E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
550 Noise While Steering
Hi everyone,
I have an '06 550, and while driving, I realized that when I make a suddent right turn at low speed (trying to turn into parking space etc.) I hear a high pitch squeak sound. Did a brief search, and didn't see this being discussed. Does anyone else have the same problem? Think I also had this problem with my '00 323i (but it was left turn on the 323) |
04 545i sport/smg silver grey/grav 60 accident and sold 03 325 ci convert titanium silver *01 325 ci black - retired *00 323 ci titanium silver retired |
12 X5 50i Sport 11 M3 DCT 11 X5 50i (lemon) -- SOLD -- 08 550i M-Sport 04 BMW 545I sport 07 BMW X5 4.8I sport 02 BMW X5 4.4i sport 01 BMW 540I M/sport 00 SL500 97 SL500 |
Mine's a 2007 550i Sport with 8K miles.
2007 550i, Sport Premium, Silver Gray Metallic, Gray Dakota, Navigation, Cold Weather Package, Comfort Access, Heated Rear Seats, HD Radio, Xenon 2007 X3, 3.0si ///M Sport Premium, Monaco Blue, Gray Dakota, Navigation, Cold Weather Package, Xenon 2002 X5, 3.0i Sport Premium, Titanium Silver, Gray Dakota, Cold Weather Package, Xenon, just a winter vehicle |
i cant really reproduce it, it just kind of happens... seems like it happens more often when the car hasn't been driven in a while though, or maybe i'm just carzy? any idea what it might be anyone?
I did a search and only found this thread. Appreciate it if anyone can help.
It has happened a few times, not on demand, that when I left turn into a parking space, before applying the brake, there is a screeching noise like scratching on rubber? What is the problem?
MY08 550i 6MT , SP, CWP, Nav, HUD, Sound, Shade, RFDS, Heated RSeat
My electronic tilt on my 6 series goes thump, thump, thump when it moves up or down.
Works just annoying.
2012 535i |
squeaking sound
![]() By the way, Welcome to the Fest!
Could the problem be that during a low speed turn with your foot on the brake and the a/c on and the pwr steering pump working hard (hence turning into a spot) that the engine is dragging down to such a low rpm due to all the conditional loads (a/c, turning sharply, foot on the brake etc.) that the engine almost attempts to stall and the result is that the pwr steering pump squeals slightly and causes a sensation in the steering wheel itself due to momentary loss of hydro pressure. The computer/ecu/dme (whatever you want to call it) corrects the low idle in time to not let the engine stall but the result is the squeal/thump in steering wheel?
Just a thought TJ |
I'll join the fray. My 07 550i makes the noise too. And it doesn't matter whether I turn left or right. I would agree mine is more of a grinding sound or as if someone poured sand into the steering column. I was reading around here somewhere last night about this and somebody suggested the best case scenario is that the rack needs lube. Worst case is a new rack...
The same thing happened to my 07 550i, too.
2007 550i - Alpine White Exterior - Black Leather Interior Sport Pkg/Cold Weather Pkg/Comfort Access System/Power Rear Sunshade w/ Rear Manual Slide Window Shades/20-way Power Multi-Contour Front Seats/Navigation System/Sirius Satellite Radio/Park Distance Control |
Same issue here on a 2008 550i M Sport 20k miles
I just started to notice the same thing on my '07 550....only has happened a few times like when I'm turning to pull into a parking space. I can't tell if it's the brakes or something else.
2007 550i - Alpine White/Black 2006 Denali XL - Silver Birch Metallic/Stone Gray 2005 Ram 1500 - Bright Silver/Slate Gray |
I picked up my 08 550i on Monday. I have had the same thing happen a couple times when turning right at very low speeds. I haven't been able to reproduce so I will just keep listening for it and if it continues maybe contact my CA.
Wow. Looks like you may be able to "reproduce" it with a car so new. I am really curious what's the cause.
Anyone with A/S have the noise?
2012 535i |
No active steering.
I also have had that happen at times when making low speed turns. It does not happen consistently so I will just keep listening for it to see if it becomes an issue.
John 2011 335 xdrive coupe; space gray/coral red; auto; premium, sport, cold weather and convenience packages; NAV; Harmon Kardon; etc. 2008 550 carbon black/natural brown; M sport package; sport auto; NAV; HUD; logic7; premium and cold weather; ipod/usb; comf access; etc. |
LMAO i thought I was hearing things. BMW has a problem here. I get it mainly when turning sharp left into a parking spot. I do have A/S.
2008 BMW 550i Space Grey, Bamboo Trim, Active Steering, Comfort Access, Navi, HUD, Logic 7, HD Radio, ZCW, ZSP, Anthracite Headliner, Power Shade! Huper Optik 45% Ceramic Tint, 3M Proform Clearshield and V1 Hardwired. Camera Gear: Nikon D300, 24-70mm, 18-200VR and SB 800 |
Mine is turning sharp right. No active steering. Occurs only when outside temp is 65F or lower. If anyone gets BMW to diagnose, please post.
Regards, BIFF 06 550i-6spd. Sold 20091113 12 X5D Bought 20120331 |
Noise while turning at low speed
Yes - I have this problem too....'07 550i, it makes a low-pitched whine when turning sharply at low speeds, like when turning into a parking space. Doesn't do it always, just occasionally. I have asked the Dealer about it but it did not duplicate for them and I haven't remembered to fill out the form they gave me to help them diagnose next time. If anyone finds the cause I would be interested to know what to tell them. Thanks
#25
I have a 08 550i and have the same problem turning right into a parking slot at a slow speed. I took it to the dealer, tried several times to show them the problem, finally got a small low pitch squeel, they said they would check the steering fluid, said it was all fine and that was it. I still have the problem.
I noticed the same issue on my brother 04 545i. How do we fix this?
2012 Carbon Black BMW 550i M-Sport 2009 Black MB GL550 (Wife's Vehicle) 2012 Black Toyota Highlander Limited |
