E90/E91/E92/E93 (2006 - 2013)
Old 06-13-2010, 05:56 PM
tclippinger tclippinger is offline
Mein Auto: Ford (current)
06 325xi right low beam headlight keeps blowing out?
06 325xi right low beam headlight keeps blowing out? I have replaced this bulb over and over again, has anyone else had this problem? It is getting frustrating! Yes, I have been VERY careful whern replacing the bulbs. I read somewhere that Sylvania bulbs maybe the culprit "cheap".
Old 06-13-2010, 06:19 PM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
check for corrosion in the socket. may also be a bad ground.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 06-14-2010, 11:36 AM
Thanks!
Thanks, I'll check.
Old 12-02-2012, 07:33 PM
cpezie cpezie is offline
Mein Auto: X3
I'm having the same issue with my 2008 x3. Did you find the issue? I don't recall seeing any corrosion at the connector.
Old 12-02-2012, 07:40 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
That would be unusual. Check volts 'n' amps. In spec?
If not familiar w/electrical troubleshooting, best left to an experienced hand.
Any flicker?
Old 12-02-2012, 07:45 PM
bmwwww bmwwww is offline
Mein Auto: e90
There was a SIB to replace the bulbs with Philips H8 AR longlife bulb P/N 07 11 9 906 503
Old 12-05-2012, 12:12 PM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
if you have the xenon headlights, its the ballast that went bad if the D1S keeps burning out.
Old 12-05-2012, 12:25 PM
The X Men The X Men is offline
Mein Auto: 2012 535xi 2012 X3 35i
Make sure you dont touch the bulb with your bare hand. Other than that, you might have some electrical issues with your car.
325xi, replacement bulbs
