Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 02-21-2010, 10:35 AM
jmlaudio jmlaudio is offline
Mein Auto: Many Vehicles
2006 M5 the ultimate radar laser system
Thank for taking a look. All feedback is appreciated.
The vehicle itself
The V10 under the hood along with the wiring to the right
Dual laser shifters in front
Front Radar Sensor
Rear laser shifter
Bi-color led mounted into the factory guage cluster
Warning speaker machined and plastic welded into the lower factory panel
USB red light and speed camera database uploading port
Main controller machined into aluminum stock and plastic welded into place to hold the controller in former ashtrey
Main display plasic welded behind factory casing in front of navigation screen
Full view layout of controller, display, and bi-color led
Satin black inserts added to sides and front grill
Old 02-21-2010, 11:26 AM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
So when you get a "hit" does it upload your GPS location to the memory stick that's in your USB port. That would make for a very convenient way of adding new POIs for speed traps.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 03-13-2010, 11:05 PM
Tari's Avatar
Tari Tari is offline
Send a message via AIM to Tari
Mein Auto: 2001 330i
^that would be very useful
** pic was a little disturbing for a signature - Tim330i ** ouch -Tari-
Originally Posted by sonspot View Post
to each his own..
Old 03-18-2010, 09:29 PM
vishaalpandya vishaalpandya is offline
Miss the 6er..Love the M5
Send a message via AIM to vishaalpandya
Mein Auto: E60 M5
ive been thinking about getting this radar... can you let us know how it does on the street?
thanks!
V
ps-great job buddy! very clean!
Old 07-29-2010, 05:24 PM
mrscott mrscott is offline
MYO8M5
Mein Auto: 2008 M5
Nice Work but has it saved you AXX ?
How many times has it saved you butt?
I almost bought the Escort system when I got my 9500IX but went for the Blinder M47 Extreme instead. It only ever went off once when installed on my M35. Now that I have a new M5, I am thinking about installing it but will let a professional do this job.
Old 09-02-2010, 07:40 PM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2014 M5
The escort radar is excellent, but the escort jammer is worthless.
I tested my system with a couple of friends who between them own 5 lidar guns. After realizing that the escort won't cut it, I replaced the jammer portion of the 9500ci with Laser Interceptor Quads.
I tested again, and now it was rock solid on front (no reads at all at any distance) but I was getting punch through on the back. I then did some adjusting and aligning to get them level and straight, and now they work perfectly on both sides.
The Laser Interceptor shares the escort speaker and bi-colour led, and has its own voice module, so the alerts can be heard as announcements, e.g. "Ka band detected", or "Front Jamming sequence initiated, Kustom Prolaser 3, please slow down"
The Laser Interceptor is impenetrable - truly the best - just like your M5s!
Radar antenna (center of lower air dam) and front laser jammers (corners of lower air dam)
Two rear laser jammers mounted at the top corners of the license plate frame.
Display in mirror to indicate warnings, signal strength and programming menus
Green LED above the speedometer (it is dead centered but camera angle makes it look off). This indicates the system is on. It flashes red when laser or radar is detected. Provides line of sight warning so you don't need to look in mirror. Great when combined with audio warnings and announcements.
Coin compartment contains the controller (left controller for Passport system, right controller for Laser Interceptor system)
Coin compartment folds away as normal
There is also a retractable USB cable in the footwell which I can use to update the system with new speedtraps every Monday.
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 09-17-2010, 08:18 AM
silverbimmer3's Avatar
silverbimmer3 silverbimmer3 is offline
Mein Auto: '05 M3 ZCP; '06 530 XIT
These look expensive... people...
but it must feel good to see them dumb popo getting screwed...
Old 10-22-2010, 10:30 AM
zhan zhan is offline
Mein Auto: Dinan S M3, Evolve M5, X3
cant they still pull you over and claimed that they paced you?
its your word against their word so you always lose anyway...
