Old 06-23-2009, 06:41 AM
reachg reachg is offline
Mein Auto: 2009 X3
How to Reset Bluetooth?
I recently upgrade my iphone 3G to iPhone3GS. When I try to pair it with my 09 X3. my iPhone doesn't see the BMW Bluetooth. I saw it once before but entered a wrong pin and since then the iPhone doesn't seem to find BMW bluetooth. I was thinking this might get resolved by doing some sort of reset on the BMW bluetooth module. Would appreciate your help.
G
Old 06-23-2009, 07:56 AM
madurodave's Avatar
BMW Enthusiast!
I got mine to work by the following:
1. Key on
2. RT button on steering wheel depressed - looking for devices on radio display
3. Turn on Iphone 3GS
4. Key in BT code into phone
5. Voila! Done!
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 10-20-2015, 11:20 AM
babyboy22plyr babyboy22plyr is offline
Mein Auto: bmw x5 3.0i
Just. Go the the trunk area go to the right side everyone says left side open the left side panel pull out fuse 10 and 7.5 wait a couple sec then replace. Ur done the red light should come back on and the steering column should work again go to blu tooth and it will re recognize the phone
Old 06-23-2009, 09:17 AM
X3-terrestrial's Avatar
Aficionado
There is a way to delete all the paired phones from the BT system, I think it is in the phone manual. Let me check and I let you know.
Old 06-23-2009, 10:15 AM
Aficionado
Ok. The manual says that up to four phones can be paired at the same time, maybe you've reached the limit if more phones have been paired in the past and not deleted; therefore not taking a new phone. Try this to delete ALL devices:
1-Press and hold the button with the "speaking face"on the steering wheel, then after about three seconds, turn the ignition key to position 1 and release the button after aproximately 3 seconds. "BLUETOOTH PAIRING" appears on the display or monitor.
2-Press the button again for approx. 10 seconds until you hear a triple accoustic signal.
"PAIRED DEVICES DELETED" appears on the display or monitor.
3-To conclude the deleting process, turn the ignition key to position 0.
All the phones that were originally paired are now deleted.
Old 06-23-2009, 11:54 AM
Mein Auto: 2009 X3
Thanks for the detailed instructions... I will try it.
I have a follow up question ..what happens if you pair 2 phones and they are all in the car, which one does the Bluetooth pick up? I remember in past I paired my wife's iPhone and then I was having an issue that the Bluetooth was pairing with her phone rather than mine when both the phones were in the car. I was under the impression that it would pick mine as that phone get's used more in the car.
Old 06-23-2009, 12:20 PM
Aficionado
You bet.
Not sure what's the logic on that. I would assume that it will pick up the last used phone, but also could be the one that was paired first.
What i do when more than one paired phone is in the car, we turn BT off on the phone we don't want to use.
Old 06-23-2009, 12:21 PM
madurodave's Avatar
BMW Enthusiast!
I believe it is order of entry. It searches based on that order. My wife's does the same thing. In my case, I paired mine first, then hers. I did the same on both cars and hers always comes up first.
Madurodave
Member of BMWCCA!
Old 06-23-2009, 12:59 PM
Mein Auto: 2009 X3
I was told it depends on which phone is used most often and that would make sense to me.
Old 11-23-2011, 06:54 PM
dpapile dpapile is offline
Mein Auto: 535 xi
My 535xi has a does not have a key. if I put the fob into the ignition slot the car will power up but not turn over. Is this the same as position one?
Old 12-29-2012, 01:47 PM
slilley slilley is offline
Mein Auto: 2004 BMW 330i ZHP
I tried this process on my 2007 X3 without Nav, and it didn't work. It's the same process documented in my X3's Telephone addendum to the owner's manual. I did manage to pair a new phone without deleting the old ones, but the radio display never changed to the "BLUETOOTH PAIRING" mode. BMW's instructions truly suck!
Regards,
Steve
Old 10-20-2015, 11:28 AM
reset ur phone to pair again
Just go to the trunck and on the left side panel there r fuses take out The on that is 10 and 7.5 fuses wait and the red light comes back on ur radio then go to blu tooth and research it will tell u 2 retype ur pin that's it. Everyone says go the the left panel and unscrew this and that to much work.
Last edited by babyboy22plyr; 10-20-2015 at 11:29 AM. Reason: it's the right side panel not left.
Old 10-20-2015, 11:35 AM
Its the right side panel sorry. Don't listen to all those people who say u need to take the left panel out then slide out the floor boars just go to the right panel u will c fuses take out the 10 fuse next to the 7.5 out and wait then replace that's it.
Old 01-27-2012, 11:51 PM
samer2011 samer2011 is offline
Mein Auto: x3
How to Reset Bluetooth? it's doesn't show in screen ***1567;
my car is X3 2005 3.0
Old 12-30-2012, 03:37 PM
X3fanatic X3fanatic is offline
Mein Auto: 2008 X3
Worked for me. Thx
Old 01-11-2013, 09:41 PM
MyFirstX3 MyFirstX3 is offline
Mein Auto: 2014 BMW X1 x28i
I have a 2004 X3.. my steering wheel has the RT button and the voice command button but none seem to work.. A friend told me that it could be possible that the steering wheel has these buttons but that the modules did not come with the car?? is this possible? how can i find out if i do have the modules... any help would be appreciated.
Old 01-11-2013, 10:58 PM
x3brian x3brian is offline
Mein Auto: X3
Your friend is right, but more importantly your description says you have an 04. Unless its a very late build month Bluetooth wasn't included in the 04.
You can check this easily by opening your trunk, looking to the left side and removing the cover (push lever on left side). If you have a BT module it will be silver and on the wheel well with a BT logo and a pairing code.
Old 01-12-2013, 11:23 AM
BlueTooth on X3
Thank you for the help X3Brian... It looks like I dont have the module I followed your instructions and looked in the trunk and it looks like I dont have it.. here is a picture of what I have.
Old 05-18-2013, 09:35 PM
Rhbishop Rhbishop is offline
Mein Auto: 2006 z4
I have a problem. Neither the bt (face) button or the r/t button will activate the Bluetooth in the car. Any solutions.
Old 05-18-2013, 10:01 PM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Mein Auto: 2015 X1 sDrive XLine
Need more info. Year? Navi? Etc.
Kevin
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 05-19-2013, 06:37 AM
Mein Auto: 2008 X3
You may have reached your 4 phone pairing limit with the mistaken code. I would you delete all your pairings and then try pairing your new phone again. Take a look at x3-terrestrial comments attached to this post. Let me know how it goes.
Old 05-20-2013, 09:17 AM
Mein Auto: 2006 z4
I thought that too. However neither of the steering wheel buttons will activate the blurletooth. And I found a loose cable in the trunk. But don't know what it goes too
Old 05-20-2013, 01:03 PM
Mein Auto: 2006 z4
It is a 2006 Z4. No Nav system. The Bluetooth worked when I first bought the car about 6 weeks ago
Old 10-19-2015, 04:13 PM
most bmw x5 or others umpairing and repair phone
{just go the the truck on the right side there is a panel after removing panel u will c fuses below it tells u what fuse is for what. Pull out the one for telephone fuse pull out fuse 10 and 7.5 wait 10sec and put them back in. That's it the red light will come back on next to phone and the buttons on the steering wheel will begin to work. Begin the pair process type in pin and done} Hope this helps..this should work for all if not most mine is a BMW x5 .. Let me know
Old 11-19-2013, 01:18 PM
Leah Leah is offline
Mein Auto: X5
Following the advice from this thread I was able to pair my new iPhone 5s with my 2005 X5 (no nav). I just kept holding down the RT button until the iPhone saw the X5, entered the passkey, and finally connected. Thanks X3-terrestrial and madurodave!
