Old 03-08-2010, 05:15 PM
rvt1975 rvt1975 is offline
Mein Auto: Nissan
2011 BMW X5 35i ... Gas Mileage?
I am curious if anyone knows what the expected gas mileage will be for the new 2011 X5 35i. I realize the engine will be an 8-speed, 300hp, V6 turbo ... however, trying to understand what to expect on mpg. I am very close to ordering a 35d, mainly for the gas mileage and additional torque. However, if the new 35i's gas mileage is close enough to the 35d, I will most likely go with it to due to the availability of gas vs. diesel.
Thank you in advance for your help!
Old 03-09-2010, 04:00 AM
XXX555 XXX555 is offline
Mein Auto: 2012 M3 cab
Its an inline 6 not V6, fyi. I gestimate the gasoline 35i at 17/24. There would be no diesel (in the USA) if the mileage was close enough...
Old 03-09-2010, 09:21 AM
Mein Auto: Nissan
Thank you for your feedback. It looks like you drive a 35d ... if so, what kind of mileage have you experienced?
Old 03-09-2010, 10:23 AM
NewGTGuy NewGTGuy is offline
Mein Auto: 2010 BMW X5 35d
Just wanted to chime in with my 2 cents.
I've got 1500 miles on my 35d and I get 24 mixed and 29-30 highway.
2010 X5 35d, Black Sapphire / Sand Beige Nevada / Premium / Cold Weather / Tech / Rear Climate / Premium Sound / Sport Activity / Roof Rails / Running boards / iPhone Snap-in Adaptor / HUD / Comfort Access / iPod and USB / Space-Saver Spare
Old 03-09-2010, 11:35 AM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Somewhat similar experience. I get about 23-24 mixed, and 27-29 with Interstate cruising at 70.
But this is with Winter diesel, I expect some improvement when Summer diesel appears in my area.
Old 03-24-2010, 06:44 PM
rehostman rehostman is offline
Mein Auto: 2007 X5 4.8i, 2009 E90 M3
I have a 4.8i and reading these mpg numbers just make me cry.
Patrice
2009 E90 M3 Melbourne Red on Black Leather
2007 X5 4.8i Monaco Blue on Saddle Brown
Old 03-25-2010, 06:09 AM
santo santo is offline
Mein Auto: 2011 X5 35d
I actually did this calculation to determine which was better for fuel economy. Here are the numbers that I could calculate. If anyone sees any discrepancies, please let me know.
2011 X5 35d (1)2011 X5 35i (2)
L/100kmMPG (*)L/100kmMPG (*)
City10.72213.217.8
Hwy7.531.48.328.3
Combined9.325.310.123.3
EPA Cost per year (3)$1,741.11$2,141.09
CDN Cost per year (4)$2,119.30$3,008.20
Distance per tank568 miles / 914 km523 miles / 842 km
Notes on numbers:
(*) The MPG numbers are converted from European L/100km to US MPG. I couldn't get the 35d numbers to match the 19/26 that the EPA suggests for the 2010 35d and since I couldn't find EPA numbers for 2011, I converted from L/100kms that could be found.
(1) From specifications at the http://www.bmw.ca website. In the Canadian 2011 X5 press release, the highway fuel economy was mentioned as the same as the 2010 so I am assuming the same numbers.
(2) From Specifications of the new BMW X5, 04/2010 which are European specs but are the the same as Canada.
(3) Based on EPA's Cost/Year formula of 45% Hwy/55% City for 15,000 miles per year where gas is $3.05 per gallon and diesel is $2.95 per gallon. DEF NOT included.
(4) For comparison, sort of based on EPA's Cost/Year formula of 45% Hwy/55% City for 15,000 miles per year where premium gas today is $1.132 per litre and diesel today is $0.949 per litre in Toronto, Ontario. DEF NOT included.
Old 03-25-2010, 07:36 AM
barbja barbja is offline
Mein Auto: 2015 X6 3.5
You think that the 2011 35i numbers are going to be that markedly different from the 2010 30i numbers? The 2010 numbers are 15/21/18 not 17/28/23. I have a 2003 X5 which has the same EPA numbers, and I routinely get 14 in town and 20-23 on the highway, so those numbers are probably spot-on. I know you converted, but that's way off -- 5mpg is 27%. The 19/26/22 to 22/31/25 is still off, but only by 13%. The 2011 for the 35d should be exactly the same for the 2010 since the car is basically unchanged.
For gallons, I think you should just stick in the US numbers instead of converting.
Can you add a column for 'km/miles per tank'? For me, its not so much about saving money on the fuel ($400/yr? eh), but how much farther I can go on a tank of gas. Give me 585 miles baby!
Old 03-25-2010, 09:33 AM
My 3000+ miles 2010 X5d is 'stuck' on 22.4mpg, 95% city. That is about 1mpg better than my 335i auto doing the same style driving.
Old 03-25-2010, 10:38 AM
I didn't come up with numbers. They have been posted in the technical specifications document noted above in the notes. I would believe that with a new engine and transmission that you would get better fuel economy.
They are the same. These 2010 numbers came from the Canadian BMW site. I don't have direct European numbers because the 30d and 40d engine output is different. The Canadian output is the same.
I would be happy to stick to US numbers but as of this writing, I haven't found any that could be used in direct comparison for 2011. These do directly convert but I'm a little stunned as to why the EPA numbers and the converted numbers don't line up a little more closely. It must be the way the testing is done. These do look like optimistic numbers where the EPA are a little on the low side.
Will do.
Old 03-25-2010, 11:44 AM
jaaX3's Avatar
jaaX3 jaaX3 is offline
Yes, please!
Mein Auto: 318ti Clubsport
Yes! Absolutely! It's a completely different engine!
Old 04-01-2010, 05:18 AM
Update: Here are new results from US EPA posted results:
2011 X5 35d2011 X5 35i
L/100km (*)MPGL/100km (*)MPG
City12.4
19
13.8
17
Hwy9
26
9.4
25
Combined10.7
22
11.8
20
EPA Cost per year (1)
Total fuel in gallons
$2,046.74
693.83
$2,303.65
755.29
CDN Cost per year (2)
Total fuel in Liters
$2,492.40
2626.4
$3,236.50
2859.1
Distance
per tank
493 miles / 793.4 km
449 miles / 722.6 km
Notes on numbers:
The 2011 X5 SAV Technical document where the EPA numbers are published is attached. Also included are X5 50i EPA numbers
(*) The L/100km numbers are converted from US EPA numbers.
(1) Based on EPA's Cost/Year formula of 45% Hwy/55% City for 15,000 miles per year where gas is $3.05 per gallon and diesel is $2.95 per gallon. DEF NOT included.
(2) For comparison, sort of based on EPA's Cost/Year formula of 45% Hwy/55% City for 15,000 miles per year where premium gas today is $1.132 per litre and diesel today is $0.949 per litre in Toronto, Ontario. DEF NOT included.
File Type: pdf 2011_X5_SAV_Technical_Data_Apr2010-1.pdf (47.0 KB, 668 views)
Old 04-01-2010, 07:04 AM
When did this data come out? Are these the 'real' EPA numbers? If these are the EPA numbers, does that mean that they are releasing the 2011 vehicles (or really really close to releasing)??!! (They weren't giving delivery dates, or releasing any already-built 2011 X5s because they didn't have EPA approval yet...)
Oh -- heh -- I can see 3-1-2010 at the top of the page (everything is so tiny!) So these were preliminary numbers since, as of at least last Friday, they still didn't have official numbers.
Old 03-25-2010, 09:32 AM
zibawala zibawala is offline
Mein Auto: 2005 x5 4.4, 2010 M3 conv
my 05 x5 4.4 gives around $15 average, mostly town, may be 2/3 town, 1/3 freeway.
If I can get combined 18-20mpg, i'll be glad!
Old 04-01-2010, 08:07 AM
rcf8000 rcf8000 is offline
Mein Auto: RX350
What is this, an April fool's joke? I seriously doubt that the 35i gets 25 mpg highway.
Old 04-01-2010, 08:43 AM
Did you also notice that the 0-60 time for the 35i is better than the 35d? 6.4 vs 6.9. The 30i was 7.8. The torque difference is still astronomical, but the 35i is by no means punky. And then there's the 8-speed vs the 6-speed transmission. Boy I wish they had updated the D at the same time as the other two.
Old 04-01-2010, 11:03 AM
I did occur to me that someone would think this was a prank but that just goes to show how impressive these numbers are. These are REAL. You can access them from BMWUSANews.com in the Press Kit that was probably for the New York International Auto Show at this link. It's on the colored bar on the right under "Press Kit Contents".
Originally Posted by XXX555 View Post
If there is only a 2mpg penality average for getting the X35i with a half second better performance improvement over the X35d, then I'd be buying the X35i.
This is exactly what I'm seriously considering since the trade-offs in going diesel (filling issues, froze DEF, etc) could be outweighed by only a slightly higher operating cost. In Toronto, it's a little more difficult to justify since diesel is cheaper that premium gas by $0.15 to $0.25 per *litre*. What makes me wonder is why the USA EPA numbers are so far off of the Canadian/EU numbers. Is the EPA testing procedures biased towards gas?
Old 04-01-2010, 11:22 AM
Well, they are real in the sense that they are the results of the EPA testing. What the comparison will be in real life remains to be seen, e.g., the benefits of that extra speed in the transmission might account for some of the increase and might also be tailored to get maximum results on the EPA test cycle...
Old 04-01-2010, 02:34 PM
boatpi boatpi is offline
Mein Auto: 530
One thing to consider is the $4,550 ECO credit on the diesel, and as my experience shows gas engines obtain poor fuel economy in very cold conditions and very hot conditions.
Old 04-01-2010, 07:25 PM
True enough; however, my X35d mpg also declines noticeably in cold weather as well.
Old 05-03-2010, 03:57 PM
twhit1 twhit1 is offline
Mein Auto: 2014 328d SportWagon
The EPA underestimates diesel efficiency in its tests. Real world results of diesel engines are materially higher than the EPA sticker numbers. So the 2mpg difference isn't a real. I routinely get 23-24mpg in city driving for 35d. On highway, always +30mpg.
Old 05-03-2010, 10:20 PM
Just about the same. I get 22 city and 29 hwy.
Old 04-01-2010, 08:54 AM
Route 66's Avatar
Route 66 Route 66 is offline
Mein Auto: 2001 740i
I wish my wife would be willing to trade off her Sequioa. 22.5 would be welcome.
Old 04-01-2010, 10:13 AM
Hard to believe BMW would even market the diesel to the states for 2mpg....
Old 04-01-2010, 05:58 PM
SoCalCFP SoCalCFP is offline
Mein Auto: 09 Porsche 997TT
and the $1,800 tax credit, does the 35i use regular or supreme?
gas mileage 35i x5 mpg
