Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 08-30-2009, 02:21 PM
tock172 tock172 is offline
Mein Auto: 2004 330i
84 318i Not Running, Fuel Pump
Looking at picking up an 84 318i on the cheap locally. The owner says the fuel pump went, and it won't run anymore.
I am just looking for some general answers here, so I will make it quick. Does this sound normal for 200k? Or are there more major things wrong here that I should worry about?
Old 09-23-2009, 01:57 AM
elm3lem_youssef elm3lem_youssef is offline
Mein Auto: E30 Facelift
Check the fuel pump as owner said i had the same problem
Old 09-23-2009, 02:03 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
for some reason i found that a faulty sender unit to the gauge cluster was the cause of my fuel pump not working in my POS car, so have a look at that if you find your pump to be fine
