Old 10-25-2007, 03:13 PM
NITO NITO is offline
BeamersRWayToEx$pe$ive
Mein Auto: 1999 BMW Z3 COUPE 2.8L
Z3 passenger seat moves.
My passenger side seat slides back and forth slightly. All electronic controls work and its as if the seat is loose on the track. It will shift forward or back freely for about a half an inch. Not so bad if someone is sitting in it, but when I'm driving alone, I hear it move if I accelerate quickly or brake hard. I can grab the seat with my hand and just slightly move it back and forth without using the switches. Does not sound like the motors in the seat are being affected by the movement. Any ideas?
Old 10-25-2007, 03:23 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
Yes,
PM with your email address, I'll send you a detailed power point slide show on how I fixed it.
Old 10-26-2007, 06:53 AM
Pinball81 Pinball81 is offline
Mein Auto: 05 M3 ZCP, 98 M Rdstr
Originally Posted by EOD Guy View Post
Yes,
PM sent...
2005 M3 ZCP: Alpine White
1998 M Roadster : Imola Red
2003 540i/6 M-Sport : Titanium Silver SOLD!!!
Old 10-26-2007, 11:53 AM
You guys are the bestest!
Nice to know someone else shares my pain! Well, step one is to first go to dealer: I'm pretty sure my warranty will cover this. If not, I have the best resources to do it myself.
Thanx a million!
Old 10-26-2007, 12:19 PM
Vinci Vinci is offline
DO IT YOURSELF.
Mein Auto: 98 M Roadster
If the dealer does it under warranty, they will just put more crummy rubber bushings in and you'll be in the same boat in another 15-20k miles. Even if you have to do it yourself, I think it's better to do it once and be done with it.
Old 10-26-2007, 04:22 PM
The Other Tom The Other Tom is online now
Mein Auto: 2008 335i
+1
Also, the more you do, the more confident you are to do other things.
2008 335i
2001 325i retired
2000 M Roadster Imola Red retired
1998 Z3 2.8L retired
Old 08-29-2011, 08:00 PM
Hey Now Hey Now is offline
Mein Auto: 1996 Z3 1.9
Can you please sent me the PPT presentation as well. Thanks
va902b@hotmail.com
Old 08-29-2011, 08:06 PM
Steamer's Avatar
Steamer Steamer is offline
Mein Auto: 2011 550i, 00 M Roadster
Sent
Old 05-09-2012, 11:08 AM
Jwolski Jwolski is offline
Mein Auto: 1998 z3
My names is John Wolski, and I have a 1998 z3.
Could I get a copy of the PPT on seat bushing replacement...
jwolski@ec.rr.com
thanks a million!
Old 05-09-2012, 12:33 PM
crappyattitude1 crappyattitude1 is offline
YYZED3M Driver
Mein Auto: '99 ////M Roadster
Might as well.....
Throw me in there as well. Will you please send me the powerpoint as well????
Crappy : )
(Just outside of Nashville)
Old 05-13-2012, 01:33 PM
nfunk nfunk is offline
1998 BMW Z3 2.8L
Mein Auto: 1998 BMW Z3 2.8L
Just replaced my seat bushings. It took around 2.5 hours to do both. It was fairly easy, especially in a roadster. Just watch the youtube videos and you won't have any problems.
Old 09-29-2011, 04:18 PM
TomC80113 TomC80113 is offline
Mein Auto: 1999 Z-3 Roadster
Yes,
Could you send the ppt to tom-conroy@strategicre.com?
Old 03-10-2012, 05:42 AM
sdegrenier sdegrenier is offline
Sliding Seats
Yes,
Thank you! sadegrenier@aol.com
Old 06-14-2012, 07:44 AM
javiercardenas javiercardenas is offline
Mein Auto: 1998 Z3
z3 seat bushings
hello. i would like to know if you still have the slide show available. thanks for your time
Yes,
Old 10-25-2007, 06:25 PM
Your seat bushings are worn out. This is a common problem with Z3's. You need to get Doug Whalen's seat bushings and replace your old ones. It's a straighforward fix and EOD Guy's presentation will most likely show you how.
2008 335i
2001 325i retired
Old 10-25-2007, 06:32 PM
WileECoyote's Avatar
WileECoyote WileECoyote is offline
Needs more cowbell
Send a message via AIM to WileECoyote
Mein Auto: 1999 Z3 2.8, 2000 328Ci
If EOD's slides don't show ya, you can also check out Rachel's pages.
Old 06-17-2011, 07:14 AM
Needs more cowbell
In case EOD doesn't email ya
Old 10-26-2007, 01:40 PM
aclswsmith aclswsmith is offline
Mein Auto: bmw z3
bushings
I replaced both seat bushings for about fourty bucks. This is an easy fix. I noticed that another member is sending the instructions. Just follow each step, and you will be amazed at how easy this procedure is. I also fixed my glove box sag using the instuctions given by a member and also was an easy process knowing how.
Old 08-15-2008, 05:57 AM
lhs2miler lhs2miler is offline
Mein Auto: Z3 coupe
my glove box hangs down, and i noticed someone had the same problem. what's the solution?
Old 08-15-2008, 06:16 AM
Needs more cowbell
There's a guy who's on the bimmerforums' Z3 board who sells them on ebay. Here's a link to it
Old 08-17-2008, 12:01 AM
KraigG KraigG is offline
Officially Welcomed to The 'Fest!
Mein Auto: 1997 Z3 2.8
Just did my glovebox fix with the same kit. Works beautifully!
The seat bushings also worked great, but were a little tougher to get in. That whole "bushings surrounding a block" was a little overengineered, IMHO. They could have done without the bad bushings, and just made the block larger.
Old 08-15-2008, 06:09 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
http://www.mz3.net/articles/253.html
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 08-17-2008, 03:18 AM
///McQ ///McQ is offline
Addicted
Send a message via AIM to ///McQ Send a message via Yahoo to ///McQ
Mein Auto: 2000 M Roadster
I have the same problem. Can you PM the Powerpoint to me also?
Old 06-28-2009, 10:27 AM
sandiegodude sandiegodude is offline
Mein Auto: Roadster
I need to do the same....
Can I also get that PPT presentation? Will that tell me what parts I need to get? Thanks
Old 06-29-2009, 06:55 AM
Z3 Rick Z3 Rick is offline
Could I also get your PPT of how to fix the passenger seat? I appreciate it.
