Old 09-30-2009, 05:07 PM
notcreative notcreative is offline
Mein Auto: 2006 X3 / 2009 G37
2006 X3 Exhaust Drone
Hi guys,
We purchased an 2006 X3 recently. It was not until after the pruchase did we notice an irritating drone that comes with the truck when cruising around 50-55 or when the RPM's are between 1800-2200. I've read this is common among the 2006's, but I have not found anything mentioning a fix, other than disconnecting the vacuum valve in the exhaust which most say makes it worse. Does anyone know of a more permanent solution? Will replacing the muffler fix the drone? Thanks...and awesome forum.
Old 09-30-2009, 06:31 PM
Mystic1's Avatar
Mystic1 Mystic1 is offline
Mein Auto: '11 328xi, '09 550i
Did you look to see if the exhaust valve mod has already been done? It's possible the original owner did it and it is still that way.
Old 09-30-2009, 06:34 PM
codog2 codog2 is offline
Mein Auto: 5
Is it a drone or more like a clatter? That's how mine got started - clatter at cruising speed and low idle, then it started making noise at cold start-up. Mine ended up being, like a lot of X3 owners, the hose to the muffler was slightly torn. the dealer fixed mine under warranty. If you are out of warranty check the hose for cracks
Old 09-30-2009, 06:58 PM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
I had a similar issue on my 2007 X3. I would hear a clatter at cold starts from the muffler. It was the flap/vacuum on the exhaust. Fixed under warranty.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 09-30-2009, 07:30 PM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is online now
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
I know exactly what you are talking about. It feels more when I disconnect the servo that keeps the valve closed, I like it for a while but I try to keep the revs up that point. Check if the valve closes when you start the car.
Old 10-01-2009, 05:33 PM
Thanks for the responses guys, I will check the valve to see is it is working. Its definetly a drone rather than a clatter. I dont believe there is anything wrong with exhaust as it is very quite at idle. Might just be something we have to deal with. Thanks again for the responses.
Old 10-01-2009, 08:40 PM
new2u new2u is offline
Mein Auto: 2006 X3 3.0i
My 06 had the almost same problem. Here's what my dealer did to repair it under warranty:
Cause: Exhaust Flap in Rear Muffler is making noise. Found a leak in the vacuum supply hose.
Correction: Replace vacuum hose. Road test, ok now.
After they replaced the vacuum hose, the exhaust drone noise at around 2000rpm near 80km/h(50 mph) is also gone. Hope this info is helpful.
