Old 10-17-2009, 06:17 PM
jieg jieg is offline
Ivan
Mein Auto: 525i 2003
twisted seat surprise, see images
as indicated in my other post, I took out my driver seat to fix the twist seat
I must admit that I spent a long time "fixing" the cable ends of the motor that control seat height (wrong motor, the little one) at least I did not cause any damage
Later I started working on the other motor, there has to be that one!! (large one)
ok, I disengaged the cable from the motor and pulled the inner cable outwards and found what is shown in the picture, the cable pulls all the way out!!!!. I did not try all the way but I am sure it would come out of the sheath.
The short cable (shown in the picture for comparison) belongs to the height controller, for which I cannot pull the inner cable outwards
Image Hosted by ImageShack.us
By jieg at 2009-10-17
is the problem on the other end of the cable?
By jieg, shot with KF750 at 2009-10-17
any one has experience working on the other extreme of the cable?
All DIY´s I read are related to the motor end of the cable
any help is needed and welcomed
thanks
IVan
---------------Ivan
Old 10-17-2009, 07:24 PM
hieuu hieuu is offline
Mein Auto: 03 540i
Pulling out cable is normal, the cable is square on both ends you can even flip flop the cable it does matter. The other end goes to the gear box and the cable fix doesn't always work if your gears are stripped, because like most other bmw parts they are made of low quality plastic.
Old 10-17-2009, 08:52 PM
Ivan
my son helped me a lot!
finally sorted out!
Seems that not all cases can be sorted with the seat inside the car, in this case it was indispensable to take the seat out of the car.
remove the cable, heat the metallic silver sheath to take it off, then cut some sheat as shown
heat the metallic sheath again to reinsert it in the plastic sheathed cable, which sould have a longer metallic end now.
reassemble carefully, as is tricky to hold the assembly back as originally shown in the upper picture
---------------Ivan
Old 10-17-2009, 10:10 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
On mine, I didn't unscrew anything. Once I confirmed which cable had the problem, I just used a cigarette lighter to heat the ferrule on the motor end of the cable, jerked the cable out, cut about 3/8 inch off the black sheath, heated the ferrule again and shoved it back in. Fixed, just that quick.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 10-18-2009, 06:22 AM
anton-sa anton-sa is offline
Mein Auto: Bmw e39 525i 2001
on my 2001 525i, i got sports seats, manual ones. im actually glad they manual. less problems...
on my previous ride i had a e30 325i, which i fitted front electric sports seats from a 1997 M3.
i eventually had one of the gears stripped, was finnicky to replace...eventually replaced it though.. when i sold the car though, the driver side seat gear also had a problem (the dredded e36 electric seat recline gear)
i had no idea e39 electric seats also gave issues... again..hehe im glad ive got sports seats of the manual variety (has up/down,tilt,recline,forward/back)
Old 10-18-2009, 07:21 AM
andyffer andyffer is offline
WTB - your E39 M5
Send a message via AIM to andyffer
Mein Auto: 02 530i, 09 335d
lighter weight so you have that performance advantage. BMW sneakily put that kind of stuff in the 525.. sleeper
With 1 person driving the car I could live with the manual seats but if you have other drivers then its a real pain.
Unencumbered by the thought process
If you're not a ******* at twenty you have no heart, if you're not a ************ at forty you have no brain.
Old 10-18-2009, 01:20 PM
Ivan
i personally do not like all the electric options in the seat, I would prefer manual movements, especially on the back rest
---------------Ivan
Old 06-14-2010, 02:15 PM
540 bimm 540 bimm is offline
Mein Auto: 1994 BMw 540i
can you help me on my case sir's.. i checked on the cables already and its still good.. the motor is working but all of the right side of the driver seat is not working.. it seems like my seat just had a stroke.. LOL.. can someone help me pls.. thanks!!
Old 06-14-2010, 02:52 PM
cn90 cn90 is offline
LOL,
Leave the seat in one place, stop adjusting it and you will never have this problem....hehe!
Anyway, good DIY!!!
Old 04-16-2011, 07:42 PM
Vegas Jade Vegas Jade is offline
Mein Auto: BMW 5 series 3003
Great thread
Im new to the forums and finally got enuf money to buy a used 2003 5 series 525i
Got problems with the seat... it works both move but is twisted
Head rest doesnt go up and down.
Leg support that goes out of the seat is stuck in the extended position i think its a switch problem it doesnt make a clicking sound when i try to retract it... like that of when you try to extend it.
Any help for a new enthusiast.
Old 04-16-2011, 07:45 PM
Trini23007 Trini23007 is offline
Mein Auto: 2003 525i sport
messing with the seat scares me dude, so many parts and wires...
Old 04-17-2011, 07:29 AM
For the record, if someone comes here for twisted-seat DIYs, I'll add this to the existing list of twisted-seat DIYs, each of which has helpful advice.
- How to understand BMW seat cables that fall out causing twisted seats (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) & watching out for the accidental airbag light (1) (2) (3) (4) (5) & warnings about the seat twist DIY (1) (2) (3)
Old 01-04-2013, 06:15 PM
This thread just came to my attention today - it has some really nice pictures of seat twist repairs:
> E39 (1997 - 2003) > Another seat twist thread
Old 10-14-2013, 09:26 PM
This thread was updated nicely with a new seat twist lessons learned post:
> E39 (1997 - 2003) > Seat Twist Repair E39 2002 530i - DIY
Originally Posted by Gian View Post
I just finished this repair myself and, let me start by saying, it was a major pain. The #1 thing you will need is patience. If you don't have it, forget it. My passenger side seat had a problem when trying to recline and when trying to elevate. Therefore, both motors were affected. I decided to do it the "harder way", by removing both of the motors and cutting the sheath back on ALL FOUR connections. (IMO, You do not want to go back in there! Trust me. Do them all now! Even the sides that work! Eventually they may fail.)
I used this DIY guide
bellsouthpwp.net/m/i/miales/seatcablesfix.htm
Many thanks to the poster of this guide
Tools that I used...
Needle nose pliers
Socket wrench w/T-50 bit
Box cutter/razor blade
Reversible Flat 8mm built in socket wrench (A must have)
Bic Lighter
LED flash light (not pictured)
After careful consideration, I decided not to remove the seat from the car or disconnect the power. I ended up placing the twisted seat up against the back seat to get a good look underneath. I then placed a board underneath the twisted seat to brace it so that it wouldn't fall back forward.
Tips
-The smaller your hands are the better. It is really tight under there. Also you might want to wear some sort of gloves. There is a lot of rough metal parts and you can get your hands cut up easily. (I did, live and learn)
-There was a metal bracket that I had to bend in order to get to one or two of the bolts. It had some plastic housing attached to it with wires. I had to remove the plastic housing so that I could bend the metal. You'll know it when you see it. I just bent it back after I was finished.
-Take note of the location of the Bosch label on the motor so you can put it back in correctly.
-If you remove both motors at the same time, make sure you mark which cords go to each motor.
-Before finishing, make sure you bring both sides of the seat up in order to even them out. Once you put the cords back in you will not be able to do it. (After cutting the sheath and replacing the connector, put one cord in at a time and bring each side all the way up. This will even out both sides of the seat)
-Make sure you apply enough heat to the metal connector on each cord. It must be hot enough so that it can be put all the way back onto the sheath. That connector has teeth that cut into the sheath in order to stay in place. If you don't get it back on fully, then shortening the sheath did nothing. The cord will not stick out enough to engage the motor.
-One thing I wish that I had was a magnet of some kind. Putting the screws back in would have been so much easier.
That's all for now. I will add other tips if I can remember them.
See also:
- How to identify seat twist & fix twisted seats (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) & BMW_E34_seat_twist_repair_diy.pdf
Old 06-01-2014, 05:35 PM
Yet another twisted seat thread today ...
> E39 (1997 - 2003) > Twisted Seat For Me Too
Old 02-23-2015, 05:33 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
No you dont.. first thing first take the seat out..
and if the seat isnt going back in that same day...
Find a milk crate
15486372<-----
Old 02-23-2015, 09:34 PM
jeffmgr jeffmgr is offline
Mein Auto: 2002 525i
ha, do they deliver milk anymore!
Should I tell the indy mechanic not do the repair? Only my wife can use the seat as she's short and moving the seat back only makes the twisting worse, so I'm unable to drive the car.
On my 2002 525i, the same mechanic was able to just do the usual cut the cable and re-insert into the motor...fixed it for $200, but he says this seat is worse.
Any suggestions?
Old 02-24-2015, 06:44 AM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
Any suggestions?
I have done this repair several times. Seat in, seat out, just removed 1/4" outer sheath from middle of cable not disconnecting either end. I don't see this mentioned, but on some broken seat functions, you can loosen seat rear bolts, remove two front seat bolts and tip seat backwards allowing access. Find where seat is level, even, whatever. Leave it there. Find bad cable and melt away about 1/4" anywhere in cable allowing center spline room to extend back into motor or gearbox. You can then use a cable tie that will kinda force cable sheath back together, tape, and then try. Center cable really *wants* to engage in both ends but the stretching outer sheath pulls one end of cable back and out of its mate. Takes very little to make cable *jump* back into engaging at both ends again. Using the motor makes the cable actually drive itself lengthwise. oh, forgot reason for posting-old age. Your indy is stroking you as he doesn't know what is wrong, but for your $1100 dollars he feels safe he can fix any issue or take to another shop, get fixed for him, and return car to you fixed and he is richer. Motor loose??!! Hardly. Save your $$$#
Old 02-24-2015, 06:15 AM
Burning2nd's Avatar
Under the lift arms
look for a new seat...
Or remove the seat find the issue and repair it,
either way it starts out with remove the seat,
unless your like one of those freaky people @ the shop that can stay in a car all hunched over for like 6 hrs @ a time
15486372<-----
