S52 Guys - Which Oils?
Which brand, type (dino or synth) and viscosity are you running in your crankcase, gearbox and diff?
TIA, Mark
WTB: Minty Seat Belt Receptacles - Front |
Do a search; this subject has been discussed to death
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
Jim Millet 2007 Imola Red Z4 M Coupe' Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates. |
My owner's manual suggests either synthetic or regular, and my mechanic suggests Castro 5w30, synthetic.
2000 M Roadster 1993 Miata 1999 Chevy Silverado 4x4 |
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx The BMW NA letter is very brand and weight specific regarding approved oils and they must be LL-01 rated. The only two other than the BMW High Performance SAE 5W-30 Synthetic Oil (BMW part number 07 51 0 017 866) that are widely available on the US market are: Castrol Syntec European Formula SAE 0W-30 (AutoZone) and Mobil 1 SAE 0W-40 (everywhere). The other two approved oils are very difficult to find in the US. The approved Pennzoil Platinum European Formula Ultra SAE 5W-30 is NOT the Pennzoil Platinum 5W-30 you commonly find on auto supply store shelves. The same applies to the approved Valvoline SynPower SAE 5W-30. The one that meets LL-01 is the Valvoline SynPower MST 5W-30 which also is not commonly found on auto supply store shelves.
The Oil page talks of two groups 1 - M vehicles equipped with S54, S62, S65 or S85 engines 2 - all other BMW Passenger vehicles and SAVs in the US market with gasoline engines Last edited by updmst; 08-15-2009 at 05:22 AM. Reason: clarification |
Your mechanic's suggestion is good.
![]() TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix |
Synthtic for sure. As for which kind.....you are going to open a can of worms on that one. Honestly there are many brands that will do just fine, Mobil 1, Castrol Syntec, Royal Purples, AMSoil, Red Line, etc....
The thing that really matters is that you change it at regular intervals, along with a quality filter. Bav Auto or ECS tuning will display oils for your car if you want some other ideas. I have been running Royal Purple 10w-40 with no issues. My Blackstone reports are good. 5w-30 or 10w-40 will be fine depending on your climate, I don't do a lot of winter driving with the car and it is pretty hot in OK most of the year, hence the higher viscosity.
99 Z3M Coupe 06 Z4M Roadster (1 of 1) 85 M635CSI (Euro) 03 530 5MT 97 M3 Coupe (Track) 10 Subaru Outback 3.6R Limited 08 Chevy 2500 Duramax 4WD LTZ |
Gearbox: Moved on from Redline MTL, using Royal Purple Synchromax...better. Diff: Amsoil Severe Gear 75/90
![]() Quote:
Some history is in order: I am in the process of swapping a '99 M Coupe driveline (S52, ZF 5-speed, 3.23 finned diff, as you are well aware, I am sure) into my '87 325is. My knowledge of the S5X is limited, so that's why I am here. Thank you for sharing your insight/experience ![]()
http://www.bimmerfest.com/forums/sho...&highlight=oil
yes we did beat this one to death a few times. for the S52 bmw or mobil1 0-40 were the most popular
2000 Imola Red M Coupe Dinan suspension, M rotors /Axxis pads Eurosport Cam Kit 1, touch lane change Zaino polish, Beach Sand Garys mirror adapter, S54 Oil Cooler seat tilt coupling nuts, spare tire "life's to short to drink cheap beer"
Anyone know where to get these "Euro Formulations" recommended in some of these posts?
Look up PENTOSIN oil made in the father land.
I think jmillet works for Castrol or something.
BMW "approved" oil is a bunch of BS. Any high level synthetic at the correct viscosity is fine. Remember, BMW is the same gang that tells you it's ok to go 15k miles on an oil change, and 100k on automatic transmission fluid. And before that, it was "lifetime" fill. Why would you believe them when they tell you what the "approved" oil is? While you're in warranty, use what they tell you to keep them from trying to find a way out of warranty work. Once it's out of warranty, ignore them like you should be ignoring most of their fluid recommendations. |
![]() See post #19 - I think we are on the same page. I sent an email to Mike Miller of Roundel Tech Talk fame, and he said that a good synthetic of the proper viscosity is more than adequate. For my drivetrain, he suggested: Crankcase: Redline 10W/40 Gearbox: Redline MTL Diff: Redline 75W/90 with friction modifiers ^^^^ this is what I am going with
And no I don't work for Castrol or anyone else for that matter
10 W 60 Synth. but its not cheap. $20 per litre here in Canada and my M Roadster takes about 6, in other words $140 per oil change (with filter) thats if I do it myself.
I run BMW 5W-30 in the engine.
I run BMW LTF2 in the tranny. I run Mobil 1 in the diff. I used to run Redline in the tranny and diff, but after seeing how it comes out after a short period of time, I no longer do. But I have a bunch of MTL, D4ATF and diff fluid I am willing to sell for a great price if someone likes the stuff.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
I will have to check, but several bottles.
Yeah, been busy with other pursuits.
#25
Sorry, I actually don't have any MTL. I have some D4ATF, and for some reason, about 8 quarts of RedLine Power Steering Fluid?????
![]() I do have a few cans of Super Blue I want to get rid of.
| Tags |
| diff, engine, gearbox, s52, viscosity |
