Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 01-07-2010, 01:47 PM
the_jeep_now the_jeep_now is offline
Mein Auto: '99 BMW 740IL
Which oil to use?
I've had my 7 for 5 years to be soon and have been using either BMW oil or lately Mobil1 0w-40. I know that BMW recommend Long Life oils only which are very limited to choose from. Everything I've used poors like water and I'm concerned about its ability to protect the engine especially having almost 130k miles on it. Did anybody use anything higher than 0w or 5w? Does it make any difference on the car's performance, funcionality?
Old 01-07-2010, 08:30 PM
tGunter tGunter is offline
Mein Auto: na
Use the weight of oil tht bmw says to use.
Seriously.
If BMW says 5w-30, USE IT.
Millions of dollars are spend finding out what fluids work best with the vehicle. Don't mess with it.
Old 01-09-2010, 08:49 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
its usually hot as hell here where i live. personally i use 10W30 with almost 115000 miles. i also like to let the car idle after a cold start to warm the fluids. seems to work for me. if you live in a colder climate, i'd go with the 5W30, maybe a 5W40 with the higher mileage. the "W" is the winter, or cold weight if you were wondering. particularly how it pours in colder temps, this is what multivisosity oils have been enginered to do to meet the tolerance specifications in modern vehicles engines.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 01-11-2010, 11:53 AM
stlbmw stlbmw is offline
stlbmw
Mein Auto: 2002 745Li/1999 528i
I have a 02 745Li. Aside from BMW oil, BMW has approved Castrol Syntec 5W-30 to be used. Have been using it with no problems since 02
Just an FYI. From an engineerinng stand point of view. Remember, these engines are overhead cam. The engineers has formulated the
correct viscosity in light of the fact the oil must get to the top of the motor as quick as possible. This is especially important in getting the lubrication
up to where the cams are. If the oil is too thick, it takes too long to be pumped up to the cams(very oil hungry). My engineering instructors used this
analogy....The oil must be pushed up to the overhead cams. This 10W or 5W is like the difference of pushing a 5 pound weight over your head vs a 10
pound weight over your head. And with overhead cams, you don't want to go too thick. Its 5W for that reason. Too thick and it will take too long to
lube the upper end of the motor. The days of overhead valve motors are coming to an end.
stlbmw
2002 745Li
1999 528i
Old 01-11-2010, 01:24 PM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
I am using castrol edge extended life 5w30 and have no problem change once a year or every 15k as they recomend
Old 01-12-2010, 01:25 PM
i personally use the 10W30 Castrol Syntec because the vanos oil passages that oporate the cams varriable timing were making some noise. no more noise, its been working well for me now. i also run the car a bit vigorously, its not going to hurt it.
*Der E38*
manufactured: 7/01
Old 01-12-2010, 08:22 PM
Oboyco Oboyco is offline
Mein Auto: 1998 740i
When I called BMW NA they recommended 5w30 9n Valvoline, Castrol or Mobile one fully synthetic for my area, Colorado mountains
Old 01-27-2010, 01:28 PM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
Mein Auto: 335i
i use Mobil only for all my oil
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
