Old 05-01-2010, 06:58 AM
mtyaker mtyaker is offline
Mein Auto: 2000 BMW Z3 2.8
Question Z3 Water pump failure-Fact or Fiction
All
I am new to Z3's and the forum. I have 62K on my 2000 2.8 Z3 and all the threads about catastrophic water pump failure have me very nervous. I talked with the BMW service tech about proactive replacement of the pump et al and he said there is no need until it shows signs of failure. Fan wobble, water leaking, noise ect. So my questions are: Are you on your on your original pump, if so, how many miles and what year is your car. If you are not, at what mileage did it fail?
Old 05-01-2010, 08:21 AM
wired wired is offline
Mein Auto: Z3 2.3 Roadster
It's really up to you, if you want to spend the money and have peace of mind then just go for it man. There are guys on this board that have pumps with over 90k on them and they will just change them when they see failure signs. If thats in the back of your mind so much and you want to replace it just do it. That's my opinion.
Check this out, my mechanic told me last week not to worry till i see signs... like you I have concerns about my 2000 Z3 2.3 but he said relax and don't stress. My car has little over 35k on it so I figure I'm good for a very long time but i will surely keep an eye out for signs of failure.
Old 05-01-2010, 11:46 AM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
Its not fiction. My Z3 3.0i's water pump went at 58k. Took out the fan, shroud, some hoses and almost the radiator.
(as a suggestion, always look at a person's post count. Experience is the difference between educated guesses, and being right).
DreamingWell.com Web Services
Old 05-01-2010, 07:04 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
Well I have 167K on mine with no signs of trouble...... I'll replace it at the 1st sign of wobble or leakage.
Old 05-02-2010, 02:49 AM
george dencer george dencer is offline
Mein Auto: 2001 z3 coupe
z3 water pump
Bought my 2001 z3 coupe last July with 107000 miles on it. I am the 2nd owner, bought a spare metal impeller pump, themo and belts. Pump started to make brg. noise at 117400. Did not take a chance and changed it. Was one of the easiest ones i have ever changed. My 2 cents is change it.
Old 05-02-2010, 04:32 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
The radiator neck is the other one that lets go without warning. About 100K or so is where they tend to let go.
But this, like the water pump, is not 100% failure rate, but enough people have had them go in the stated timeframes (mileage), that I would not plan on taking a long trip without changing mine.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-02-2010, 07:34 PM
EOD Guy's Avatar
Yep best bet is to change everything and hope the new ones don't fail..... better yet change the new ones too. Seriously keep a close eye, and ear, on things if something starts to act up change it. I for one check my cars every Sat when I'm driving them.
Old 06-05-2010, 12:29 PM
phrajao phrajao is offline
Mein Auto: 2002 M Coupe
Most definitely is not fiction. I found out the hard way last (Memorial Day) weekend that the water pump on my 2002 M Coupe had decided to go. All at once, I hear the most ungodly screeching/clunking/gurgling sound, the battery light goes on, power steering dies, and smoke/steam come shooting out from under the hood--all in the middle of downtown San Francisco traffic.
When I finally got pulled over and opened up the hood, it looked like a bomb had gone off in there. Shards of fan blades, cut hoses, dangling belts, and fluid streaming out from under the car....This being a Saturday on a 3-day weekend, all the mechanics were closed, so I ended up waiting nearly a week to get everything fixed up and it ended up costing nearly $2000. Grrrrrrr.....
Old 06-05-2010, 12:48 PM
Mike Clark Mike Clark is offline
Mike
Send a message via ICQ to Mike Clark Send a message via AIM to Mike Clark Send a message via Yahoo to Mike Clark
Mein Auto: 2006 BMW M Roadster
Preventative maintenance is not a bad thing. It can save lots of grief and money. If the car is more than 6 years old and has more than 75k miles, I would change it out. Water pumps are a part that eventually wears out on any vehicle. It's much nicer to schedule the change out than have it arrive as a sudden emergency on a 3 day weekend when you want to go somewhere.
Mike
2006 M Roadster Imola Red
2000 M Roadster Imola Red (gone but not forgotten)
1997 Z3 2.8 Roadster Red (gone but not forgotten)
2008 328i Sedan Gold
Old 06-05-2010, 01:06 PM
Hey Mike,
I most definitely agree! I thought I had done pretty comprehensive research before buying my M 2 years ago, but I somehow missed the water-pump issue. I see that you used to have a 2000 M roadster--did you find it to be pretty reliable or did you encounter any significant problems with it? I'm at around 44,000 miles right now and I'd definitely like to prevent any more nasty surprises.
Thanks,
P
Old 06-06-2010, 09:20 AM
milesdf milesdf is offline
Send a message via AIM to milesdf
Mein Auto: 98 BMW Z3 2.8 liter
Z-3-Wow! Now I/m worried about my radiator!
I replaced my water pump at 93k, but with 103k now, must be time for a new radiator. Arggh! Any checks a mechanic can do in advance? Any suggestions on a decent source for a radiator?
Dave
Dave
98 BMW Z3 2.8 liter
Seattle
Old 06-09-2010, 03:11 PM
CarlM's Avatar
CarlM CarlM is offline
Inquiring mind
Mein Auto: Z3 2.8 BG & 5 old Volvos
Mine was replaced at 90k. Broke down on way to Keys. Towed it home from Miami
While you are in there think about mods.
I replaced stock pump w/ warner pump
Replaced expansion tank I highly recomend as these dry out & crack (read up on these devils)
Replaced radiator w/ Zionville
install underdrive pullys
replaced belt tensioner & belts
replaced large washer fluid tank w/ smaller Euro tank
fan clutch & fan
and of course replaced phonolic thermostat housing w/ aluminum one
"One good curve deserves..........another"
Modified Boston Grun 2.8 Z3 Garage Queen
5 vintage 60/70 Volvos & a 1 of a kind '62 morris Minor pickup
Clearwater Beach sand
Daytona Beach sand
SC Homecoming Red Clay
Deals Gap Dust in the Wheel wells
Maggie Valley Fall leaves in the Trunk
Florida Love bugs stuck in the Grill
Islamarada/Pigeon Key crushed coral chips
Mojave Grass seeds in hardtop window
Mane from sorrel 'Leo' quarter horse, a congenital Californian
Old 06-13-2010, 06:09 AM
curtnc curtnc is offline
Mein Auto: 1997 z3 2.8
How much did all the cost? Working on my summer maintence budget
Old 06-09-2010, 03:12 PM
CarlM's Avatar
Inquiring mind
Dave
ZIONVILLE
http://www.zionsvilleautosport.com/s...ALLOYRADZ3.htm
Daytona Beach sand
Old 07-08-2010, 04:24 PM
gwailoh gwailoh is offline
Mein Auto: 2001 M Coupe (steel gray)
For my education, what does the water pump bearing noise sound like when it's starting to fail? My 76k 01 M Coupe has no water leaks, fan wobble or cooling issue (and it's summer in Vegas), but every second or third time I start it it makes a repetetive chirping like a noisy fan belt. The noise eventually goes away once the engine warms a little. Anyone think this is impending water pump failure? Thanks in advance for your expertise and opinion.
Gwailoh
and a handful of Italian motorcycles
Old 07-11-2010, 04:32 PM
phrider's Avatar
phrider phrider is offline
Equine 1/4 miler ancestor
Mein Auto: 2001 M Roadster, 1998 M3
The S54 water pump in the 2001 and 2002 M Roadsters and M Coupes is a different animal -- but it can also fail, but in different ways.
Mine started spraying a tiny amount of coolant onto the hood blanket and shields near the fan at about 40,000 miles or so. I replaced it, and the fix has been good for nearly another 35,000 miles now.
The S54 water pumps are specific to the M Roadster and M Coupe, and the US inventory is often quite low (like 1 or 2 in the US). So, if you see a problem developing, plan ahead or you may be spending a week waiting for a part.
Old 07-12-2010, 12:40 PM
reidconti reidconti is offline
Officially Weird
Mein Auto: Clownshoe,Miata,WeeStrom
I considered a $45 waterpump cheap insurance. Come to think of it, now that I'm up around 130k, I should replace it again. I went with the Zionsville radiator back when I replaced everything the first time. I like the peace of mind. This time around I'll just do waterpump coolant, hoses, belts.
Old 08-07-2010, 07:29 PM
Drw911 Drw911 is offline
Mein Auto: 99 Z3
Mine went out this week. It also took out the shroud, the fan, and all of the coolant. The pump was cheap compared to all of the parts I had to replace! Still waiting on parts. The car has 74 k miles. Hope the engine is ok my wife drove the car several mile before stopping!
Old 08-07-2010, 08:20 PM
NoMax NoMax is offline
Mein Auto: 1999 Z3 2.3
What's the usual cost to get a water pump replaced before it fails?
Old 08-07-2010, 11:39 PM
Skyhawk Skyhawk is offline
Mein Auto: BMW 325i, M-roadster
I replaced the WP with a Stewart and replaced the thermo., upper and lower hose, hose neck with a alumium, coolant, and a temp switch to do the fan delete mod. Got all the parts from bimmerspecialist in all it cost me a little under $300..No labor I did myself.
Old 08-08-2010, 01:30 PM
Officially Weird
BMW part is ~$45. Should take less than an hour to swap, but requires coolant replacement so I'm not sure what the shop labor would look like, I've always done them myself.
Old 08-09-2010, 09:38 AM
muellesx muellesx is offline
Mein Auto: 2000 Z3
My experience (at about 69K miles) was that the plastic impeller sheered off; no dramatic bomb going off under my hood, just an immediate and total stop to the flow of coolant. There is no warning for this kind of failure; you cannot listen for any tell-tale signs. Considering the cost of the repair vs. the cost of the eventual tow (let alone repair costs), I'd recommend being proactive. Be sure to replace it with the stainless steel impeller version. Even these have reported issues; the bearings eventually go out. If I hadn't been stranded and at the mercy of the shop I got towed to, I would have invested in an aftermarket water pump.
Old 08-09-2010, 03:17 PM
kostverloren's Avatar
kostverloren kostverloren is offline
Mein Auto: DINAN Z3 3.0,535i,MINI
Only way to go for full confidence.
http://www.turnermotorsport.com/html...gn=STE%2030330
'02 Z3 3.0,'11 535xi,MINI
Old 10-11-2012, 09:50 AM
morrieschoice's Avatar
morrieschoice morrieschoice is offline
Mein Auto: 2001 3.0 Z-3 ROADSTER
The Stewart Water Pump is $175 at Bimmerzone. I recently purchased & installed one on my 3.0 '01 Roadster. Ask for Vincent...the manager. Tell him Morris Chance sent you...
Old 08-09-2010, 05:50 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
My water pump blew out on my M3 on Christmas Day of all times. The worst day to have a total breakdown.
Radiator, water pump, thermostat housing, hoses, etc. Full cooling system replacement basically.
Its not that hard to replace the water pump, just takes time. I would go with a stewart warner pump and an S54 radiator just for the peace of mind.
I bet you wouldn't have to worry about replacing it for a long time after that. Its not very complicated though, I would just jump into it and get it done one weekend.
Or you can just wait till the coolant runs up your hood and sprays your windshield, thats a good indication that the system needs service.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
