Old 01-31-2009, 12:36 PM
dakarm dakarm is offline
Send a message via AIM to dakarm
Mein Auto: 00 M Coupe, 08 MCS JCW S1
DISA replaced and rattling noise gone! potential disaster averted!
I've had the rattling noise for a while and at first I thought it was the VANOS, but after further research and reading the 330i doesn't suffer from the VANOS rattling noise. I actually went as far as buying all the gaskets to do the VANOS seal replacement until I realized it was the DISA making the noise.
Fast forward to today:
Here are a few pics of the DISA removed from the car.
as it came out of the car. notice the pin has work itself out about 1/3 of it's length!!!!!
the flap was not perpendicular + like it should be and generally really really dirty.
close up of the pin... scary.
the flap had a lot of movement in it. about 1/4" before any resistance was felt. the new one was perfectly centered + and wasn't as easy to move as the old one.
Thanks again to bimmerfest for potentially saving me from having to pay for a new engine
ID:	173597   Click image for larger version
ID:	173598   Click image for larger version
member of CRS Club
'00 Dakar Duck CRS Edition
'10 335d
'12 X5d
'12 MINI Countryman S
Old 01-31-2009, 01:31 PM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Wow that's a scary looking part. How much mileage is on your 330i? Was the DIY difficult?
Old 01-31-2009, 01:34 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Wow, that's crazy. +1 on what the mileage is.
Old 01-31-2009, 01:40 PM
Gryphon's Avatar
Gryphon Gryphon is online now
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
True. These cold weather part failures, as well as worn part threads is getting me paranoid. I think Inspection II for me is gonna be an overboard of more than required thing for me.
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 01-31-2009, 01:50 PM
I would just listen for the rattling noise. At least this one is an easy DIY
member of CRS Club
'10 335d
'12 X5d
Old 01-31-2009, 01:49 PM
current milage is 168K but the noise probably started around 150K or so. I shouldn't have ignored it for so long. I could have paid the big price. I read (here in fact) of someone having the pin back out completely and be swallowed up by the engine = kaboooom
the DIY was fairly easy for me. took me about 15mins total. I had to make another extension to be able to reach the T40 bolts (also taped so they don't come apart). I also had to disconnect the intake tube and push it down so I can get at the 2nd bolt and remove the DISA. Part was a little expensive ($183 with shipping from Tischer) but to think what could have happened if the pin worked itself loose and into the engine.... Well, like I said, I saved money (and potentially the engine)
see above.
member of CRS Club
'10 335d
'12 X5d
Old 01-23-2012, 09:51 AM
coupe*steve coupe*steve is offline
Mein Auto: bmw 318ci se 2000cc
see above.
Apart from the rattling noise what other problems was you having?
reason why I ask is im having problems with mine and trying to find out what is wrong
Old 01-23-2012, 10:01 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
This thread is from three years ago. The OP hasn`t been around in a long time....
The road goes ever onward....
(R.I.P. Jever)
Old 05-18-2012, 12:33 PM
michael_ro michael_ro is offline
Mein Auto: 325i E90
Hello guys.
I have an idle problem with my 325i E90. The bimmer has a poor start (it tends to die after it runs for 3-4 seconds) and at the last moment it revs up the engine to stop it from stalling. Another simptom is that the RPM needle starts to slightly fluctuate only after the car warms up. I looked for vacuum leaks(2 on the DISA valves) and sealed everything and did a diagnosys test. It reveiled a P160F code - "Power management problem" and P14C3 code - "DISA (Differentiated Intake Manifold) Actuator 2 Mechanical or Hardware Defect".
I looked at the 2 disas before when I was looking for vacuum leaks and besides really bad seals (which looked like they exploded) they looked fine.
Pictures of the 2 DISAs:
http://www.e90post.com/forums/showth...8#post11967898
Now this error code apeared.
Can a bad DISA influence the car's starting or the fluctuating in RPM at idle?
Old 01-31-2009, 01:52 PM
Solidjake's Avatar
Zero. Leaks.
I'm gonna take a look at my engine bay and see what I hear. It is expensive, lol. But it needs to be changed regardless.
Old 01-31-2009, 02:05 PM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
Is there enough room inside the intake manifold for the pin to wriggle free and get into the engine? The pin on my car's DISA unit came out completely while I was removing it from the manifold last year, and I spent several tense minutes locating it in the engine bay. After retrieving the pin, I cleaned it off, pushed it back into the flap, and reinstalled the DISA unit.
Since the DISA unit slides into a channel between the two halves of the intake manifold, I have my doubts that the pin would even be able to get loose in there and do a tap-dance inside one of the cylinders - but I'd like to hear from someone who has studied the system more thoroughly.
Old 01-31-2009, 04:38 PM
someone posted that exact thing happening to him. I don't remember if it was here or e46fantatics. my pin slide in and out fairly easily so I'm sure given enough vibration and time it could have come out completely.
in my case I had to replace the disa as it was completely worn.
member of CRS Club
'10 335d
'12 X5d
Old 01-31-2009, 04:52 PM
Fast Bob's Avatar
Keeping it surreal
If and when I ever replace the DISA valve, I`m gonna take a copper pipe cap, maybe 3/4 inch, or whatever is a close fit over that pin boss, and epoxy and/or drill & safety-wire that sucker to the boss to prevent the pin from coming loose....
(R.I.P. Jever)
Old 01-31-2009, 10:06 PM
Gryphon's Avatar
The Boss of Nobody
Werd
MacGyver school of engineering FTW!
Born 02-24-11
Born 06-22-16
Old 10-14-2011, 10:45 AM
new_kid new_kid is offline
Quietly Learning E46
Mein Auto: 2000 BMW 323i
Would you really???....
I have always thought of you as very proper and right-way-kinda-guy when it comes to Bimmer repairs.
..but then a little relieved
Old 02-02-2009, 02:55 PM
DaShoker's Avatar
DaShoker DaShoker is offline
Fitness Freak {}=={}
Mein Auto: Lexus SC turbo
What does DISA do anyway?
Vadim
^ Highway Beast ^
SC300
2JZGE NA-T
Old 02-02-2009, 03:33 PM
found this in my search:
To be exact, the DISA valve does not change the length of the intake system on the six-cylinder engines from the M52TU onwards - its function is to be open at low speeds, so feeding all six intake pipes together.
At mid-range speeds it closes, seperating the front and rear groups of three cylinders from each other. At higher speeds it opens again, joining the cylinder groups together. It therefore acts like a massive balance pipe which can be closed when required.
The effect of this is to give more mid-range torque without interfering with bottpm and top-end torque.
member of CRS Club
'10 335d
'12 X5d
Old 01-17-2011, 10:04 AM
I've been searching for a good (read "simple") explanation of the DISA valve operation and this is the BEST I've found!
Thanks.
To show my appreciation, I added it just now to the VERY best of E39 Links as a re-use reference (and that's the best compliment of all).
- DISA VALVE FLAP BREAKS: the DISA valve flap breaks, sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) or the disa valve o-ring fails (1) (2) & where to get just the DISA valve o-ring (1)
Old 10-13-2011, 11:08 PM
I think that explanation is wrong, based on this explanation:
- m54x5[1].pdf
Originally Posted by rdl
- Pages 42 -44 describe DISA operation
below ~ 4000 RPM closed
above ~ 4000 RPM open
rest position, i.e. when removed - flap open
The resonance system provides increased engine torque at low RPM, as well as additional power at high RPM. Both of these features are obtained by using a resonance flap (in the intake manifold) controlled by the ECM.
During the low to mid range rpm, the resonance flap is closed. This produces a long/single intake tube for velocity, which increases engine torque.
During mid range to high rpm, the resonance flap is open. This allows the intake air to pull through both resonance tubes, providing the air volume necessary for additional power at the upper RPM range.
When the flap is closed , this creates another "dynamic" effect. For example, as the intake air is flowing into cylinder #1, the intake valves will close. This creates a "roadblock" for the in rushing air. The air flow will stop and expand back (resonance wave back pulse) with the in rushing air to cylinder #5. The resonance "wave", along with the intake velocity, enhances cylinder filling.
The ECM controls a solenoid valve for resonance flap activation. At speeds below 3750 RPM, the solenoid valve is energized and vacuum supplied from an accumulator closes the resonance flap. This channels the intake air through one resonance tube, but increases the intake velocity.
When the engine speed is greater than 4100 RPM (which varies slightly - temperature influenced), the solenoid is de-energized. The resonance flap is sprung open, allowing flow through both resonance tubes, increasing volume.
Note: With 12 volts DC to the DISA valve, the 'magnetic valve' closes the DISA flap; when you remove the 12 volts DC, the DISA flap flips back open due to spring tension.
- Strange results from a simple test of the M54 DISA valve today
Old 05-04-2016, 10:02 AM
rbelton rbelton is offline
Mein Auto: E39
Here's the noise I heard in my experience with them. On an M54 in E39, failing DISA.
