Ignition Problem with codes - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-01-2007, 07:47 AM
Mark_Liverpool Mark_Liverpool is offline
Mein Auto: BMW 320i Coupe
Hi, I've been looking all overt the net for information and I'm getting no where quick!
Basically I've got a 1993 RHD E36 320i Coupe running MS40 (Siemens) management it seems.
I drove the car to my friends, turned it off had no problems with running, no juddering, jumping, stalling anything, ran fine. Got into the car 5 minutes later and it just cranked over and would not start.
So the car cranks but will not start, I used a snap-on scanner and the following codes came up:
01 Ignition Cylinder 1
02 Ignition Cylinder 3
03 Ignition Cylinder 5
29 Ignition Cylinder 2
30 Ignition Cylinder 4
31 Ignition Cylinder 6
62 Feedback Ignition Signal
204 Feedback Ignition Signal
If anyone can shed any light on what the best route to take is I'd be extremely grateful.
Mark
Old 09-01-2007, 07:51 AM
VTi's Avatar
VTi VTi is offline
Dale Crane is the MAN!
Send a message via AIM to VTi
Mein Auto: 95 320i / 00 520i
Sounds like an distributer problem.
Old 09-01-2007, 08:00 AM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Call it a hunch, but I bet your problem has something to do with ignition..
Old 09-01-2007, 08:03 AM
VTi's Avatar
VTi VTi is offline
lol
spark plugs are fine (unless all 6 cylinders are faulty...not likely)
ignition signals come from the distributer to time the ignition sequence.
i would start there, try replacing the distributer.
Old 09-01-2007, 08:28 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Helpful as always!!!
Hey buddy
I would get your camshaft position sensor checked as it maybe on it's way out
2001 Mini Cooper R50
Edirty6 for life
Old 09-01-2007, 08:34 AM
PhilipWOT's Avatar
Turn Burglar
I'll always do my best to help someone out if I know how, and I don't know how to help them rest assused that I will make up some preposterous bullsh!t.
Old 09-01-2007, 08:26 AM
enriquecere enriquecere is offline
Mein Auto: E36 318
Before, change any part, verify the spark plugs, the ignition wires and the ignition coil. Then the distribuitor.
Old 09-01-2007, 08:35 AM
Still here
Mein Auto: M3
Well kindly stop it
Edirty6 for life
Old 09-01-2007, 09:14 AM
PhilipWOT's Avatar
Turn Burglar
Well kindly stop it
Then how would i entertain myself at work?
Old 09-01-2007, 09:16 AM
Still here
Mein Auto: M3
lol, no comment
Edirty6 for life
Old 09-01-2007, 10:00 AM
Nice one guys, will use the Vantage tomorrow and check the signal from the cam sensor. The water pump did go at the "same" time but I thought that it couldn't be related but upon further investigation the crank sensor is directly below the water pump so could be cracked and water has got in it maybe? Can't see head gasket going on all six cylinders, plus it doesn't splutter when it turns over, it is just like the immobiliser is on, and before you ask, its not, lol.
Old 09-01-2007, 02:06 PM
bobbobb bobbobb is offline
Mein Auto: 318tdse
always when something like this happens try another key first. the keys i have found out and talking to the stealers a lot about this is that the keys can loose the codes very easy so the imoby goes on.
thats where i would start
