Video of cold idle engine intermittent squeal (how to determine cause)? - Bimmerfest - BMW Forums
Old 05-19-2010, 02:50 PM
Attached is a video of my cold idle engine intermittent squeal.
Debugging hints to isolate the cause are welcome.
I replaced the power steering reservoir fluid twice with a quart of Dexron VI which seemed to help a little - but it still came back (the power steering fluid container is empty so you see the white bottom; all the ATF sucked out twice filled the S. Pellegrino water bottle).
Caveat: This is my first video upload ever so I may screw it up.
Here is the video:
Old 05-19-2010, 03:17 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Donna, I thought we need Dexron III, and is there a negative effect in using Dexron VI?
I am not sure what actually the difference is between the different Dexron labels: Dexron III vs. Dexron IV vs. Dexron VI. (I didn't see a Dexron V yet, and I purchased Dexron IV for my steering).
Also, from the pic, your ATF seems grey? This should not be normal - it's light pink.
Addendum: In this case (that grey color), I would try to get rid of as much as I can of that grey stuff - it will kill your steering rack (if it didn't already).
Here are some methods - beware though they are from a v8, which is different from ours - but close enough for procedure, including cleaning the reservoir which has a build-in filter.
GL
Old 05-19-2010, 03:36 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The squeal sounds like a bearing, possibly an idler wheel, or alt/water pump/PS pump.
Pull fan, remove belts, and examine all the rotating machinery on the front of the engine. Be sure to mark the operating direction of the belts, so you can put them back on correctly.
The idler pulley bearings can be cleaned and repaced, if not worn or scored.
Old 05-19-2010, 03:47 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Take a spray bottle with water in it....spray a little on the idler pulley....if the noise goes away, the pulley is bad....if not, spray some on the belt...if the noise goes away, replace the belt.
The road goes ever onward....
(R.I.P. Jever)
Old 05-19-2010, 10:17 PM
I'm going to have to replace the belt anyway (it has 85K miles on it and has cracks).
I'm not sure which is the idler pulley so I'll look that up... ok. it seems to be related to the A/C and water pump so maybe a debugging hint is to run the AC to see if the sound changes...
Old 05-20-2010, 01:58 PM
I soaked the idler pulley and then the 6-hills-5-valleys serpentine belt with Wisk. The noise abated but only slightly, and since it's intermittently loud and silent, I couldn't tell a thing from that test.
I can't imagine a stethoscope working safely because of the moving parts (I mean, you can't just put it on a pulley, can you?) But I'm looking online in AutoHauz for the stethoscope as I'm getting the cabin air filters anyway).
Luckily, I need to replace the serpentine belt (it has cracks); but while I'm at it, I'd rather not take it apart twice so may I ask what is the total list of possible components that could cause the intermittent squeal?
- idler pulley bearings (can be repacked with grease, right?)
- alternator bearings
- water pump bearings
- power steering pump bearings
- the 5-ribbed (6 valleys) serpentine belt
In cn90's diagram, I see a few more parts (do you think they have bearings that could cause that noise)?
- idler roller
- two other rollers
- hydraulic tensioner
I hate to take it apart twice just so it would be good to diagnose before getting all the parts. I will try the suggested 2500 rpm test if I can get a helper so that I can videotape the noise.
Old 05-20-2010, 02:42 PM
Shires's Avatar
Shires Shires is offline
Mein Auto: E39
FYI the part numbers may be different for the M54 engine (different style of pulley I think). Last time I tried neither BMW nor an OE shop sold the M54 tensioner pulleys separately (they sell tensioner only). I didn't look on the internet. I hope you have better luck. Also some cars omit the idler roller pulley.
Old 05-19-2010, 10:03 PM
I'll look for an M54 DIY. Seems to me I need to replace the belts (they have cracks) and identify whatever it is that is making the noise so that I can replace that too.
Unfortunately that means I'll be taking it apart twice!
Once to identify the culprit; the other to replace it. It would be nice to be able to identify the sqeaky wheel without having to remove the belts!
Note: I found an E46 DIY and an 330i M54 DIY (is a 330i M54 engine belt configuration the same as a 525i M54 engine belt configuration???)
Old 05-20-2010, 02:46 PM
E39Freak's Avatar
E39Freak E39Freak is offline
BimmerJunkie
Mein Auto: 1998 Alpine White 528i
+1 on the pulley.
Mine is doing that now but only when stopped while in gear.
The Ultimate Driving Machine INDEED!
[SIGPIC][/SIGPIC]
Old 05-19-2010, 09:50 PM
Originally Posted by doru View Post
we need Dexron III ... is there a negative in using Dexron VI?
AFAIK, Dexron III no longer exists. According to what I had read, GM no longer "certifies" compliance with Dexron III; but not to worry. AFAIK, Dexron VI supercedes Dexron III specifications.
There is no ATF in the picture; my ATF is blood red but what you see in the picture is the WHITE bottom plate of the empty power steering fluid reservoir. I had just sucked out all the fluid so that's why you see the white bottom. It's empty in that picture. (Of course, I filled it up before starting the engine; it took about half a quart.)
ID:	230831   Click image for larger version
Old 05-19-2010, 10:49 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Idler pulley morning squeal = common, I put oil on it to verify, easy to replace
Old 05-19-2010, 10:54 PM
doru's Avatar
Thanks Blue for the reply.
Old 05-20-2010, 10:32 AM
I need a good diagram of which is the idler pulley. I suspect a search for "cn90" and "idler" will get it for me ... gimme a sec ...
Too bad. Cn90 didn't start any threads with idler pulley in them. Lemme search for something else ...
Ok, searching the Internet for cn90 and idler gets me closer (on bimmerboard) ...
Is this the idler pulley? Is the "idler roller" the same as the idler pulley?
Old 05-20-2010, 12:45 PM
scott0357 scott0357 is offline
have you used a mechanics' stethoscope to locate the origin of the noise when that happens? It shouldn't be hard to pin point the location. If you find the noise is indeed from the PS pump, try use the ATF from Redline.
Old 05-20-2010, 12:51 PM
Graham E39 528i's Avatar
Graham E39 528i Graham E39 528i is offline
Conservative Modder
Send a message via Yahoo to Graham E39 528i
Mein Auto: BMW 760Li (2008)
Yeah, a stethoscope might help. It helped me locate a bad water pump. Mine didn't screech though, it made a rattling noise.
OEM BBS Style 42 (18x9) | Conti DW 245/40-18 | KraftStab Strut Bar | Bilstein Sports | Vogtland Springs | Eibach Sway Bars | Mason Sway Bar Links | e36 M3 Steering Wheel | Biarritz Blue Metallic | Nimble & Graceful
Portland BMW Club Member
Old 05-20-2010, 03:03 PM
How does this stethoscope look from Autohauz (since I'm already getting the filters and serpentine belt and maybe the idler pulley)?
The only problem I foresee is that those parts can rip your arm off so I am not sure HOW I'm going to get a stethoscope in there w/o getting coiled up in the belts, rollers, and fan!
PS: I have a friend coming over to help me videotape the noise since I need to rev the engine and film at the same time for that debugging test.
Old 05-20-2010, 08:44 PM
No! You don't put the stethoscope on the spinning pulley, you'll get hurt. Put it on the housing behind or closest non-moving part to the pulley. As you probe around the non-moving parts, the noise gets louder as the stethoscope moves closer to the source of the noise. Assuming the power steering pump pulley or bearing is bad, put the stethoscope on the power steering pump housing (behind the pulley), the noise would be the loudest at that point. As you move the stethoscope away from the PS housing, the noise gets quieter.
Old 03-19-2012, 07:28 PM
I had asked that question long ago ... and ... interestingly, the same question came up today ... over here:
> E39 (1997 - 2003) > Pulleys and tensioners
Originally Posted by juanchi29 View Post
I'm confused about one thing, is there an idle pulley and a pulley or is it the same thing?
Old 10-17-2012, 12:26 AM
A recent thread had a nice video of the squealing noise of a bad tensioner:
Originally Posted by Hootman View Post
I have posted this problem a few times under different titles and have had a few responses to this engine noise. I have replaced both belt tensioner pulleys as well as the idler roller pulley. Both belts are in good shape although I did spray a little belt conditioner to see if would soften the noise, didn't work. The fan clutch seems to have a proper amount of drag when I spin it by hand, at least enough to unscrew it from the water pump pulley.
It's hard to tell where the noise is coming from. I have posted a short video on YouTube (BMW Engine Noise) where you can hear it. If you go there note the noise intensifies as the car is put in gear.
Any suggestions on what this might be?
In addition, this thread today has a nice DIY procedure for figuring out WHICH tensioner is bad:
Originally Posted by Pucho View Post
This is just for the benefit of those that have an engine noise and can't seem to find the problem. I had a noise just like the one in this post http://www.bimmerfest.com/forums/sho...d.php?t=511169
I used a hose as a stethoscope and was convinced the noise was coming from the WP. Since I was doing a complete cooling overhaul I figured the noise would be gone once I replaced the WP. Not so. At the same time I replaced both the AC and WP pulley as well as the main idler tensioner. I have the mechanical idler arms and figured they were okay and would not need to be changed. Well, I was wrong. The "cricket" noise prevailed especially when in gear at the lights.
Just today, I got under the car, took off all belts, put a 16mm on the idler nut and rocked the arm back and forth. Gotcha! the squeak was there as I rocked back and forth.
Hope this helps some of you, as it drove me crazy for months.
Dan
Old 05-20-2010, 01:22 PM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
Would belts or pulleys cause a constant sound? The intermittent is throwing me off.
What happens when you raise the RPM's say to a steady 2500 or so?
Old 05-21-2010, 01:21 AM
It's still intermittent!
Old 05-20-2010, 05:15 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
bluebee i'm have the same problem. ps pump loseing fluid once a week. what i had to do was get under the car and take down the engine sheild too see where the fluid was going too.
but my problem is a little different. i hit, well the rabbit wanted to die. but any ways after running over the little turd i started to have problems. most people need to either tighten some hose's or replace them, cn90 cover this in one of his diy's while working on something else, kind of killed two birds with one stone, or diy.
my problem, is when the rabbit went under, the boot that goes over the tierod, tore, and i think he knocked the tierod back some or enough to mess up the seal on the rack. good luck with finding the problem.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 05-23-2010, 03:32 PM
lild's Avatar
livin the 'Fest
well i know mine leaks, and when it is low, on cold starts the pump will whine until the car warms up which at the same time fluid level seems to build up and stops unless it's real low.
Old 05-28-2010, 08:53 PM
july865 july865 is offline
Mein Auto: 97 528i
i worked for GM for quite sometime. we had a TSB (tech service bulletin) relating to belt pilling. pilling is caused from the belt material gathering in the lands and groves of various pulleys. that in turn would cause the belt to raise itself off the pulley and shift just enough to chirp or squeal. we also had to check for mis-aligned pulleys. PS pump was notorious for that. anyway, we had to go over each and every pulley with a wire brush and a pick to scrape all the pilling out. was a pain in the azz. once that was done the belt was replaced.
as for the stethoscope, use the longest screw driver or socket extension you have. wasnt uncommon for me to use my 30'' 3/8 extension or my breaker bar. then put your ear to the handle and listen... its easy once you get the hang of it and know what to listen for.
g/l
Old 05-30-2010, 12:05 AM
Originally Posted by july865 View Post
as for the stethoscope... its easy once you get the hang of it and know what to listen forl
No matter where I put the tip of the mechanics stethoscope, everything sounded hugely loud and tinny, with vibrations and growls and a cacophony of sounds emanating from every which way.
The fact nothing seemed different when the intermittent squealing occurred, indicates, to me, perhaps, it's a component isolated from the engine block.
The biggest problem was that I couldn't put the tip of the stethoscope on the idler pulley or the alternator pulley itself or any moving component.
So, the use of a stethoscope, at least in my hands, is busted.
Name:	20100526 001-20100319_16-24-49-.jpg
