my control arm story - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 03-08-2008, 09:13 PM
downhiller's Avatar
livin large
so today i took on the challenge of swapping control arms. i had the pelican parts procedure memorized so the job would go a tid bit faster. so i start tearing into things, it took more time to find an impact then it did to take everything but the upper ball joint nut off.
so im running throu everything in my head remembering what pelican said. lower vehical an get from top. upon lowering the car and trying to get the nut from the top i ran into a small problem, the exhaust manifold was in the way.
i didnt want to remove the manifld, because i know the gasket is bad and dont want to make it worse and no one in this town had one. so i get the car back in the air and try everything else possible. that wasnt gunna happen. at this time im pissed off, busted a knucle on the exhaust, and they were goin to close the shop in 30 minutes. so im at the point, attempt the remove manifold and finish it, or put it back together and have a shop do it.
i decided to put it back together and have someone else do it. my main resoning, i looked on the drivers side to see how hard that was gunna be. yea i can do it, but i dont want to think of how im goin to get an impact in there and remove that nut.
so im depressed that i couldnt finish something i started and the fact im goin to take it somewhere to have it worked on.
Old 03-08-2008, 11:08 PM
Paul Christian Paul Christian is offline
Mein Auto: 87.325is
well you tryed to do it...cheers....
Old 03-09-2008, 04:55 AM
chazbo1952 chazbo1952 is offline
chazbo
Mein Auto: 1989 325, 2002 330cic, X3
I made a wrench to remove those upper bolts. I always keep a set of cheap flea market wrenches so I can cut, weld or bend them to fit just about purpose.
Old 08-29-2009, 12:02 PM
slimphilster slimphilster is offline
Mein Auto: 1985 BMW 325 e
replacing control arms
Hey chazbo, I have a 325e 1985 need to get to that inner ball joint nut, how long is the wrench you made for that and is it a 17mm
slimphilster
Old 08-29-2009, 01:15 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
A+ for effort
I Timothy 2:1-2
Old 08-29-2009, 01:35 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
holy anal batman thread from the dead.
e30 & my little girl
Old 08-29-2009, 01:47 PM
an audience of One
Haha... I didn't see that
I Timothy 2:1-2
Old 08-29-2009, 05:24 PM
downhiller's Avatar
livin large
it took me a while to even remember that. but its nice seein people using the search
