X3 E83 (2004 - 2010)
2007-2010 X3 Automatic Transmission Problem Master Thread!
I'm making this a sticky and merging all new AT threads from the main page into this one (I can not move older threads into this one because it will insert the previous messages above/before this post).
Thanks to AzNMpower32 for this summary: The problem: A portion of 2007-08 X3s built between 9/2006 and 11/2007 my have possible faulty transmission software programming. This affects X3s equipped with the 6-speed automatic gearbox. The gearbox may fail to respond to throttle inputs, fail to engage a lower gear, or downshift very roughly in normal Drive mode. The problem is not exhibited in manual mode. Cold temperatures may or may not make the shifting quality worse. The BMW fix There is a software update, this is the latest release as of 10/07 Quote:
Call BMW NA
If you are having problems and your dealer hasn't been able to fix them, call BMW NA customer service.
1-800-831-1117
Renault Zoe reservation #313 The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change. Last edited by Andrew*Debbie; 02-12-2008 at 05:29 AM. |
This does absolutely no good. I called and was told "Your complaint has been registered but please return to your dealer for any additional attention to this issue."
been there done that. now what. the new software program made it worse. now it red lines and never goes into gear. any help is appreceiated. making payments have no car.
The problem: A portion of 2007-08 X3s built between 9/2006 and 11/2007 my have possible faulty transmission software programming. This affects X3s equipped with the 6-speed automatic gearbox. The gearbox may fail to respond to throttle inputs, fail to engage a lower gear, or downshift very roughly in normal Drive mode. The problem is not exhibited in manual mode. Cold temperatures may or may not make the shifting quality worse. The BMW fix There is a software update, this is the latest release as of 10/07[QUOTE] AznM's information is appreciated but tells the story from a third person's perspective. And, since she has never experienced this issue-- does not accurately portray what has/is really happened or happening with this MAJOR PROBLEM! Here is a more telling portrayal of what is happening with a growing percentage of 07/08 AT's The Problem Over sixty percent of users polled on this website at the beginning of 07 have a faulty transmission and the number is not diminishing but growing with the inclusion of the 08 line. The gearbox will fail to respond at random times usually in critical life threatening situations such as merging into traffic or avoiding other careless drivers. Can't seem to decide what gear to be in when making quick uphill turns. While downshifting in SD the driver may experience down shifts so rough it seems like you have been rear ended by another driver. Cold temperatures seem to always excerabate the shifting issue and the vehicle may red line or not shift at a normal rate. The vehicle seems to work perfectly while in manual mode, which means this is not a mechanical, but programming issue. The BMW Fix
The Real Fix
BMWNA has had more than ample time to correct this issue. It is now surfacing in the 08 models which says that they have not devolped a tried and true fix. Remember to keep the pressure on as this is not a matter of inconvenience but a life threatening problem. If you let this go BWM will not fix it as their past behavior has shown. If this does not tell you something then CAVEAT EMPTOR directly applies. Last edited by Evlengr; 02-12-2008 at 08:14 AM. |
Bravo on the Sticky. Long overdue.
For those that consider this issue life-threatening, please use Manual mode until a proven, permanent fix has been applied. Since, as stated, the transmission does not exhibit the problems in this mode. Yes, I know, this is not a fix, but a workaround. This mode can also be used to reassure previously tainted family members that you have better control and get them back into the vehicle for needed transportation.
46 & 2 just ahead of me...
So is there another presumably better software update(s) coming from BMW on this?
I had my 07 X3 in for the October update and that did get it about 85% resolved for me. Sure would be nice to get it fully fixed, I'm still shocked at the difference when I drive my wife's 06 X3 that has none of the issues I have. |
"...sock puppet..."
![]() ...at least you still have your sense of humor, E. ![]() Good stickie by the way, thanks Kris. |
Dealers do not always perform the software update correctly. Reading the service bulletin , I can see how it would be easy to do the update wrong. You may want to ask another dealer to verify the software version numbers for both the EGS and DME. Several members posted with "transmission" problems that turned out to be problems with the DSC. One way to test this out is to try driving your car with the DSC turned off. If your problems go away, you may have a bad sensor or other DSC problem.
Renault Zoe reservation #313 The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change. Last edited by Andrew*Debbie; 02-12-2008 at 11:37 AM. |
Changed my Icon to something more subtle. Lol
Glad to see you read through the whole thing WingSpan. Where did that quote come from btw? The service slips I have are not as detailed as that. |
No disrespect, but I don't see how the service bulletin couldn't be more clear. It tells you what to do, what not to do, and what to look out for.
Seems pretty straight forward. The latest update was so screwy they had to send the DME back to New Jersey. They should be doing this as a SOP since some of the dealers techs are having a hard time interpreting these directions ----especially with the volatility of this issue. Last edited by Evlengr; 02-12-2008 at 11:55 AM. |
Yes. But you do have to read and follow them. If a tech just hooks the car up to the BMW Software Service Station and starts the download, it may not work. Just leaving the car in neutral would be enough. We know from several posts here on Bimmerfest, some techs are not checking the version numbers before returning the car. Sending the DME and EGS to New Jersey is a good idea. Unfortunately that means taking the customer car off the road for a few days. Are keys coded to work a specific DME? I'm not sure how the EWS works on the X3. If BMW NA sends the wrong DME back, the car may not start. There are personality conflicts coming into play too. That's a polite way of saying 'pig-headed' service manager. I've certainly run into my share of dealer service problems, just not on this issue. In our experience the quality of service varies widely between BMW dealers.
Renault Zoe reservation #313 The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change. Last edited by Andrew*Debbie; 02-12-2008 at 12:41 PM. |
A/D what I mean is that when you schedule a service update for the vehicle a hot spare with the latest updates should be overnighted to the dealer or sent ahead of time and be waiting for the vehicle to arrive.
This would minimize downtime to a simple swap out and eliminate the point of failure that seems to be recurring. No more he said she said--just BMWNA. They then replace your old DME with the new one and send the out-dated one back for bench testing, newest update, burn in period, then recycled to the next out dated vehicle. This raises the level of quality assuarance along the whole custody chain. |
There are some issues to be overcome. The EWS sends a coded message to the DME when you put the right key in the ignition. The system is designed so that the EWS module isn't easy to bypass. I don't know if the DME is coded to the keys or if only the EWS is.
Renault Zoe reservation #313 The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change. |
My response was based upon one poster stating they had to send the entire DME back to New Jersey to be reflashed or replaced. Since they made no mention of the EWS and that they were/are an SA I figured that would have been mentioned.
I am not a BMW owner at this point, but interested as I would like something nicer than my current ride.
I am doing my homework on different higher end awd's and the X3 is on my list. Depending on the weather I will be test driving an X3 this weekend. It seems from the poll a large group of people have this problem. Has this transmission problem ever been fully resolved? The cold weather package really worth it? Does it do what it says in other words? I would go for a stick but the Missus doesn't want to drive one anymore. Anyone have any experience with Carbone BMW? |
bimmerfest is not a scientific sample. People may come here and post because they have a problem. Likely the problem is not as widespread as the polls here make it out to be. However this is a real problem. J.D. Power and CR don't show anything near the rates reported here. I'm still waiting for the next Consumer Reports ratings. The last one shows a trouble rate between 1% and 2% but most of 2007s were less than 6 months old in that survey. Some of the cars with transmission problems are seriously messed up. Most are fine. It is a roll of the dice. I recommend ordering an X3 with a manual transmission. Quote:
Different cars have different symptoms, so there is likely more than one issue. Quote:
Renault Zoe reservation #313 The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change. Last edited by Andrew*Debbie; 02-13-2008 at 10:07 AM. |
And +1 to AzN's post above. Last edited by HT417; 02-13-2008 at 12:26 PM. |
To answer your question, the manual gearbox on the X3 is a terrific mechanism. There's little reason not to get it. The brakes hold the wheels for 2s while on an incline (start-off assistant) to prevent the vehicle rolling back while you engage the clutch. The shifting is smooth, typical BMW. Plus, by buying a manual, you are telling BMW NA that there indeed is a demand for manual transmissions in the US. BMW took away the 3-pedal X5. Don't let the next X3 follow in its footsteps. Secondly, the latest X3s do not appear to have any unusual problems with the automatic. They come with the latest software from the factory. So, if you order an X3 now, you'll get the latest build, the latest software for everything, and a big fat smile on your face because it's a terrific vehicle. The fix that came out for the older builds also fixed most vehicles, although a small number of those here are very vocal about the fact it hasn't worked on theirs. Based on your location, I would not recommend sport package. I would recommend cold weather AND the heated steering wheel. The latter sounds silly until you try it. And then you start wondering why other cars don't have it. I wish my mom's 325i had this. The heated rear seats on the Cold Weather will come in handy, since the rear of the X3 does not have vents (cut it some slack, its based on the old 3-series from 1999). Xenon headlamps are very highly recommended. xDrive is a terrific system (when equipped with proper tires) and offers terrific control in many situations. Last edited by AzNMpower32; 02-13-2008 at 10:21 AM. |
My 3 month old 2008 X3 has been having problems where on accelerating from a stop sign, slowing for a curve and then accelerating or slowing at a yield sign and pulling into traffic - the car has felt like it went into neutral then jumped into gear - It also changes gears on inclines and then accelerates so fast upon changing gears that it almost jumps out from under me. The dealer "reloaded the GM software" last week at the dealer but it is still not changing gears correctly. Any advice
![]() Quote:
welcome to the club!!
document everything, every single times its and issue. ask them to do the software update AGAIN (remember, it's TWO different updates they have to make) and then if it doesn't work... ask for a buy back or trade assist into a manual version. Quote:
Kevin ----- 2009 MINI Cooper Clubman - "Oxley" Nightfire Red/NFR, Tuscan Leather, CP, PP, CW, Roof Rails & Aero Kit, 16" Bridge Spokes, Xenon, Auto, English Oak Trim & Wood Wheel, Alarm, Hi-Fi ------- 2007 Volvo S60 2.5T 2007 X3.0si PlatBronze/Beige 2006 X3 3.0i, Flamenco Red/Beige 1997 528iA, Oxford/Tan 1994 318iS, Black/Gray 1979 528iA, RubyRed, Tan 1971 2002, Sahara, Saddle |
What version software was loaded? I posted my version earlier. Do you have the same? You need the trans and ECU software upgrades.
Madurodave My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi Retired: 1998 BMW Z3 Member of BMWCCA! |
don't forget they CHANGED the transmission in 07. so it is NEW, even though the X3 is old.
#25
I have come to the conclusion that this issue will NEVER be resolved. These reprograms get an almost satisfactory result. Sometimes the benefits decrease over time, and the trans reverts. My lease will be up in 5/10 and until then I will continue to keep my ears open on the X3. These trans problems are in addition to the outdated electronics. If you are happy with your X3, that's great. I have mixed feelings, and feel like I am settling on some issues.
'04 X3 2.5i gone '07 X3 3.0si gone |
