Mobile Electronics and Lighting
Car Stereos, Cell Phones, DDEs, HIDs, foglights etc... |
FS: MY2010-on Stereo system (6-speakers) harness
The MY2010-on 1- and 3-Series standard sound system was downgraded from a 10-speaker, separate OEM amp to a 6-speaker, no OEM amp system. So adding an aftermarket amp requires cutting the wires in the back of the OEM HU or cutting the speaker wires either at the speaker themselves or under the carpet.
This PnP harness eliminates that hassle and the damage to your OEM wiring by directly interfacing with the OEM Quadralock connector in the back of the OEM HU and producing a cable extension for the connection of an aftermarket amplifier in the trunk without cutting any OEM wires. ![]() Complete harness includes: - OEM Quadralock connectors fully populated (max of 40 wires) to connect between the OEM HU and the OEM Quadralock in the car - A 12V relay pre-wired to provide an OEM remote turn on signal for the amp(s). The new amp will turn on when a door/trunk is opened and will turn off in about 2 minutes after the door/trunk is closed and the car is off, just like all OEM amps. - 15' cable extension with each wire labeled to the inputs/remote signal of the aftermarket amp - 15' cable extension with each wire labeled from the aftermarket amp outputs back to the OEM HU. Notes: - this harness is currently only for the OEM HU. In the next few weeks I will have a longer harness for the iDrive (same price) which facilitates the installation in such vehicles so equipped. - this harness is designed to add a 4-channel amplifier to the Stereo system as is. If the idea is to add a 6-channel amp or to bi-amp the front speakers and the woofers separately then new wires need to be added from the amp to the woofers. These wires are not included. To power the woofers separately -as in replacing the woofers with SWS-8- the OEM woofer connector does not have to be cut, just tape it under the carpet and run new wires from the amp to the woofers. My harness will route the front channels of the new amp to the front doors without an issue as the woofers are connected in parallel to the front doors. Therefore, adding an amp will be completely reversible without any ill effect to the OEM wiring as long as these instructions are followed and the amp output is not in excess of the OEM wiring (20-18AWG) capacity. - if your car is equipped with the MOST (fiber optic) ring you must transfer the MOST connector from the OEM Quadralock to the new Quadralock harness in the same exact slot. Make sure that it locks into place. Price is $65 shipped in the USA. One year warranty against defects; warranty voided if Quadralock harness is modified in any way. PM for details... |
Bump!
Bump!
Bump...
Bump...
Bump...
So...i need your harness for my 2010 E92 335i w/ i-drive and basic stereo (6 speakers). The plan is to replace the fronts with Focal 100VRS (u have also OEM speaker connectors to connect the Focal?) - ch 1 & 2, keep the OEM's in the rears - ch 3 & 4, replace the underseats (SWS8 or ADMW SW9) and power them on separate chanels - ch 5 & 6 (i need any jumpers with your harness for that?) and add MS-8 + XD600/6 in the trunk.
Bump...
News about the hardness for the 2010 E92 basic sound system?
It is back in stock for a short run...
i need to purchase this harness asap. im new to this forum, please help complete transaction
....and what does PM stand for as far as contacting the right person to make the purchase of the harness. its for an '08 535i. im looking to replace the door speakers with (4" polk), tweeters (polk), under seat subs (sws-8), rear deck (4" polk), and add 2 L7 10" sub, use one 5 channel alpine amp and a hifonics brutus 1300 watt rms amp
For the 5-Series, a two harness kit (one for the iDrive unit and one for the OEM amp in the trunk) is needed if all the 6-channels are going to be powered by aftermarket amps. |
Technic or anyone else out there that can help me.
I have this harness from Technic and it is very high quality(thanks man) I installed it yesterday and linked it all up with my Boss PH4.400 Phantom amp but now have the annoying alternator whine. I guess this is caused from bad earthing. So my question is where is the best place to earth on my E60 '2005'?? Thanks Guys |
If there's none then ground it directly to the OEM battery. All audio grounds should converged there. |
Bump...
Bump...
Bump...
Will this idrive version fit the pre lci E60 with the hifi 10 speakers? if so please tell me how to order.
Thanks Dave |
Do you still sell this??
