Old 04-09-2008, 05:02 PM
bmw520 bmw520 is offline
Mein Auto: BMW E60 2006 523i
Headlight Lens Renewal?
Just wondering can you purchase headlight lenses separately. Mine are looking fairly aged. I've been searching and all I keep finding is the entire headlight units. my car is a 2001 E39 facelifted model. All I want are a pair of lenes. Any help greatly appriciated.
Old 04-09-2008, 06:20 PM
jieg jieg is offline
Ivan
Mein Auto: 525i 2003
have you tried polishing first?
or polishing with brake fluid?, if you getting rid of them, give it a go
---------------Ivan
Old 04-09-2008, 06:39 PM
1bad540's Avatar
1bad540 1bad540 is online now
Mein Auto: E65 750i Sport,C5 z51 e46
no the 2001 doesnt come seperate...
[SIGPIC]
e39 540i sport, acs type 2's,acs sper pdls,Euroclrs(sold)
e65 745i aw sport,21's aib's acspdls& rf splr(sold)
e46 328i Prem Aw18" 335spt whls(sold)
c5 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pana rf,nav,xenon,cldweather,20"4.6rims.(sold)
e65 750I aw, sport. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20"rennen forged,tune,exh,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
Old 04-09-2008, 06:40 PM
jonmcc's Avatar
jonmcc jonmcc is offline
Mein Auto: 04 545i sport
yep if you want new lenses on the 2001+ headlights you have to buy the entire headlight.
2004 BMW 545i sport: current
2005 Cadillac Escalade: sold
2005 LR Range Rover: sold
2006 Infiniti M45 sport: sold
2001 BMW 540i sport: sold
Old 04-09-2008, 06:59 PM
o well, thanks for the heads up. i can stop looking now. does brake fluid work sounds a bit messy.
Old 04-09-2008, 08:02 PM
lennyd lennyd is offline
Mein Auto: 540i/6 Speed
Brake Fluid is a bad idea anywhere near PAINT!
2001 540i 6 Speed / Jade Green Metallic / Two Tone Interior / 16:9 Mk IV Nav / Sirius / Bluetooth / Sport Seats / Staggered 18" M Pars / Custom Exhaust
1999 528ia T / Black / Sport Pack / Premium Pack / Sand Beige / Nav / DSP / Sun Shades
Old 04-09-2008, 08:15 PM
PJB. PJB. is offline
Mein Auto: 2000 528i (01/2000 mfg.)
I would try wet sanding first.
Plenty of people do it. I've done it, and it worked great. Note that the following DIYs are for the old 1996-2000 style headlights (which is what mine were), but plastic is plastic and I didn't even follow those DIYs, I followed one for a VW. Also, note that the DIYs state to remove the headlights, but I did mine whilst on the car, no problems at all:
http://forums.bimmerforums.com/forum...d.php?t=930893
http://www.bimmerfest.com/forums/sho...d.php?t=261628
A general DIY, courtesy of VWvortex forums:
http://forums.vwvortex.com/zerothread?id=2485084
Old 04-09-2008, 08:36 PM
jonmcc's Avatar
this is exactly what I did with my 2001+ AE headlights, and I did it without removing the headlights from the car. I just taped everything up around it, and used a water hose instead of the sink faucet
pics before, during, after:
Old 04-09-2008, 08:53 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Yep I've looked everywhere for facelifted lenses. They don't exist. Still very impressive work there Jon. A slight improvement
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 04-09-2008, 10:09 PM
ill_kuma's Avatar
ill_kuma ill_kuma is offline
Mein Auto: 2001 530i
Jonmcc, how long did it take for you to do that?
Old 04-09-2008, 10:41 PM
jonmcc's Avatar
haha yeah it looked a bit better afterwards...
not including gathering everything and taping the lights, it took me about an hour per light. lots of time spent wet sanding, and then about 25 coats of plastX after the sanding was done! just as a side note, you will have to reapply plastX now and then to keep this lights looking good. plastic sealant helps prolong the plastX, but it will need to be reapplied at some point. I put a couple coats of plastX on about every 2-3 weeks.
another tip: while wet sanding the best method (IMO) is to run the water over the lights, take the stream of water away and sand the lights until you see a milky white substance developing, then rinse them. eventually, the milky white stuff with not develop and you will know to move on to the next higher grit sandpaper. someone else told me that and it proved true for me too!
Old 04-09-2008, 10:44 PM
topazbluee39 topazbluee39 is offline
Mein Auto: 2002 E39
I'm with jonmcc and pjb. I recently "rehabbed" my lenses last weekend. They weren't hazy, but there were a few surface dings that bugged me especially when the lights were on. Personally, I went from 600 to 1000 to 2000 grit sandpaper and finished it off with Meguiar's Plastx polish. The results were great. The lens surface is super smooth and the nicks and dings are non-existent. I do plan on going over it again by hand with the polish. (I initially hit it with the mini powerball) There are some hairline scratches that I notice only when the lights are on. (I may be a little ocd on this one, but aren't a lot of us) Save yourself some bucks and spend an hour or so on polishing instead of replacing! Just my .02!
525i Sport/Premium/Winter/Sunshades/PDC/DSP/Xenons, M5 lip, 35% tint, debadged, M5 wheels, Tec cupholder!
