Old 12-26-2009, 06:06 PM
phil0618 phil0618 is offline
Mein Auto: BMW 528i
Which auto transmission to I have (ZF vs GM)?
Hi,
I've been all over the forums looking at various items related to changing transmission fluids.
I just want to confirm the transmission on my car without having to jack up the car.
My car is a 2003 e46
The plate on the door says 06/03 (June, 2003)
The last part of the VIN reads KP81689
The sticker on the underside of the pan is green, but I can't read the markings
(i can see the sticker is green by placing a mirror under the car)
It's a California car and so I believe that I have the M56 SULEV engine (oil fill in front of engine)
The e46 wiki states that as of March 2003 all transmissions are GM.
However, I also used a VIN decoder I found online and it said that I had the ZF transmission.
Is it possible to know for sure just using the above data which transmission I have?
Best,
Phil
Old 12-26-2009, 07:58 PM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
King of Drone
Mein Auto: Bavarian Bombshell
It's a GM, you have a 2003 and 1/2 model like I used to and its sort of got a weird mixture of stuff. I did the same thing you did and bought the filter for a ZF transmission, didn't figure out it was a GM until the tranny was drained. Turned out to be quite a long afternoon chasing down the right filter.
EDIT: I'm pretty sure I edited the wiki when i figured that out.
Old 12-26-2009, 08:26 PM
Melquin Melquin is offline
Mein Auto: 2005 330i
AFIK all the M56 vehicles had the ZF transmissions. (see attached PDF). I have seen some of the ZF blue stickers that have oxidized and turned sort of a bright metallic green color over time. (as opposed to the more flat-puke green colored GM sticker). Best to check the recommended fluid part number listed on the label to verify which you have.
edit: PDF was too large so just took a snapshot of the first page
Old 12-26-2009, 09:08 PM
SlimKlim's Avatar
King of Drone
Originally Posted by Melquin View Post
AFIK all the M56 vehicles had the ZF transmissions. (see attached PDF). I have seen some of the ZF blue stickers that have oxidized and turned sort of a bright metallic green color over time. (as opposed to the more flat-puke green colored GM sticker). Best to check the recommended fluid part number to verify which you have.
Ohh, didnt know that, sorry about the misinformation. I wonder why they would bother to fit two different trannies for the different emission engines.
Old 12-26-2009, 09:43 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
I just decoded your VIN. Your tranny is A5S325Z which is ZF tranny. It requires ESSO ATF LT 71141 fluid.
Old 12-27-2009, 06:12 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2004 ZHP Sedan
Count the pan bolts. The GM trannies have 22 bolts, the ZF have 14.
Check out my BMWBLOG!
Old 12-06-2012, 10:21 PM
STREETFIGHTER50 STREETFIGHTER50 is offline
Mein Auto: '03 330i
I'm just peeking under the car & can't really see or read anything off of the sticker. I'd have to lift it up this weekend to tell I guess. My car's VIN # tag reads 08/03. So is it the GM tranny for sure?
Old 12-07-2012, 01:45 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Read Smolck`s Post# 6....it doesn`t get much more definitive than THAT !
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
