Old 01-24-2010, 06:53 PM
edbmw745 edbmw745 is offline
Mein Auto: 2002 bmw 745i
745i navigation, radio, and sound system problem
i own a 2002 bmw 745i , the navigation system , radio system, are not working anymore, the fuses are all good, i was wondering if any one out their knows what the problem could be? please let me know thank you
Old 01-24-2010, 09:20 PM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
One of the items on the MOST bus ring has tanked or you have an issue with one of the fiberoptic cables. MOST = Media Oriented Systems Transport. A MOST bus jumper / FOC coupler (fiber optic couple) - part: MOST 61 13 6 917 541 - can be used to eliminate / bypass specific devices on the network until the offender is found. Before that, try pulling out the FOC in the the glove compartment fuse box for a few seconds to give a simple MOST bus reset a shot.
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
Old 01-25-2010, 10:16 PM
thank you, im going to check it out and see what happens
Old 03-24-2010, 01:57 PM
Cehrlichman Cehrlichman is offline
Mein Auto: BMW 745i
I as well have a 2002 BMW 745i and am having the same issue. I took the MODE BUS out for a few min and plugged back in to see if it might reset the radio or navagation, nothing. I also went to BMW and asked if I should replace the MODE BUS. One of the techs I spoke with said he didn't recommend that because he didn't think that would be the cause. So I was wondering if there might be something else I can try?
*Car Problems* One night I went to start my car and the front nav screen flickered a bit. As it turned on it looked as if there was no problems. I go to accept the agreement and realize that after doing so both CD options (CD Changer/Single CD) are grayed out as well as the Radio. I scroll down to click, nothing, no sound of any sort (execpt a little crackle out of the front speakers, that happened every now and then previously). I scroll to the navigation, again nothing, just a blank screen where the nav would normally appear. Come to find out most all of the control functions dont work, with exception of the climate control. You can navigate through the menu just fine but when it comes to working nothing happens.
I've tried reseting the MOST BUS by pulling it out and plugging back in. I've tried cutting power to the entire and let it drain a bit (unpluged the battery). Not really to sure what to do from here. Any suggestions? Thank you!!
Old 08-18-2010, 11:47 AM
Has8223 Has8223 is offline
Mein Auto: 745i
i have the same problem... aircon works but all other functions are dead. Did you manage to fix problem? Please help... beautiful car but no fun driving without music... Just had the windows tinted and problem started after that.
Old 06-26-2011, 11:30 AM
Cubfan Cubfan is offline
Mein Auto: 745i
I've tried reseting the MOST BUS by pulling it out and plugging back in. I've tried cutting power to the entire and let it drain a bit (unpluged the battery). Not really to sure what to do from here. Any suggestions? Thank you!![/QUOTE]
This is located in glove compartment correct? I'm I pulling this with a fuse puller?
Old 03-24-2010, 02:28 PM
joekahng joekahng is offline
Mein Auto: 03' 745i & 06' Cayenne S
any software updates lately? any new software updates on 02~03 models have triggered failure in certain control modules.
Old 03-24-2010, 02:58 PM
Mein Auto: BMW 745i
Not that I know of. I only bought the car last year and didn't hear about any update from previous owner. Plus it was working great for the first 6 months. Thanks!
Old 04-09-2010, 12:05 PM
allaboutdaz allaboutdaz is offline
Send a message via AIM to allaboutdaz Send a message via Yahoo to allaboutdaz
Mein Auto: 745
any updates on this ?
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
Old 04-09-2010, 04:17 PM
Mein Auto: BMW 745i
Not yet. Any input would be great. Thanks!
Old 04-09-2010, 05:55 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Get hold of another MOST BUS LOOP Connector (same as the one in the glove box) then bypass each Control Unit in the trunk/boot... one at a time.
Hopefully when you bypass the faulty control unit other functions will appear on the IDrive indicating which unit is having the problem.
My BMW ACS7
Old 05-20-2010, 10:36 AM
shane2010 shane2010 is offline
Mein Auto: 7451
i am havin same problem please help me ........
Old 04-12-2010, 07:44 AM
Mein Auto: BMW 745i
Could you please tell me how I would go about bypassing each of the Control Units? Where exactly might they be located? I went down to BMW and asked just to borrow a MOST BUS LOOP and of course I already knew the answer before I even asked. It was "No. You must buy it.". And I of coursed ask if I could return it if it didn't work. Same answer "No". Now I have no problem going out and actually spending the $40 if thats what you think might work. What might you recommend? Again thanks for the reply.
Old 01-26-2012, 01:03 PM
bmw745li01 bmw745li01 is offline
Mein Auto:
Did you ever receive a response to your question?
Old 06-07-2010, 06:21 PM
nvafamilyman nvafamilyman is offline
Mein Auto: 2002 745i
Mine started this today as well, can some one explain the trouble shooting process. please advise
Old 06-08-2010, 09:35 PM
jide_99 jide_99 is offline
Mein Auto: 04-745li on 24"rims "BOSS
nav not wkin
its ur radio when mine acted up, nav wasnt workin, no sound from radio, took it to a side audio and they send it off and rebuild my radio, often moisture gets in them and causes it to shut down.
Old 06-09-2010, 07:21 AM
radio probs
Thx for replying, where is the radio board located? I had my windows tinted the same day wondering if that can be the cause? Do you mind telling me what they charged to have it sent out and repaired?
Old 07-12-2010, 06:39 PM
jeff67210 jeff67210 is offline
Mein Auto: 2005 BMW 745Li
Can you tell me where they send your radio for rebuild? Appreciate it if you could forward their contact number so I can ask them for estimate. Thanks so much.
Old 06-15-2010, 10:21 PM
jssmi765 jssmi765 is offline
Jssmi765
If you read most of the threads here where people are having similar problems it is almost always the ASK (Audio Systems Control) unit. That is the CD player in your dash. Because everything electronic runs on the MOST BUS system if one unit goes out it appears that everything tanks. So the good news is it's probably just one component. The bad news is that the factory part is $1279 here is a link where you can get a new OEM part http://www.bmwpartscounter.com/produ...126977634.html. If you search long and hard on the internet - particularly on Ebay, you can find it cheaper used. I have found it as low as $350.
Old 06-16-2010, 08:21 AM
My problem ended up being the voice input control module, part of the optical loop for the audio system. If any of the devices on the loop go down the whole system does not work. The bad news is the part cost almost $900.
Old 06-16-2010, 11:26 AM
DrewBimmerGA DrewBimmerGA is offline
I've been told its my voice input control module as well. I have a 2002 and it doesn't have the tray in the back to prevent moisture from getting to the compenents from the trunk hinge. They (BMW) say its water damage. I'm going to bypass it as soon as my MOST Bus jumper arrives (ordered it yesterday) and I'm taking the voice input control module to Electronic Masters (Duluth, GA) to see if they can fix it before I buy another one. They will look at it for free and they specialize in repairing car electronics.
Old 06-16-2010, 12:08 PM
let me know how it goes, I was impatient and ordered a new one Where did you order your MOST BUS jumper? what do those run? I am told the cd changer usually goes next.
Old 06-16-2010, 12:14 PM
http://www.bmwpartscounter.com/produ...rm=61136917541
http://www.bmwpartscounter.com/produ...rm=61136917978
The first one is the jumper and the second one is the connector. I got the information off of a posting on here. I'm taking it on Friday so I'll post what happens after that.
Old 06-23-2010, 01:39 PM
Johnny Big Johnny Big is offline
Mein Auto: 02 745i
You are right. Mine had the same problem and BMW by passed the voice control unit for $300 and now the radio and navigation works. It would have costed $2000 if the whole thing was replaced and i figured i could do without talking to the car.
Old 06-22-2010, 07:38 PM
Jerry 745Li Jerry 745Li is offline
Mein Auto: 03' 745Li
Is the voice input control unit located in the trunk?
I don't have all the answers, but I can do one helluva Google search!
