46 M3. I haven't heard back from StopTech as to what kit(s) they will be offering, but I expect to within the next week or so. Here are some pics:
Outside: The Coupe jacked up: Here's a shot of the complex stock front dust shield: StopTech test rotor: Pics of measurement "stuff": |
We took the Coupe up to Big Bear last weekend. Traffic wasn't ideal but I got a few miles of fun driving in.
Passing Yorba Linda: Nearing the mountains: Starting up: A little higher: Getting close to the 7000' pass summit: Snow!: Frozen(ish) lake: Arrived: Gratuitous puppy pics: In case you are curious how the puppy travels in the Coupe, here is Profit in the trunk: |
Update: The new battery tray prototype is complete! I stress this is a prototype, the production version will be much cleaner, anodized, and etched with the BMS logo. I still have to make the new interior panels, and we have to fabricate some simple brackets to hold the M Mobility Kit, Owner's Manual and Tool Kit. That'll happen after the panels are done. In the mean time, here are some pics of the battery relocation and tray:
The cardboard template: Rough cut billet: Milling the primary pocket: Pocketing finished: Finished prototype tray, clamp and hardware: With the battery mounted: Using a hammer I flattened the stock ground cable, after I slightly enlarged the bolt hole: Ground cable mounted: Battery and tray in and connected: Another shot, showing how much room is freed up in the trunk! Also, you can see the A/V In cables for the upcoming DVD mod...but more on that later: As for weight savings, the battery swap alone cuts 35lbs. The new tray and all related hardware weighs 875 grams vs. the OEM tray's 1700 grams, or 1.82lbs less. Some more gratuitous pics... At Home Depot: At Koisan, my local sushi bar: Mod 1, version B The new BMS license plate frames arrived, so I swapped out the old one. They are aluminum/black, not gold. In this picture the lighting was yellow and that's why the lettering looks gold. |
#25
Earl - Have you already considered installing remote terminals for the battery to make it easy to hookup the trickle charger? Most Bimmers seem to have remote terminals under the hood since the batteries are often under the back seat or in the trunk. Since you're going to need regular access, I'd think that doing something similar would be a good idea. Of course, the MZ4 might already have a terminal block under the hood...I don't know...
Great mods! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Z4 M Coupe at NHIS | brave1heart | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 9 | 11-11-2006 09:52 AM |
| 335 news release today => 535 next year | klu123 | E60 (2004 - 2010) | 34 | 04-26-2006 03:35 PM |
| Z4 coupe wheel styles | Don L | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 6 | 03-28-2006 06:55 AM |
| Z4 Coupe design | Axcu | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 0 | 12-10-2005 02:17 PM |
| NEW BMW Z4 Coupe Video | OC-Z4 | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 9 | 10-07-2005 05:13 PM |
