X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
Removing X3 Headliner?
How hard is it? I have the dreaded roof rail corrosion and am considering removing and repainting the rack myself.
How big a deal is taking out the headliner? I can see that the OH console, mirrors, grabs, etc all need to be detached, and the trim on the pillars removed. Anyone done it? How long should I budget? (competent amateur mechanic, and i want it to go back together correctly. Thanks for any help. I have searched for DIYs but haven't found any. Greg Ottawa, Canada |
Hi Greg , I know I have seen a couple of people have done this, and had hoped they could give you a time frame…I haven’t … but I can send you the instructions if you wish ( just too large to post it all here )
So send me a private msg. with your email if you are interested, and I’ll try and get it off to you.. This looks like a fun but time consuming job. It includes removal of; both sun visors & supports, all handles, all trim panels from all pillar’s, trims, & all ceiling lights… Also, tell me if you don’t have the panorama sunroof John |
Hi John,
New to the forum, but wondering if you still had a copy of the directions to remove the headliner. Have had some nasty issues with the pano-roof and would like to get access to the track. Really appreciate any help, Tyler |
Hi Tyler, p/msg received & sent you what I have...good luck, John
http://tis.spaghetticoder.org/s/view.pl?1/09/24/55
Check this web site out for instructions. Good luck. Jeff
2005 X3 3.0, Mystic Blue Metallic, Sand Beige Leather Interior, Birch Grain Light Wood Trim, Steptronic Transmission, Premium Package, Heated Seats, Privacy Glass, Satellite Radio Prep, Xenon Adaptive Headlights, Heated Steering Wheel, Premium Sound, Power Folding Mirrors and NAVIGATION RETROFIT |
The rear panel on the panoramic sunroof jammed open on my wife's E83. Could use the same info to remove the headliner - sending you a private message to that effect as well if you still have those instructions available.
Josh |
Greg,
I'm in Ottawa as well and I am looking to remove mine. My mechanic said that it would be a couple hour job. So I'm assuming around $200 to have them removed. If you happen to get it done prior to me let me know. I have that rust as well. I'm looking at taking them off and leaving them off. Brian |
do you guys still have the instruction on how to remove the headliner?
thanks |
...and,in addition,with the roof rails installation? thank you
Front Head liner
Says you can't remove the front head restraints/rests, but there must be a way? Anyone done this, if so thoughts?
headliner
Please send me the headliner removal instructions also
Thanks |
It's not very difficult.. I removed rear to get access to shark fin, all pilar covers have to come off. There are two screws holding each of oh sit handles, with each screw hidden with a snap in cover. Those things were a bit of a pain, but once you get first one out, it is simple. There is usually a Torx screw behind Srs bracket. Take your time, it can be removed in under 2 hours..
Headliner instructions
Hi,
The instructions would be most helpful. Thanks Jak |
