Old 06-28-2010, 12:07 AM
What is this engine part? (Getting to know my M54 engine bay)
Over time, I've come to know (by necessity) almost every large item in the M54 engine bay ... but some items still are unknown to me ...
Old 06-28-2010, 12:13 AM
Old 06-28-2010, 12:20 AM
Old 06-28-2010, 12:25 AM
Old 06-28-2010, 12:27 AM
Old 06-28-2010, 12:32 AM
Old 10-28-2011, 07:26 AM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
vanos solinoid.
Old 11-26-2011, 08:59 AM
Fuel tank breather valve, aka EVAP purge valve ...
From this thread today:
- E39 (1997 - 2003) > EVAP Purge Valve Flow
Originally Posted by hasamu84 View Post
My service egine light came on my 2000 528i and the code show P0441 EVAP Incorrect Purge Flow. I need to know where the Purge Valve is located on my 528i, under the hood it has a diagram but I don't quite know what it look like.
Here is the pic of the by 16valex:
Originally Posted by 16valex View Post
Under the intake manifold and close to the front
Here is a description by JimLev:
Originally Posted by JimLev View Post
Part #1 on the diagram. The DME controls it. One hose goes to the charcoal cannister that is connected to the fuel tank.
The other hose connects to the intake manifold
The charcoal absorbs fuel vapors (in the old days the tank was vented to atmosphere). The purge valve allows the vapors to be sucked out of the charcoal and into the engine.
Adding JimLev's information to the diagram in this post #17 of:
- Might we be able to list, with pics (realoem diagrams ok) of ALL E39 vacuum lines?
Note: I'm having trouble finding an E39 charcoal canister photo, in situ.
Do you have one handy?
ID:	302498   Click image for larger version
Last edited by bluebee; 11-26-2011 at 10:01 AM. Reason: Added request for charcoal canister photo.
Old 11-26-2011, 11:46 AM
Thanks to added value by Bomb5 today in this thread:
- M54 vacuum tubing ... what diameter ... what brand ... what material ... what length?
... we, for the first time (that I know of), have an in-situ picture of the three M54 engine vacuum endcaps that are listed in the parts list but (frustratingly) are not shown in the diagrams!
Based on what we found in post #20 here, out of the two, three, or four endcaps reputed to be in the E39, here's the best I can do so far without additional help:
  • This diagram loosely intimates there is one capped vacuum port:
  • This diagram outright says there are three capped vacuum ports:
    • Engine => Intake manifold => Intake manifold system
    • #15, Cap, D=3,5MM, Qty=2, 11611437560, $3.39 (between 1/8" & 9/64" ID)
      • One of these is probably for the CCV valve vacuum port on the M54
      • The other 'may' be if the M54 does not have an air pump, then it would cap off that vacuum port in the back of the engine where #7 hose would go in the "Air pump F Vacuum Control" diagram.
    • #17, Cap, D=7,0MM, Qty=1, 11611727176, $3.39 (between 17/64" & 19/32")
      • This clearly is the rear vacuum port behind the sucking jet pump on my M54
Originally Posted by Bomb5 View Post
I believe that I found the 3 end caps ... See the attachment.
EDIT: Steve530 added additional pictures showing the SAP electrical valve taking one of the hoses that appear to be capped above:
Last edited by bluebee; 11-27-2011 at 07:51 AM. Reason: Added additional pictures showing endcap locations on the M54 engine
Old 06-28-2010, 06:49 PM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
That part is called dust.
Old 06-29-2010, 06:53 PM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
I wonder what the air filter looks like? Rather dusty where that vehicle is operated.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 06-29-2010, 07:32 PM
Here is a picture of the old engine-air filter and the new filter side by side.
The old one looked OK but I replaced it anyway.
It won't rain here for the next 10 months and I take the bimmer for a drive over the mountains at least once a week, so, there is a lot of dust in the mountain roads.
Do you guys actually "wash" the engine? I've never done that as I'm too afraid I'll wash the oil out of things that need grease and electrical components that aren't supposed to get soaked.
Old 09-16-2010, 01:11 PM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
It's the only collection I have.
Old 04-14-2011, 02:03 AM
In situ ICV location on the BMW M54 engine:
- CCV Replacement FYI - M54, by Jason5driver
In situ DISA location on the BMW M54 engine:
Old 04-14-2011, 02:06 AM
Intake manifold "air distribution piece" in the M54 engine by Jason5driver:
- CCV Replacement FYI - M54 (post #23)
Old 06-28-2010, 07:29 AM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Air pump valve cold start, disa, heater left right valve, vanos solenoid, cvv tube to cvv, dunno last
Old 06-28-2010, 05:05 PM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
glad to help!
Old 06-30-2010, 08:27 AM
Past Sponsor
Mein Auto: e39 5
I wipe mine down with a damp cloth, that is about it. I don't do that often either. I've never been one to detail an engine, I just don't have the time or energy to devote to it.
Old 06-30-2010, 10:33 AM
menhir's Avatar
menhir menhir is offline
Float On
Mein Auto: Not a Bimmer
I clean mine two to three times a year, I've done it on all my cars and my wife's as well. I use a generous amount of Simple Green from a pump spray bottle, a soft paint brush for stubborn spots and a stiffer brush for really stubborn spots (like around the power steering cap and bracket) and a gentle spray from a hose to wash the grime/dirt/grease away, top and bottom. I will dry what I can with a towel or rag then drive the car until the engine bay warms up enough to dry the remaining water. Sometimes I will "condition" the plastic and rubbery parts with a protectant like Armorall. Be sure to cover your power steering reservoir cap with a plastic bag to prevent water from entering thru the small weep hole before spraying anything! You may need a few paper towels to soak up the water that will accumulate in the wells on top of the struts, too.
"The wise speak of only what they know."
Old 06-30-2010, 05:59 PM
gtxragtop's Avatar
Armor All contains silicon. Silicon is deathly to the O2 sensors. Not worth using that stuff and having to worry about it being sucked in somewhere into the airstream going into the engine.
Old 06-30-2010, 10:12 PM
menhir's Avatar
Float On
Good advice, I'm sure. Silicone is a double edged sword and not appropriate in every situation. My mistake for generalizing.
Following your caution, it makes sense for me to recommend the use of Meguiar's Silcone Free dressing or a similar product. Works the same on rubber, plastic and vinyl without the danger (and it won't discolor tires, intake ducts, etc. if used often, as Armor All would).
Old 07-01-2010, 04:52 AM
BigCo540i's Avatar
The Usual Suspect
Been using it for years, how much could really be sucked in and where could it be sucked in from.
Old 06-30-2010, 11:03 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
I mix up a bucket with very warm water and Dawn dish soap, Wet the engine bay down first with a light spray of water, then use a wash mitt and the Dawn mixture to suds up the engine bay, then rinse it off with a light spray, and blot it dry with a few old towels. The dawn cuts grease and oil quite well, but if you get it on the body of the car it will also remove every speck of wax. In fact, I use it for stripping wax when I'm doing a full detail on the paint. As far as water causing problems, a light spray isn't a problem, but NEVER use a pressure washer or coin-op high pressure on the engine.
And yes, you can go crazy and detail the entire engine compartment:
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 07-01-2010, 06:40 AM
menhir's Avatar
Float On
Wonderful work. Exactly what I aspire to. The trying part is I have to overcome the PO's years of "neglect".
Old 07-01-2010, 08:11 AM
Oh my! I'm never posting a picture of my (dusty) engine ever again!
PS: Is it silicone or silicon that you are worried about for the 02 sensors?
