Old 06-07-2010, 09:59 PM
cdawg246's Avatar
cdawg246 cdawg246 is online now
Mein Auto: 1999 540i m-sport
where do i get a diode block for a 540i water cooled alternator?
does anybody know where i can pick up a diode block an internal electrical part in a bosch watercooled alternator--this block or plastic part melted along with 3 diodes-- 3 were still good(intact). i can get the voltage regulator but i have been searching all day for this diode block since it has a bosch part number on the part--if i can buy this part i can fix the alternator myself and do not have to buy a remanufactued one here's a couple of pics in red i circled the part--in black are the 6 individual diodes--i know someone on here ripped one apart and fixed this problem--thanks again [IMG]Photobucket[/IMG] [IMG]diode pack 2[/IMG]
Old 06-07-2010, 10:19 PM
Don't know the answer ... but did the diodes melt due to the huge reverse-biased current that occurs when jumping a dead battery and not turning on the lights (to suck up the initial surge across the diodes)?
Old 06-07-2010, 10:37 PM
cdawg246's Avatar
not sure but one diode was melted the other two just disconnected from the diode block and the plastic was melted--i did replace the battery last year thinking the battery was the problem--autozone did a load test and it failed the diode test so my boy took it apart today and we found out the burned diode was the culprit--i think the first one went taking the other 2 since it was weak already--but im not sure
Old 06-08-2010, 07:21 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
These guys used to carry those diodes in the past. They do carry most of the rebuilding hardware or replacement alternators. Not sure what happened with the diodes parts. Maybe contact them and ask them. If you find out anything, let us know.
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 06-08-2010, 08:18 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Doru,
The link you mentioned is WAI Global, they do NOT sell to the public (I already asked).
cdawg246,
Best is Smith and Co. in Greely, CO (I spoke to them and they know their stuff). All info is here. Speak to Dave, very nice guy!
Post a follow-up so others who want to rebuild the water-cooled alternator can benefit from it.
http://www.bimmerfest.com/forums/sho...0&postcount=13
I would change both bearings too (highly recommended):
1. Front bearing 17x52x17mm, use only Bosch OEM bearing and yes Smith Co is the only place that sells this difficult-to-find bearing with quality (You will find Chinese bearing of this size on ebay but stay away from Chinese bearing!!!). I convinced them to sell the Bosch OEM bearing on ebay and here is the link:
http://cgi.ebay.com/ebaymotors/5-522...Q5fAccessories
2. Rear Bearing is 6203-2RS (check to be sure). Smith Co. also sells NTN brand NTN is very good):
http://cgi.ebay.com/ebaymotors/5-400...Q5fAccessories
However, if you want Japanese bearing. Go to ebay and search "Nachi 6203 2RS". You want double rubber seal bearing (therefore "2RS" designation). Nachi is a very very very good brand!
http://cgi.ebay.com/6203-2NSE-RS-2RS...item5d2879bac3
Old 06-08-2010, 03:23 PM
cdawg246's Avatar
k here's the answer i got from 2 local alternator/starter places in buffalo ny--bosch for some reason is not selling parts to fix them--that's what they told me--i guess it doesn't come as one piece--neither of them can get me a new rectifier(diode block) neither of them can get me the 25amp press fit diodes, 3 are positive 3 are negative--best and co. like suggested above stocks the 3 positive diodes but cant get the 3 negative--they can't get me the piece that the diodes are soldered to-- they told me are like a crimp spot weld process at the factory-- but they do stock the internal voltage regulator--in conclusion bosch knows that u cant go without this water cooled piece of **** so they dont give us access to the parts which blows--this would have been a easy fix if they stocked parts for this alternator--so i guess im like everyone else and will have to purchase a reman alternator for their insane price and move on
Old 06-08-2010, 07:10 PM
Originally Posted by cdawg246 View Post
.....neither of them can get me the 25amp press fit diodes, 3 are positive 3 are negative--best and co. like suggested above stocks the 3 positive diodes but cant get the 3 negative--they can't get me the piece that the diodes are soldered to-- they told me are like a crimp spot weld process at the factory....
Did you check with Smith Co. in Greely CO?
Info in my post #5 above.
Old 06-08-2010, 03:28 PM
cdawg246's Avatar
i know if this happened to a doctor or lawyer they would pay the stealer 1500 to change it and never look back--but this alternator isn't hard to change and the rebuild is even easier--bosch really needs to start selling alternator parts to the public--if they did i would already be rolling again
Old 06-08-2010, 03:31 PM
cdawg246's Avatar
there is a good write up i found on the net about bmw water cooled alternators--where he explains how to disassemble the alternator and replace the bearings http://www.meeknet.co.uk/E38/Alternator/Index.htm
Old 06-08-2010, 04:11 PM
Are you saying our alternators are water cooled????
Old 06-08-2010, 05:14 PM
cdawg246's Avatar
not all 5 series but any one with a 4.4 m62 engine does--it sits in the engine block and coolant runs across the back to cool it--taking it apart is cake--getting parts is another story
Old 06-08-2010, 07:11 PM
GSXRYDER GSXRYDER is offline
Mein Auto: 540i
Well...
From what I find on the net...
$399 at Advance
$454 at autozone
The core charge at advance is $100 so you get a rebuilt alternator for $300...not a 'steal' but not that bad either
99 540i-6 Sport
Pure
Adrenalin!
Old 06-09-2010, 02:18 PM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
$399 at Advance
$454 at autozone
No the core charge is added to the price which makes the advace one 500.00 with core and its a no name brand atleast as far as there site shows, You can get a bosch unit for 389.00 after core credit
from board sponsors.
Old 06-08-2010, 07:17 PM
Also,
Have you tried dacotronic.comfor the diode?
Read this:
http://www.rangerovers.net/forum/vie...hp?f=2&t=38323
Old 06-09-2010, 09:23 AM
cdawg246's Avatar
those diodes don't fit in the bracket--the alternator place near me had those but they were too big
Old 06-09-2010, 09:28 AM
cdawg246's Avatar
i just ordered a remaned alternator on ebay total was 285 no core charge--advance wants 400 without the core charge i called yesterday
Old 06-09-2010, 02:04 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport cdn, F355
Here is a great source for alternator rebuild parts. Reasonable prices, quick service.
http://www.holcombedirect.com/browse.cfm/2,205.html
Factory M-Sport package with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar.
Old 06-09-2010, 05:04 PM
cdawg246's Avatar
it looks like they carry the voltage regulator for $27 but i didnt see the rectifier for a bmw water cooled alternator--but they are way cheap on internal parts
Old 06-09-2010, 06:28 PM
Call them, they are very helpful.
Old 06-10-2010, 10:15 PM
cdawg246's Avatar
i called them and no dice--but i told mike that they need to look into carrying bmw bosch water cooled alternator rectifiers--thanks 540 m-sport
Old 06-11-2010, 01:21 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 2000, 1995 540iA, 07 525
I had mine rebuilt 3 times within a year. The rebuilder kept putting in higher amp diodes (up to 150A) and they kept blowing. He explained there must be an internal short in the windings which raises the amps but lower voltage output so I would have to replace it. I picked up a reman one and haven't had an issue since. Luckly, the rebuilder only charged me for the diodes each time but the car was still out of commission for a couple days each time. I'll never go that route again. I wish you luck if you decide to proceed to with your rebuild.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 06-18-2010, 08:58 AM
jgrullon1967 jgrullon1967 is offline
Mein Auto: X5 4.4i
Bushing
Does anyone know where to get the plastic bushing that surrounds the rear bearing to separate it from the main body of the alternator. If not what can be used for this area.
Old 06-18-2010, 09:43 AM
Call Smith and Co in Greely, Colorado and ask:
Smith Co. Inc.
530 11th St.
Greeley, CO 80631
USA
Phone: (970) 353-3121
Ebay seller name "smithcoelectric".
http://www.stayingreen.com/5.html
Old 06-18-2010, 09:57 AM
Mein Auto: X5 4.4i
Already did that they don't have it
Old 06-18-2010, 12:49 PM
fisha fisha is offline
Mein Auto: Range Rover ( Sorry ! )
Hi folks, I'm in exactly the same boat as posted here. Have an M62 engine in a Range Rover ( sorry its not a beemer ) and the alternator has packed up.
To be honest i think its outrageous that you cant get the parts to fix these. However, I have found this link:
http://www.semiconductors.bosch.de/p...oduct_info.pdf
Anyone think these may be the correct ones ? Looking at the pictures above, it looks like the ED10 housing may be the correct size. Can anyone tell us how tall the original body of the diodes are?
