Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 06-29-2007, 12:27 AM
starcappy starcappy is offline
Mein Auto: 1998 740il
Question 98 740iL - All power lost to trunk
Recently I had my car boosted because of dead battery. Last thing I did before I realized battery was dead, was unlocked the trunk. Now the inside button, key button, and power assist on trunk are not working. Message on console says "Trunklid Open". What should I be checking?
Scott
Old 06-29-2007, 09:24 AM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Have you checked the fuses and the battery? A weak battery can cause strange things to happen in these cars.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 06-29-2007, 03:03 PM
Adi's Avatar
Adi Adi is offline
Mein Auto: E38 750iL, A6 (4f) Avant
Get battery checked and probably replace. Lots of people have had lots of different weird issues when the battery is on the way out.
Audi A6 Quattro Avant (2007) - Oyster Gray Met.
E38 750iL (1995) - Cosmos Schwarz
Sign by Danasoft - Get Your Free Sign
Old 07-06-2007, 02:23 PM
Jmassa89 Jmassa89 is offline
740i
Send a message via AIM to Jmassa89
Mein Auto: 2000 BMW 740i
I have that exact same problem.. everytime i turn on my car it beeps and says trunklid open.. I haveto manually open it and its horrible.. I got mine checked and they sed I need a whole new pice that makes the trunk click closed..
Old 07-11-2007, 08:17 PM
ctweber98 ctweber98 is offline
Mein Auto: 5.28i, 7.45iL
Make sure that the lock is not turned to the valet position. If you take your key and manually unlock your car like you had to when your battery was dead, you probably have it in valet parking mode and therefore the only way you can open it is with the key and not by any other means (buttons, keys, etc). Check your owners manual for more details about this as I had the same problem and took mine into the dealership and showed me how to do it in a second.
ctweber98
Old 11-08-2008, 12:29 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
So was there ever an official solution for this? Of all my searches on Google and all the messagesboards, this is the closest I have come to similar symptoms.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 11-09-2008, 09:10 AM
danosll danosll is offline
Mein Auto: 2000 323ci, 2002 530i m
I had similar problem wires were broken in harness between body and trunk lid bad design.
Old 11-09-2008, 09:18 AM
m5james's Avatar
I've had mine stop working for like a day once, it was embarrasing having to try and reach up inside the car every morning when going to work to get what I needed and have to rebungee it down. After a few good slams and some yanking up and down, suddenly it came back to life.
INTERIOR:
Old 11-17-2008, 05:32 PM
krockstk krockstk is offline
Mein Auto: 2001 740il
try opening the trunk. disconnect battery. take screwdriver and close trunk latch. reconnect battery. use mechanical key in lock to open latch. my 740 had the same problem when I bought it. took a while to figure out, it was just confused. I have to do this every time the battery goes dead. (it sits alot) good luck, Tim
1946 Dodge Business Coupe
1948 Chevrolet P/U 350/350
1982 Rampage roadster
1985 Omni GLH(Goes like hell)
1993 Lincoln MK8
1995 Lincoln MK8
2001 Krautmobile
2001 Dodge 2500 4x4
Sleds, Bikes, Go-karts
I'm a Fossil fuel bulimic.
Old 11-17-2008, 06:52 PM
m5james's Avatar
I found the steps after searching around some more using Google....basically did what you just suggested. Thanks.
INTERIOR:
Old 01-11-2009, 04:16 AM
tromp tromp is offline
Mein Auto: 2001-740il
My trunk motor stopped working so I can't close/lock the truck as of yesterday. I'm thinking I have the same problem as you. What were the exact steps that you did to "reboot" it?
Old 01-11-2009, 11:30 AM
m5james's Avatar
To be honest, I don't remember exactly where I found it, and I'm replying via my phone. I'd start by looking on e38.org, then if no luck there, then try using Google.
When I did it I remember a few sites I found. One had me disassemble the lock and check to make sure the spring mechanism was intact, the other had me doing something like turning the trunk key while connecting the battery or something. Sorry I can't give you more at the moment.
INTERIOR:
Old 01-16-2009, 02:47 AM
Did the spring thing and it worked! Now I'm moving onto overhauling the breaks. Wish me luck.
Old 01-16-2009, 08:48 AM
m5james's Avatar
Cool. Brakes are pretty easy, just depends on what you're doing sometimes though. If you don't have a buddy to help you bleed, you can build your own pressure bleeded for like $10.
INTERIOR:
Old 01-17-2009, 03:49 AM
Thanks. I'm going to change pads and rotors so i'll need to bleed. Tell me more about the build your own pressure bleed? I'm also shopping for the parts. I was dust free pads I know for sure.
Old 01-17-2009, 08:17 AM
m5james's Avatar
E38.org has a few write-ups. I went around to a few local stores (Wal-Mart, Ace Hardware, etc) to find a bleeder that could hold around a quart or so. Take your old brake master cylinder cover w/ you, then goto Wal-Mart or an automotive specific store and get a cap of the same size to drill and install a nipple to connect the bleeder to the cap. I might be getting confusing now, but these are pretty easy things to make. Either read up on E38.org or maybe even try using Google on how to make your own bleeder.
INTERIOR:
Old 01-21-2010, 07:10 PM
Ken Burkett Ken Burkett is offline
Woohoo!!
Mein Auto: 2000 740iL
It Worked!
Thanks M5james!!
Disconnecting the battery and closing the lock with the screwdriver worked! appreciate the time you have taken to answer these posts. I was lost and ready to take it into the shop.
Thanks again!!
Old 01-21-2010, 07:42 PM
m5james's Avatar
Glad I was able to help. Thank you for searching around for the answer and finding this thread instead of posting a new thread I'm all for thread revivals and keeping the information to fewer posts instead of spread all over the place.
I'm born and raised in Edmonds, so I've been able to go on a lot of Seattle5's and 7's drives. Marysville isn't too far, so you should get in touch w/ the www.seattle7s.com guys and go on the drives...good bunch of people and fun meets, usually starting in Issaquah. Anyways, have a good weekend.
INTERIOR:
