The X5 SAV Forum
Old 11-15-2008, 01:57 PM
x5strive x5strive is offline
Mein Auto: 2005 BMW X5 4.4i
2005 4.4i X5 transmission problems
Hey guys,
I drive a 2003 4.4 X5. It has about 111,000 miles on it and unfortunately im having terrible transmission problems with it. Simply putting it into drive, I need to wait a good 5 seconds until the car is in gear. I took it to my local dealership and they said they would have to replace the entire transmission for about half of what the car is worth now. Is there a way to fix an automatic transmission without replacing the entire thing? I'm considering just selling the car.
thanks
EDIT: I actually have a 2003 X5 4.4i, with the 5 speed transmission, not the 6 speed found in the 2005 and up. As i posted further down also, the car is having clutch problems I believe, the transmission slips hard almost in any gear, and jumps and catches gear. I dont beleive that changing the mezatronic unit or upgrading the firmware for the tranny control will help me in this situation.
Old 11-15-2008, 07:40 PM
Craig B Craig B is offline
Mein Auto: 2009 X5 35d 2007 Lexus LS
You can check salvage yards for a good used transmission. If you sell it with a broken transmission, you won't get much for your vehicle in my opinion...
Craig
Old 11-16-2008, 12:00 AM
zibawala zibawala is offline
Mein Auto: 2005 x5 4.4, 2010 M3 conv
I have same car! problem, jerky transmission, booming too, continuing issue, previously fixed temporarily by firmware /software upgrade!
This time they changed MEZATRONIC UNIT, part of transmission, now working fine! Pm, me if u need more info
Old 07-11-2009, 01:36 PM
TimRice TimRice is offline
Mein Auto: 2004 x5
that is good. i have the same problems. got the same answer. replace the whole transmission for $9,100.00. After picking up from the dealership yesterday, i drove it in sport mode and it has not been jerky. i dont see how the whole transmission needs to be replaced if it works fine in sport mode. I will talk with the mechanic. thanks
Old 10-20-2009, 06:23 PM
cholongar cholongar is offline
Mein Auto: 2005 X5
Hi Zibawala, My x5 has the same problem kick in the butt from first gear to second gear.
started from 30.000 miles. It's been in the shop many times. first, they said it's the power of the 4.4 engine, after that they could not duplicate the problem. they said it has the latest software upgrade.
now few months passed warranty and today just hit 50.000 miles. problem is, it's getting worse. Would you please explain more about Mezatronic unit? at what mileage did you get yours replaced and did they do it under warranty?
Old 11-16-2008, 09:28 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
+1 on the salvage yard if the Mezatronic Unit fix doesn't work. Also use a good independent shop to do the replacement, they will be cheaper than the dealer.
Old 11-16-2008, 01:41 PM
Ok i guess I didn't really describe the problem correctly. The car slips in almost every gear during hard acceleration, which leads me to believe that the clutch plate is ruined. Is there any way to crack open this transmission, and have someone work on it? or do we have to replace the entire tranny.
Old 11-16-2008, 10:59 PM
I would recommend to get it check through your insurance company repair shop, e.g through AAA
Old 11-17-2008, 09:07 AM
After 111K miles you probably do need a rebuilt or new box. You can have your transmission rebuilt at a specialty shop for a lot less than the dealer will charge. You can also have a box from a dismantler (salvage yard) installed at even less cost. I have had excellent luck with both over the years. I look for an independent shop that just does transmissions and rear ends. Ideally this is a shop that other dealers use for this specialized work. I avoid the franchise operations, but that is just my personal preference. Visit the shop and look around the work area, if it is spotless and well organized with high end cars on the hoists you have found a good one. Avoid the shade tree operations with parts piled up and junkers parked outside. Good luck!
Old 10-30-2011, 08:50 PM
X5CLUB X5CLUB is offline
I had the same issue with my 2005 X5 4.4 Sport Package. I'm embarrassed by the solution. Mine has had this issue for some time and the dealer tried a software fix. It did not correct it. So, being out of warranty, I just kept driving and mostly used manual mode. The only time it really presented a problem was a rolling stop, usually on a hill. Well, about month or so ago my tire pressure light came on and one of my front tires was low, but I checked all of them. THe rest were around 30 PSI... still a little low. Well, if you look inside your door panel when you open the door, you'll notice that it says for the larger rear tires they should be inflated to 39 PSI. SO I filled them all to spec AND NOT A PROBLEM SINCE. I'm kinda surpised as to the sensitivity of the transmission. This should give my torque converter a break too. Put AIR in your tires and see what happens... 39 PSI rear for the larger tires (check your door panel).
Old 11-10-2011, 06:25 AM
gerry9870 gerry9870 is offline
Mein Auto: BMW X5 V8
Originally Posted by x5strive View Post
Hey guys,
thanks
Hi,, tell me exactly what problems you are having with the gearbox, I have repaired countless gearbox problems without the need for the transmission to be replaced.
Cheers
Gerry
Old 12-01-2011, 02:13 AM
azmaz azmaz is offline
Mein Auto: X5
Cheers
Gerry
Hi,
Can you please help me find a solution for my problem aswell?
I have a X5 of 2004 with almost 295000km and since yesterday I have a problem with my transmission aswell. When I put it in R it starts driving forwards instead of backwards! When I put it in D it takes a few seconds before it moves.
I went to the dealer and they said they need to change the gearbox but that's so expensive! I hope that there is a solution that doesn't involve changing the gearbox because the car isn't worth that much anymore. I hope you can give me some tips.
Old 12-01-2011, 03:25 AM
Originally Posted by azmaz View Post
Hi,
Hey There
I willhelp as much as I can,,but I need to some more details, does the car display the symptoms when it is cold or warm, have you lost the kickdown gear, can you use your gearbox in maual mode, has a message TRANSFAIL PROG appeared on the dash, when you select drive does the car take a few seconds before it engages gear, but you experience a loud thump before it moves off.
Cheers
Gerry
Old 12-01-2011, 04:27 AM
Mein Auto: X5
Hey There
Cheers
Gerry
Hi Gerry,
Thank you so much for your fast reply
There's nog change in temperature these days so I don't think it has anything to do with heat or cold. I can use the gearbox in manual mode but it still takes a few seconds before the car actually moves slowly and it makes a noise (it's the same movement and noise when I put it in D). When I put it in R it starts to drive forwards immeadiatly without making any noise.
Old 12-01-2011, 04:22 PM
Hi Gerry,
Hey
When i say cold i mean does the car display the symptoms when the car has just been started up ( cold start ) or when it has been ran, can you describe the noise for me, I think i know what maybe causing you this issue but I need to be sure first, run through the whole sequence of what happens when you put your key in the car for the first time, what mode gear you select, what noise appears etc
Gerry
Old 12-03-2011, 11:49 PM
zeebmw zeebmw is offline
Mein Auto: 1998 528i
Hi Gerry, u seem knowledgable, I had a problem today with my tranny, I was in Reverse rolling back, then I put it in Drive, and gased it quickly, it didnt move, then engaged with a clunck, then as if it was in 2nd gear instead 1st, then the message Tans. program failure appeared, no check engine light or anything, I decided to go in manual mode, at first it did the same thing, then it worked, then I thought I will program the trainny by using manual mode, but after driving it for a while, put it back in regular automatic mode, it worked fine, except one time I was almost stopping, and I had to move fast, the clunk happened again. works fine in manual mode. never tried sports mode though. any ideas Gerry?? thanks
Zee
Old 12-04-2011, 05:11 AM
Zee
Hi Mate
Trans Fail Prog means the gearbox electronic gears from 1 -4 will not be selected by the main gear computer, BMW X5'S WERE BUILT WITH A FAIL PROOF GEAR ( 5TH GEAR ) when the gearbox components fail and trans Fail Progrm appears then the electronic gears 1- 4 shutdown and the car puts itself into 5th gear because it knows there is a problem.
Trans Fail Progrm,,,,can mean several points,,,but first can you tell me what is your mileage / kms on the car, do you drive it hard ? was the car just warmed up, or cold start when the problem started, have you lost your kickdown, try putting the car on a hill, shut the engine off and restart to see what happens, the clunk you have experienced is the torque converter and the stator not sychronising with the clutch possibly due to wear, if you can take it for a drive both in auto sports first and manual and try dropping the gears to see what happens.
Let me know how it goes so that i can advise further, once we can narrow down the options then i can more or less diagnose the fault,
This is my email if you need any further info
gerry.gorman@blueyonder.co.uk
Old 12-04-2011, 05:33 AM
Hey Gerry, first thanks for your time to help people
I was driving the x5 for at least 100 miles when this happened, seeing my mailbox while in the car, tried to take off quickly, and it happened. As far as miles I have 90k miles on it, I do drive it as supposed to, but one time I put it in manual mode when I first got it, and I stayed on 1st gear and tried to shift the +/- in the opposite direction, to the front thinking it is +, which ended up staying long on first, that's the only thing I remember I did wrong with it, the previous owner was my friend, and knowing how he drives, he might be a harsh driver especially that this is a sport package too, the big wheels might hurt it more, but today I will try the things u gave me to narrow the problem down, just to let u know that the car is driving fine, only in certain places this happens. I will try it today and get back to u, thanks
Old 12-04-2011, 05:47 AM
Hey Zee
Yea no probs about you coming back to me, try the things i said as they all point to certain parts of the gearbox components, one thing iam sure of is that your gearbox will be fine, they are practically bullet proof and should never need replaced, there is a small particle filter inside the gearbox that usually needs replacing around your mileage, but try out first so we can narrow it down
Cheers
Gerry
Old 12-04-2011, 02:47 PM
Hi Gerry, very busy sunday for me around the house!!
I took the truck for a ride and did what u told me and here what I found out:
the kickdown is still available in aut. reg. mode and in sport too.
tried it in sport first, drives perfect, all gears change the way they supposed to, and in manual same thing, all of them work up and down, then I tried it in reg. aut. mode and it drove really nice too, but the whole drive was around 10 miles, hopefully this will help you(and me) sort the problem out
one more thing, I thought these transmissions should have a lifetime oil, I thought I read that in the manual, u know better, I am waiting for ur reply on fire!
I can't thank u enough man!
Zee
Old 12-04-2011, 03:14 PM
Zee
Hi Zee
Did you do a hill start ?????,,,,,,sorry i meant to say to you to pull away in manual on third gear to see if there is any slip??? sorry about that i meant to say earlier
Well the gears are working fine by the sounds of things,,so no probs with the gearbox, the gearbox oil has a lifetime fill, BMW class a lifetime fill and a cars lifetime span as 100ks, this is where the life of the car ends, tell me was the car still moving when you reversed it and then selected the forward gear ??
Come back to me
Gerry
Old 12-04-2011, 03:34 PM
here u r, well I can try the 3rd gear thing in manual and let u know what happens! but yeah it was driving %100, is it possible when it gets hot?
to answer your question, when i was reversing, I was almost in full stop when I put it in drive, but what happened it didnt engage in D fast enough, so my foot on the gas pedal was faster than the gear itself, thats when the clunk happened and then the whole story.
u mentioned in earlier post the filter inside the gearbox, what about that? thanx Gerry
Old 12-04-2011, 04:16 PM
Hey Zee
Well i have absoultely no worries that you have an internal fault, if this clunk has only happened the once with trans fail progm appearing on the dash, then im 99.9 per cent certain that the stator which id part of the one way clutch and torque convertor did not distribute the flow of directional oil quickly enough to drive the torque, hence the fast gas pedal while the car was still in motion ( moving ) the filter would only need changing if you experienced this on more than one occassion, the easiest way to check if the particle filter is clogged is to drain a small plastic cup full say about one quarter and check for small particles and also smell it for burning trans oil, burning oil is where the particle filter and the gearbox oil cooler keps the flow of oil at a nice operating temp.
Keep me posted but if your saying that this has happened only the once then you have no worries with any fault,i know the gearbox components like the back of my hand and i can assure you that if and when they fail then you would be experiencing a lot more issues to do with loss of gear.
Best wishes
Gerry
Old 12-30-2011, 04:01 PM
bob&sonia bob&sonia is offline
****ie
Mein Auto: X5 4.6is, Pajero 2.5,
Question Trans fail safe prog
Hey Zee
Best wishes
Gerry
Hi Gerry,
I am a new owner & member...
Cut a long story short, we bought a 2002 4.6is X5 88000ml today (30/12/11) and on the way home @ 40mls driving sensibly we felt a small kick/thud/shunt in the driveline, pulled over turned off, re-started, no real getaway power, once up and running seemed to be overrevving..
Not able to use sport mode at all, seemed like we only have one gear. Into dealer in morning for fault reading, rang dealer purchased from is willing to help a little as this was his personal car.
Got home disconnected the battery, nothing different, tried the gas pedal thing, nothing
Be very gratefull for any advice
Rob & Sonia (disheartened owners)
Old 12-04-2011, 06:48 PM
Me again, I found out something, it happened again while I was in reg auto, it was running nice till about to stop and then u go, that when it always happen, and when it happens, whatever u put s mode or manual, the first gear will rev high but slow motion, then engages with a clunk for 1st gear, and as long as u start from standstill, it won't happen, except rolling then gas in reg aut mode, but it will never happen in s mode or manual, unless u were in reg mode then when it happens, no matter what mode u put iT in while moving, it won't reset till u u release ur foot off the gas pedal till it engages with a clunk depending on how hard u were on the pedal, but again it won't happen if u started on s mode or manual.hppefuly this will give u a better idea for diagnostics. Regarding the filter change can an Indy mechanic do it or it needs special tools, and how would the mechanic know how much oil to refill if i changed the filter, sorry for troubling u that much Gerry, but I guess u r close to know what is wrong. I tried the 3rd gear in manual mode it is fine.
Thanks a bunch!
Zee
