E36 M3 (1995-1999)
Common Maintenance Issues
I thought it might be helpful if we had a thread handy that mentioned the common problem areas of the e36 /M. Things to look for when searching for a new car and things to keep in mind as the miles go by (in fact, much of this list is normal maintenance). Here's a list off the top of my head:
1) Rear shock mounts 2) Rear Trailing Arm Bushings (RTABS) 3) Water pump (they seem to last about 40k miles even with the ss impellers, but 95 - mid 97 /Ms had a stock plastic impeller that failed routinely) 4) Transmission mounts (to avoid mis-shifts) 5) Shocks (oem seem to last about 40k miles) 6) Radiator (hose fittings crack - about 60k miles?) 7) Thermostat housing 8) Vanos failures seem to be fairly common 9) The undercariage panel seems to routinely fall off (and can be replaced with an aftermarket metal piece that stays) Anyone think of anything else? |
- Sticky 5th gear.
- Uneven idling on cold starts - Bent wheels on the earlier models
1998 M3/4: Arctic Silver on Black; 5-spd; LTW forged wheels, power seats, butt warmers, cruise, OBC, roof, Koni Sport shock absorbers (rear only), CD43 headunit, hardwired V1. |
-Front control arm bushings
-Camshaft timing sensor -Faulty ignition cylinder -Brake light circuit failure |
Excellent! I was going to ask for a list like this - thanks.
TD, what exactly is the "fault" with the ingnition cylinder? The second time I drove my car the key seemed to just spin around in the cylinder without engaging. Perhaps I didn't push it in far enough...
'98 M3/4 (manual) Estoril/black nappa, UUC clutch stop, airbox debaffled, Pilot Sports ’04 Discovery II |
-Plastic radiator neck fails, leaving nothing for the coolant hose to clamp on to. Only solution is a new radiator. Many replace this before 80K as a preventative measure, since a failure = stranded on the side of the road.
-There seem to be two independent transmission problems. One makes it difficult to shift into gear. The other occurs on cold days, when the detent for 5th gear goes away and the shift lever rests underneath fifth when in neutral. |
Thanks.
M3 Gear Shift
HYA MATE MY CAR SEEMS TO BE HAVIN THE SAME PROBLUM AS URS ITS DIFICULT TO GT INTO GEAR ONCE ITS WARM... DID U MANAGE TO SORT URS OUT??
The oil pump nut can back out, causing a total loss of oil pressure and possible engine failure...
Also, when I had it done, the TSB was not in the dealer's computer. Brecht seems to go the extra mile - they called BMW's helpline, found out about it, and had it faxed to them. |
WATS THE ISSUE WITH GEARS NT SHIFTING AS MINE IS ALSO DOIN IT WEN ITS WARN??? |
13 535i M-sport 11 MB R350 04 MB E320 98 M3/4/5 00 323i (sold) 10 MB ML350 (sold) 08 MB GL450 (sold) |
replace clutch slave cylinder
Which leads me to the thought - maybe you should lower your clutch stop a bit? I kind of doubt it will fix it though. I have next to no travel before the pressure point and it works fine. How much travel do you have? |
With a brand new tranny, I suspect your problem should be an easy fix. Have you posted to bimmerforums with the problem? There are a lot of E36 M3 owners over there as well. Never hurts to ask.
Other people who drive the car DO notice shifting difficulty though...including 1 person on this board.
facebook.com/sctsracing 02 M3 SMG Coupe - prepared class BMW Club racer 08 135i 6sp - stock class BMW Club racer Photo gallery |
http://www.unofficialbmw.com/e36/int...oil_alert.html
Chuck Brazeau 1995 BMW M3 - Violet on Black SCCA Solo2 - Street Modified #95 www.BrazeauRacing.com ![]() West Texas Region SCCA Webmaster - www.WTRSCCA.org |
#25
The subsystem beeps and flashes on loss of oil pressure, and also warns you if the oil switch doesn't close when the engine is stopped. |
