Old 07-10-2008, 08:03 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
E90/E91/E92/E93 OEM Spare Tire source
I know the leather-Z kit has been out for a while. it just never sat right with me that a) it was almost 400 for the kit that fit the 335i ( tire + tools + spacer & bolts)
b) you needed to use a 15mm spacer to get it to work.
digging through the ETK, it looks like the leather-z spare is the spare from the E46 cab.
3.50BX17 ET:30
a little more digging shows that the E60 550i uses front brake rotors the same size (348mm) and thickness as the 335i. brake calipers look to be of approximate same size.
the compact spare for the 550i is:
4BX17 ET:18
the offset is close to that of the E46 spare plus spacer-- ET 15 for the E46 spare wheel + spacer vs ET 18
now the fun part. BMW sells a retrofit spare kit for the E60. it includes:
the wheel +tire diameter is within 2% of stock tires.
total price from tischer BMW, for the whole retrofit kit listed above, before shipping, is $239.
I've ordered up a set, will keep everyone posted as to if it works. if it doesnt, i have a new flower planter. if it does, a spare that works without having to deal with the spacer, and for a lower price.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 07-10-2008, 08:32 AM
BMWFM1 BMWFM1 is offline
Mein Auto: 328xi
Very interesting finding. Please keep us posted. (Already bought the LeatherZ but it is good to have alternatives).
Some folks had mentioned at one point using an X3 spare. Have you looked into it?
FM
E91 328xi, Jet Black, Black Dakota, Dark Burl, Premium, Steptronic, Navigation, Active Cruise, Park Distance Control, Sirius Satellite Radio. Debadged, Euro Switch, Dome Strut.
Old 07-10-2008, 08:40 AM
FM
yeah, the 550i and the X3 use the same spare rim. same P/N. i was drilling down using the brake size as a guide and the 550i was the best choice that had an optional spare.
i ran into a problem getting the tire-- when not bundled in the set i found, the tire has a lead time of 6-8 weeks from bmw and tire rack. alone its 120-150 bucks for the tire.
Old 07-10-2008, 09:00 AM
MrBones's Avatar
MrBones MrBones is offline
Skjoni's Dad
Mein Auto: 335i
Did you get a price for just the wheel/tire/valve? Or does it just come as a kit. Cuz I don't need a jack/chock/bracket... I already bought the BMW jack kit. I was planning on using a snow as a spare, but I'm sure your solution would be a thinner, lighter tire.
Old 07-10-2008, 09:12 AM
rim is about 52, tire is 116 from the tire rack, valve, usually 2 bucks when you get the tire mounted. bmw doesnt sell the rim and tire premounted unless its in the kit.
i was actually going to get the rim and tire only, but i only have full sized jacks.
i'm actually hoping i can mount the tire, somehow, to the roof of the trunk.
Old 05-06-2015, 03:59 PM
golferken55 golferken55 is offline
Mein Auto: 2006 E60 (BMW 550i)
This is a stupid question. But where is the jack kit located on 2010 335i coupe?
Old 07-27-2016, 02:03 PM
jimmk jimmk is offline
Mein Auto: 328i 2011
There is a you tube article by a man who has done just that (Mounted a spare to the trunk lid with some bungee type stuff. ; it does look a bit shaky. I just put mine on a 5 spoke rim with a new proper size tire . Got the rim cheap as it had a couple of dings on it. I don't carry a jack.The jack I found is too big and heavy. Now I can call road side and have them change the tire for me. It leaves little room in the trunk for groceries and beer. And I feel safe.
Originally Posted by Orient330iNYC View Post
rim is about 52, tire is 116 from the tire rack, valve, usually 2 bucks when you get the tire mounted. bmw doesn't sell the rim and tire premounted unless its in the kit.
There is a you tube article by a man who has done just that (Mounted a spare to the trunk lid with some bungee type stuff. ; it does look a bit shaky. I just put mine on matching 10 spoke BMW rim with a new proper size tire . Got the rim cheap as it had a couple of dings on it. I don't carry a jack.The jack I found is too big and heavy. Now I can call road side and have them change the tire for me. It leaves little room in the trunk for groceries and beer. And I feel safe.
Old 01-11-2014, 10:47 AM
nallman nallman is offline
Mein Auto: BMW 335d
Hi I'm new on this forum but thought this post might be helpful. I have changed from runflats on my e90 335d to non runflats and was looking for a spare wheel with not that much success, then locally I was offered a set of 18 inch MV 1s luckily the seller let me try them on the front and rear before I paid. And they clear the calipers and discs on both so are OK for spares. Hope this is helpful.
Old 07-10-2008, 10:40 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
Where did you get the data on wheel + tire diameter?
Add me to those who are interested in your testing results.
Old 07-10-2008, 11:36 AM
easy... tire size is: tirewidth/sidewall height (expressed as a % of tire width) / rim size.
stock tire size is 225/40/18
225*0.4=90/25.4=3.54"
3.54*2= 7.08" +18"= 25.08" diameter
spare tire size: 135/80/17
135*0.8=108/25.4=4.25"
4.25*2=8.5"+17"=25.5" diameter
25.4 is the mm -> inch conversion.
Old 07-10-2008, 12:03 PM
Interesting calculated results. For comparison, I have included data for the published spec on the Bridgestone Potenza RE050A RFTs:
Published Spec for Bridgestone Potenza RE050A RFTs in 225/40-18:
Diameter.........25.2 inches
Revs/mile........827
Based on your calculated result of 25.08 inches, there is apparently some minor variance between expected (calculated) and actual (published specification) diameter. Which is why my interest in your actual results. If you have ordered the BMW spare, when it arrives, could you do the following:
1. Mount the spare on your car at specified inflation pressure (60 psi?).
2. Roll the car forward for 1 complete revolution of the tire.
3. Measure the distance covered by the 1 complete revolution of the tire as loaded by the weight of the car.
The distance in item 3. above would give us the loaded circumference of the spare tire. It is then a matter to divide that result into a mile to get the number of rotations value. I acknowledge that the value won't be at speed, but I am wondering how close the rotations result will be to published specifications. If we wanted to get more precise, we could repeat items 1. - 3. for the Bridgestones and make an adjustment based on circumference for the Bridgestones.
I am personally really curious about the result of the measurement for the BMW spare tire. If the measurement is in the ball park, you may have found a viable option.
Old 07-10-2008, 12:22 PM
being completely honest, i'm not too worried-- its not exact on any of the other models. and of course its a temporary spare.
there's even a varience between the front and rear wheels with staggered tires... as well as tire wear varience. the rears will wear out faster than the fronts.
most modern traction control systems can handle 2-3% differences in diameters.
a 125/80/17 spare tire would be almost spot on, but i dont think a 4" rim will take a 125 tire ok.
also-- a runflat tire running on zero pressure has more a diameter difference than the temp spare (the FTM system doesnt trip until there's about a 10-15% diameter difference)
Old 07-13-2008, 05:26 AM
equ equ is offline
Mein Auto: Something or other
Generally agreed, a few % off (ideally below 2-4) should be ok. 10-15% diameter difference is huge. I think you mean, 10-15% pressure/PSI difference.
Are you planning to mount/test?
Old 07-10-2008, 11:58 AM
TireSmoke TireSmoke is offline
Mein Auto: 2012 Audi A6 3.0T
$400 bucks for a spare is highway robbery... I am also interested of there are any alternatives. I have 2006 330xi and I just changed to non-RFT's. I was considering just using AAA, but the problem is if you get a flat and need a new tire it will take 3 days minimum to get one from Tirerack (if the shop doesn't stock those). That's where the spare comes in. It also helps you to get to your destination and not be forced to abandon your trip.
Please keep us informed if any other BMW or other brand spares would fit E90. I assume that '06 330xi and new 335i's would require the same spare, right?
Old 07-10-2008, 12:00 PM
the 330i is a *little* easier, the front brakes are a little smaller than the ones on the 335i. but everything else would be the same
Old 12-19-2010, 09:53 AM
JimMetcalf JimMetcalf is offline
Mein Auto: 135i coupe
I will purchase a jack and a used wheel to mount a full size normal tire for use as a spare. I will lose some trunk space-but its a worthwhile trade for the security of having a spare tire that I can drive on with no limitation. RunFlat tire availability is not good in rural California! I travel a lot in California wine country-being "stranded" 3-6 days waiting for a RFT is not practical for me. It is disappointing that BMW does not supply a "real tire" for the 355i convertible!
Old 12-19-2010, 09:56 AM
deleted-doublepost
Old 01-11-2011, 12:25 PM
I live in rural California- RFT availability here is app 4-10days! I elected to purchase the BMW jack kit, (app $150) a reconditioned spare wheel-$300 and two new Brigestone tires. Put the new tires on car-used the best RFT for the spare and placed it in the trunk. When my RFT are worn-I will replace with regular tires. The wheel and tire does take considerable space-but there wasn't really much usable room there to start-I consider it a worthwhile addition. I now have a spare that I can use with no distance or speed limitations. The hard top stows in the trunk OK! BMW should rethink this problem-or reduce pricing to reflect missing wheel and tire!
Old 01-23-2011, 09:20 AM
dformica dformica is offline
Mein Auto: 2004 x3
buy a bottle of slim and a mini compressor
2004 X3 MINE'S
2007 328XI WIFE'S
Old 01-23-2011, 07:40 PM
wont work on a sidewall rupture or a large enough nail.
Old 11-14-2016, 03:31 AM
outlawslaw outlawslaw is offline
Mein Auto: 328i
AAA is the way to go i dont have a spare or carry fix a flat AAA will bring you air or put you on the flatbed and tow you home for 0 dollars how can you go wrong.
2008 328i Navigation-paddle shift-saddle leather interior-monaco blue paint-
2000 mercedes C230 Kompressor-Mercedes 300E -78 pontiac trans Am 4speed manual-70 SS El Camino 396 64 olds-53 willys jeep 283 small block- 76 fiat 128 coupe
Old 11-14-2016, 04:59 AM
Spare Tire.
I put a ding in the original front right rim. After the dealer replaced the rim I asked him to kindly give me the damaged rim. He put it in my trunk with no problem. I bought a jack and It must cost about $5 a month in gas to carry the spare and jack..
Man i went to my local Tire Guys and got a tire with a ratting that was equal in all but one.Like 180 mph. NO. And 160 mph. Yes. I think you can get 4 for under $300.
Old 11-14-2016, 05:52 AM
Just match up the numbers on the side wall of the tire. I feel stupid telling you that.
Old 07-10-2008, 01:07 PM
rallycobra rallycobra is offline
Mein Auto: volvo XC70 wagon !
Very interesting. I was pricing a 550 spare on ebay, last week. Kudos to you on your initiative! I would expect it to work, and eagerly await your results!
