The X5 SAV Forum
Old 05-11-2008, 03:05 PM
bmwfactors bmwfactors is offline
Mein Auto: 2004 BMW X5
2004 BMW X5 Panoramic Sunroof - Faulty
Hi, please can anyone help? I have a 2004 X5 with an electric panoramic sunroof. The rear roof is faulty and only opens slightly but then doesn't close at all. This stops the front roof closing and I have to use the manual winding tool and then push the rear roof raising arms back manually to shut the roof. As soon as I touch any button for the roof it goes straight back to the same position. Any ideas please?? Many thanks.
Old 06-26-2008, 01:42 PM
TheRugSeller TheRugSeller is offline
Mein Auto: x5
Angry BMW x5 panoramic roof problems not closing
Hi, I'm having the same fun with a 2004 x5. The rear section also will not close. Did you find any solutions? How did you manually get the rear roof section down, I cannot see how you can do this. Please help it's raining!!!
Old 03-27-2009, 11:02 AM
william143 william143 is offline
Mein Auto: 3000 cc x5 d
sunroof fault
hi,how did you get on with your panoramic sunroof fault,i have the same problem mate.cheers.
Old 04-20-2009, 12:22 PM
synct synct is offline
Mein Auto: X5 2004
Panoramic Sunroof X5 2004 Repairs
The back flap of my 2004 X5 Pana sunroof wouldn't close over the weekend, so I took it to Park Ave in Maywood. I was told that the cable had broken the pulls it closed. To do a repair of the rails and cable would be $2,200 (including 14 hrs labor!!!) but if the entire sliding kit was needed, it was closer to $4,000. ABSURD!!!!
I asked them to close it, and they did that for an hour's worth of labor. You can be at the moment that I'm not going to open it!
Does anyone have a lower price estimate?
Old 04-20-2009, 01:50 PM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Chalk up the panoramic sunroof to the problems that BMW (and Mercedes too) seem to be having with these as well as their window regulators. I just don't use mine, didn't want it but it came with the car at no cost. All I need it to do is work when I trade the thing in. Lots of comments on the X3 board about sunroof problems as well.
Old 05-03-2009, 11:25 AM
JeffVander JeffVander is offline
Mein Auto: X5 4.8is
My general rule of thumb with these things is that if it fails and it doesn't hugely bother you, leave it in the closed position and live with it. Repairing any sunroof is typically a huge pain in the ass. It typically involves ripping out the entire headliner to get to the running gear. And, the work itself can be tedious and require more than one person to do. That tempered glass is not thin and is not light. It's impossible to manipulate it by yourself.
Old 03-14-2011, 12:50 PM
PX50477 PX50477 is offline
Mein Auto: US
Sun shade (visor) stuck inside top of X5
Hi, I know this is an old issue at the forum, but I have the same problem except for the sun shade on my 04 X5 is stuck inside the roof, it will not pull back, with the summer coming up and 40+F sometimes in VA, I need to fix that since I do not wish to be toasted. Took it to an indi and was told they will need to take off the whole liner, three days and cost about $2500. I see here someone was saying it cost over $6K at the dealers. I feel it's got to be something more simple, like you can pull it out altho I tried that but it feels something holding it pretty firm. Anyone can help? Thanks!
Old 04-17-2011, 12:16 PM
Christiano Christiano is offline
Mein Auto: X5 4.8is
Well, my first post here and guess what? Yes, my pan sunroof rear section is on vent mode and don't close. WTF???? I try to reset it and nothing.
Anyone has the solution or know exactly what to do/happens? I read somenthing about a part number kit: 54 13 7 240 682. Anyone try it?
Well, any help will be welcome,
Thank you
Chris
Old 04-18-2011, 06:24 PM
Mein Auto: X5 4.8is
I found a video on youtube with my problem. Anyone help?
_________________________________________________
Welcome to the top. BMW.
Old 04-21-2011, 08:44 PM
Mein Auto: X5 4.8is
Well, the car goes to the Dealer to see what happens. Not a diagnostic yet, but they close the rear section and ask me to let the car for 3 days to fix it on monday. I have the extended cover and they say that I'll not spend a penny with that. That was the best part, for me. I'll update this post soon I can get the car back and found what happens or broke.
Chris
Old 05-08-2011, 02:39 PM
buckx5 buckx5 is offline
Mein Auto: 2005 4.4 X5 Black
X5 Panoramic Sunroof stuck - problem
Hi all, My X5 has the same issue, rear glass stuck on ONE side. both glass roof sections try to close but the rear glass only moves on one side...result is both glass sections stay open in vent position...lossened rear glass screws and removed glass and tried to close...front glass went thru the motions to close but popped back up to vent position...looking at the cables and wedge shaped ramps at left and right that lift the rear glass...only the left rear wedge moves...the right side wedge does not move...cannot push it forwards or backwards...not sure how hard to push...have read need to push one side at a time 'reward' until both LH and RH are moved back, but I have not tried this yet...I would think the LH side is connected to motor and could not be pushed back manually. Anybody with a diagnosis what part is broken and how easy can be fixed?...pictures and instructions?...I found a work around on the net that disables the rear glass...lot's of folks say it works great...but I am not sure if it will work for MY stuck ONE side problem.
File Type: pdf BMWPanoramasunroofclosingandfixing[1].pdf (1.15 MB, 7743 views)
Old 05-08-2011, 05:59 PM
Mein Auto: X5 4.8is
I'm waiting some parts coming from Germany to fix my problem. I have exactly the same problem like you. The one side of rear section was closing, equal to your problem. If you could close it, I'll find what they (dealer) will change in mine and tell you everything. But the part still coming. The dealer just close the sunroof for me, I don't know how, yet.
But a important note: Don't push your sunroof repeating the operation to close the rear sunroof 'cause in my case, one side of rear was working (like yours) and I did 4 or 6 times some attempts to close it. Guess what? The other side stop working to. Dammn.
Chris
Old 07-06-2011, 04:10 PM
thelastday0 thelastday0 is offline
Mein Auto: X5
I have the same ptroblem and need your help please. Can you send me the steps. Thank you in advance.
guajaca@hotmail.com
Old 07-06-2011, 04:12 PM
Mein Auto: X5
I have the same problem on my X5
Can you help and send me the steps to fix the problem. Thank you in advance.
guajaca@hotmail.com
Old 05-08-2011, 10:34 PM
Chris, thanks for the warning. I'll try not to close it any more unless I have to. Might have to go to dealer to get the roof closed temporarily.
Old 05-20-2011, 07:00 PM
wrenchmcfly wrenchmcfly is offline
Mein Auto: Land Rover Discovery 1
panoramic sunroof fix X-3 X-5
If you live in the Central Florida area email me and I can fix it. If you want to try the DIY modification yourself email me and I can send the info on the mod. This will get the rear glass to close permanently and the front glass to function normally.
Old 05-14-2012, 03:31 PM
vic3461 vic3461 is offline
Mein Auto: 2004 x5
2004 bmw x5
i am in west palm beach and i am having sunroof problems. can you repair the sunroof.? the shade will not work properly,
Old 05-15-2012, 07:23 AM
sdm_1 sdm_1 is offline
Mein Auto: X5
Melb
For anyone in Melbourne Australia that is either having problems with their roof of want to ensure they don't have in the future, I highly recommend a visit to Precision Sunroofs in Cheltenham.
Owen is a great guy who is more than reasonably priced and knows his stuff. Fixed my roof with 30 min.
Old 05-15-2012, 07:43 AM
Mein Auto: 2004 x5
my bmw 2004 x5 panoramic roof is not working properly. is thereany one out there reasonably price that can repair this sun roof, in south florida. this is my 2nd x5 and both were giving problems. are those panoramic roof defective, bmw need to have a recall on those. can any one help.
Old 06-07-2012, 05:29 PM
kikiluv74 kikiluv74 is offline
Mein Auto: 2004 X5 4.4
Are you still in the central Florida area? My panoramic sunroof will not close
Old 06-24-2013, 07:52 PM
powder2 powder2 is offline
Mein Auto: X5
I'm newly registered to the forum, and I'd love to see your fix! I'll email you.
Old 06-25-2013, 03:31 PM
kollas123 kollas123 is offline
Mein Auto: 2004 x5
x5 shade stuck half way
I have the same sunroof issue but in addition my sun shade is stuck in the middle so I can't access the area for the fix. Is there any hope for me?
Old 01-10-2015, 04:56 PM
Stevescott1969 Stevescott1969 is offline
Mein Auto: BMW x5
Panaramic sunroof
Hi . Can you help me , my wife & I have just bought a BMW x5 on. 05 plate the rear sunroof won't go down , I have to do it manually , do you know how to disable back roof & just have front working ??? Would be so great full if you could help , I live in England . Regards Steve.
Old 01-11-2015, 05:36 AM
sunny43.5 sunny43.5 is offline
Mein Auto: Sorry VW,s
Hello Steve from a fellow EX Pom originally from Hastings in Sussex now resident Aussie . if you go to page two of this post you will find the original post from me on this repair procedure LINK here http://www.bimmerfest.com/forums/sho...=284615&page=2. Scroll down to the bottom of the page for photos and instructions , hope it goes well for you please let me know . Howard
Old 05-23-2011, 05:32 PM
zoelman zoelman is offline
Mein Auto: X5, 545i
I have an 2006 3.0 X5 and have a similar problem with the panoramic sunroof - the glass closed fine, but the rear panel does not come out of the back any longer. the front panel over the driver is in place, but the real panel that covers the passengers in the rear seats seems to be stuck. Same expensive thing told by the dealer to fix, and no warranty. bummer.
b
