New to BMW's - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 02-04-2007, 06:03 AM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
New to BMW's
New to the site and BMW's although I am an avid car enthusiast. Just picked up this 1986 325es with just over 75k miles as an anneversary gift to my wife for $3500 (a little over book, bit worth it IMHO). The only rust found throughout the car is on the corners of the differential case and the inside corners of the exhaust bends. The only mechanical problem seen so far is the fan clutch which I picked up yesterday and will be installed soon.
The bimmer was added to the collection (my friends call my driveway a "used car lot,lol) which contains a mint 1990 Firebird w/88k mi (in the process of being turbo'd), 1998 F150 (work truck), 2000 Excursion w/80k miles (for the four kids), and the 2002 Lincoln Navigator (the only one for sale).
I'm just curious if there are any inherent problems to look for in these cars (aside from the timing belt). I am very mechanically inclined, have lots of tools/equipment, and have no problem doing the work myself (jeeze the parts are expensive enough).
So enjoy the pics, hopefully I will be an asset to your site and look forward to corresponding with other enthusiasts.
ID:	97481Click image for larger version
ID:	97483Click image for larger version
ID:	97485Click image for larger version
Old 02-04-2007, 06:31 AM
Court M3 Court M3 is offline
Mein Auto: 88 M3
nice find!! I'd also do a general tune up to include all belts, fluids
Old 02-04-2007, 06:37 AM
Thanx, and done. Just didn't know if there are things to look for besides the obvious mechanical issues that ALL motors/chassis seem to have.
Old 02-04-2007, 09:12 AM
mrdell4150's Avatar
mrdell4150 mrdell4150 is offline
Mein Auto: 1986 BMW 325ES
wow. we basically have the same cars. Nice looking ride. Looks solid. Your engine is slightly cleaner than mine though. I like!
1986 BMW 325ES
Old 02-04-2007, 10:16 AM
Paul Christian Paul Christian is offline
Mein Auto: 87.325is
very clean 86 325es you gotten your hands on,and on the plue note you have (is) spoiler to boot........nice....you will injoy this car alot too........
Old 02-04-2007, 10:33 AM
Thanx, front air dam needs some TLC. Also the spioler is cracking, fixable or replace?
Old 02-04-2007, 01:27 PM
Nomade30 Nomade30 is offline
Nomad
Send a message via MSN to Nomade30
Mein Auto: 1987 325es
very worth it can anyone find a crack in the dash cause i can't!!! Nice job finding it. In general that is not over book that's actually a little below book cause it's in almost perfect condition
Old 02-04-2007, 08:08 PM
The highest book value I found with that mileage and condition is $2700USD. Where have you seen otherwise?
No, there are no cracks in the dash. The few things keeping it from perfect is :
1. Three "door dimples" on the pass side
2. Chips on the lower air dam
3. Antenna stays out about 6"
4. Cracks in the spoiler
5. Drivers seat spring is gone, so when you go to adjust the back - it drops to the rear seat
6. Oil service light blinks
7. Check Engine light blinks after starting
8. Fan clutch is gone (will be fixed in a couple of days)
9. Needs alignment
10. Driver's side door lock is missing plastic cover
As a perfectionist these are the thing I saw wrong with this 20yr old car.
How available is the rear spoiler? Does anybody know where I can get one?
Old 02-04-2007, 08:51 PM
Hamfisted Hamfisted is offline
Mein Auto: BMW
Easy stuff to fix...
That's a beautiful car for it's age and looks to be pretty well cared for or at least garaged most of it's life. The antenna mast has the typical nylon tracked cord inside it that breaks or the teeth strip at a certain point and stop it's movement. You can buy just the replacement mast and it'll come with the new track cord attached. The antenna comes apart to replace it. Pretty easy fix. This is a very common failure with these cars.
In the trunk, make sure the battery is properly vented (vent tube attached and routed to exit the bottom wheel-well area under the battery. Otherwise you'll get a rusted out trunk if the battery vents inside it.
Look at getting one of the Peake diagnostic tools (R5/FCXII) (You'll need the early style adapter...) for reading Check Engine codes. Is it the Check Engine light? Or just the "Check" light flashing after startup? (it wants you to tap on the brake pedal so it can check the brake light system...).
Looks like the wiper arms are adjusted up pretty high, unless you had them on and just turned the key off when they were in that spot?
I used the Weather Tech heavy rubber floormats, they're bulletproof.
There's a sunroof cavity drain hole over on the front righthand side of the sunroof cavity you might run a length of wire down it to make sure it's clear, otherwise you'll get water inside the car.
Anyway you'll have fun tinkering with the car and getting everything perfect. Good luck.
-Mike
Old 02-05-2007, 05:20 AM
Thanx for the heads up, Mike. Yes these are easy things to fix, as my challenge right now is finishing up the turbo system in my Firebird. As far as the battery, I guess I'll be going with an Optima sealed cell battery to eliminate that problem totally. The wipers could go a little lower but they are about 1" from the bottom of the glass at the lowest point (could have been raining prior to taking the pics).
The things like the tip on the sunroof is the kind of information I was hoping to get here.
That Peake your talking about, is it BMW specific?
And yes I sure do like to tinker, have tons of tools in the garage including big equipment like a drill press and welder etc.
You're in Ft.Lauderdale, practically my neighbor here in Coral Springs .
Old 02-05-2007, 08:50 AM
Nomad
bavauto.com and search for part number 51 71 1 945 710
Old 02-05-2007, 01:06 PM
Thanx Nomad
I changet the fan clutch today, wasn't too bad. Took about 20min, a 1 1/4 open end wrench, and a 10mm socket.
Old 02-05-2007, 02:17 PM
BmrrCpl's Avatar
BmrrCpl BmrrCpl is offline
HighSpeedSpecialist
Mein Auto: 89' 325IC
hey, nice car and welcome to the FEST! I was just wondering, my friend just bought a 91 318is and im having as hell of time taking off the fan to change the waterpump. i have done this before to my 325ic but this lil car is becoming the pain in my neck. well anyhow, i see you used a 1 1/4'' open end wrench. what else did you use to get that darn fan nut off the waterpump pulley? or was is pretty easy like my 325ic? i know they spin clockwise... thanx
69 Chevy Chevelle Malibu 383 stroker - 92 Acura Integra RS - turbo in the works - 89 325ic auto 160K miles
Old 02-08-2007, 05:58 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Sawzall
Old 02-09-2007, 10:35 AM
BmrrCpl's Avatar
HighSpeedSpecialist
lmao. you know what? if i cant get to it, i just might. then all id have to do is drill through the threaded part of the WP thats still in the fan nut and get that darn thing out and i'll be done. very extreme case scenario but maybe, just maybe...!
Old 08-07-2009, 02:26 PM
Well, I know it's been a while since i posted here, but in the last 2.5 years or so, the car has been through hell and is on it's way back
Still no mechanical problems, but that pesky antenna mentioned earlier was snapped off by a neighborhood kid, the radio stopped working after a battery change and couldn't get the code to work, so I dropped a Blaupunkt CD player in (reception isn't that bad with no antenna surprisingly lol).
But that wasn't the worst of it...
Still only has less than 90k miles, but I'll let the pics tell the story.
First the wife came home crying and told me she didnt have the guts to look, but the tire was rubbing the fender, went outside to find this...
She was driving a Navigator for several years and had no problem, but the job she was working had a parking garage and she parked next to a pole. Perhaps she wasn't used to the tight turning radius?
Then this...
Another story where she called me all upset. A cat had run in the road and it tore the air dam off She came home with that in the back seat.
Then I started driving it daily as my truck had blown a head gasket and she has been driving the Excursion since. One morning I woke up to this (I leave earlier than she does for work, so I parked it in the road)...
Old 08-07-2009, 02:34 PM
SO!
As I said, it's on it's way back from hell...
Got a new fender (evilbay aftermarket)...
Traded some head porting on a GM big block for this...
Then had the same guy that did the bodywork, block the car down and get most of the imperfections out (missed a few lol). Then he painted it Bimmer Delphin, and even shot the bumper fillers, mirrors and shaved off the pin stripes, 325es badge and took the sunroof deflector off...
Old 08-07-2009, 02:41 PM
Then I scored an '885 top end, sandblasted the manifold and put numerous coats of "Super High Gloss Black" on it...
Went to the junk yard this week to grab some stuff for another project and nabbed a valve cover to get the same treatment.
Next on the agenda is to get some new shoes for it, locate and install some better bumper fillers (keeping the diving boards and they will get polished), drop it 60/60 and do a GM ECM swap so that I can datalog and tune easily. I have the equipment and knowledge to burn PROM's for the Motronic '027 ECM that's in it now, but don't like the idea of tuning without being able to datalog. The air dam is repaired, just needs to be filled, sanded and painted - and am interested in this Taurus side skirt modification others' are doing and they will go in the paint booth along with the air dam.
Sorry I haven't been around much, but the Firebird motor got blown, rebuilt, blown and is now under the knife again getting twin t04e's this time , but since I have been driving the Bimmer, why not fix 'er up a little?
Old 09-27-2009, 03:49 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
what year taurus are those skirts off of?
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 09-27-2009, 04:05 PM
98 I think. They were too long and had to shorten them a bit, paid $11.80 each for them and bought the 3M bumper repair (I used 8223 for the quicker drying, but you can also use 8115).
Old 09-27-2009, 08:37 PM
East Bound And Down
they dont quite look like the side skirts that were on my taurus and mine was a 97 lol but then again it was a SHO
Old 07-03-2010, 04:56 PM
Been a while since this was updated lol.
Well got the body work on the side skirts done, ready for final sand and paint, then just last week I pulled too close to a curb after lowering the car and broke the valence again
Repaired it (again), got it installed today and the rear valence mocked-up.
Coil over conversion...
and walk around pics today...
Still have the spare head I will be putting on soon as I take time to mail out all these cam cores for re-grinds
Old 07-03-2010, 09:38 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
needs wheel spacers...
89 325i~~04 s60r~~88 635csi~~91 325ix-SOLD~~02 WRX-SOLD~~04 WRX-SOLD~~01 2.5RS W/h6-SOLD
Old 07-04-2010, 12:22 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
looking good so far. needs rear bumper tuck, and maybe the front too (undecided)
E30 above Sold
Last updated 2nd January 2014
Old 07-04-2010, 03:41 AM
East Bound And Down
with all the time u spent you could have just facelifted it.. thats what i would have done... wait.... thats what i did
Similar Threads
Wall Street Journal Article on BMW's Past, Present and Future Salvator General BMW Questions 65 12-25-2010 08:22 PM
BMW's Embarassment Malibubimmer General BMW Questions 27 11-20-2005 09:35 PM
More Goodies from BMW's Telematics mojosaan General BMW Questions 1 10-14-2005 01:52 PM
new bmw's sucks? fricas 5 Series 16 12-16-2004 11:55 AM
of all european cars, why do BMW's seem to attract the cheesiest modders? bmw325 Off-Topic 23 01-03-2003 10:15 PM
