E46 (1999 - 2006)
Old 07-24-2010, 08:46 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
Arrow DIY: FSU (aka Blower Motor Resistor) replacement pictorial guide
It was my turn to replace the FSU (blower motor resistor). I just got tired of the pulsating pattern of the blower and its shutting off on its own accord. It is especially frustrating in the 100F degrees St. Louis weather. I ordered the part through one of my favorite sites: www.eeuroparts.com that has great prices and both OE and aftermarket parts. The FSU is made by Behr (OEM). The cost was $59.99 shipped. It took an hour to install and it was a pain in the neck (literally) due to its location under the dash. If you have problems with your back/neck/shoulders Iíd recommend to delegate this repair to a shop technician (hopefully without these problems). You have to spend some time in the area below the glove box on your back and side with your legs on the passenger seat. There is simply no other way.
The DIY is in the pictures. Sorry if I missed something. But thatís just pretty much the way I did it. Iíll just mention it here one more time that I did not find it necessary to remove the air duct and control motor to get to the resistor like some other diys suggest. Of course it will make things a little easier but will take more time. And I did not want to spend more time on the 95F degrees evening sweating in the footwell of the car. So here is the pictorial guide:
Old 07-24-2010, 09:03 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Very nice as always. Thanks.
Old 07-25-2010, 03:23 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: e46 ZHP
Very clear and cleanly done! I will definitely come back to this when it's time.
"Common sense is the collection of prejudices acquired by age 18." ~ Albert Einstein
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 07-25-2010, 07:40 AM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
Very nice work, enjoy all your constant cool air this summer
Old 07-25-2010, 09:01 AM
Ryans323i's Avatar
Ryans323i Ryans323i is offline
Little Miss Ry
Send a message via AIM to Ryans323i
Mein Auto: 1999 3pedal 323i
Thank you! And bookmarked!
Old 07-25-2010, 10:05 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
I vote for a new title of Chief DIY Illustration Guru.
Great job as always...thank you.
PT
___________________________________
Old 07-25-2010, 12:34 PM
Haha, I just like to take pictures of my repairs when they come up
Thanks everybody for comments. I'll need to include some other good FSU links for those who decide to remove the air duct. It's a couple of extra steps from what I've read.
Old 12-18-2011, 08:59 PM
bobbiejohn bobbiejohn is offline
Mein Auto: 1997 540i
Starless,
Thanks for the innformation on the FSU. I had the ssame thing happen to me with my CFO in the car on the way to the airport!
I'm also from St. Louis. Do you have an indie place that you use for serious repairs? Dealer is way expensive!
Old 12-18-2011, 09:31 PM
Originally Posted by bobbiejohn View Post
Starless,
Bavarian is an awesome indie shop. Reasonable rates, honest knowledgeable mechanics. Can be opinionated about certain things and stubborn, but I have yet to see a mechanic who would not be... They have 2 locations now, in Olivette and in Manchester. Highly recommend them. They have a very good reputation in stl.
Old 07-25-2010, 02:05 PM
C-Bear C-Bear is offline
Mein Auto: E46
To the wiki we go?
Old 07-25-2010, 03:40 PM
Originally Posted by C-Bear View Post
To the wiki we go?
I'll link it there later Thanks!
New FSU definitely solved the pulsating/interrupted air stream problem. Cause it started getting annoying...A lot of maintenance still ahead...
Old 03-07-2011, 09:39 AM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
Mine started having the same problem on startup...I can hear the fan speed pulsating, and then it will work ok....wonder if its the same problem...
Old 03-15-2011, 05:22 PM
BlackThunder BlackThunder is offline
Mein Auto: 330Ci
Is there anybody that had the case that a faulty blower motor caused a faulty FSU blower motor resistor? I am asking because I am suspicious that blower motor would be in bad shape or the fuse for the blower motor was replaced and upgraded to a higher fuse capacity (ie. from 20amp to 40amp) just to keep the blower running.
Old 03-15-2011, 08:09 PM
I don't know fact but there have been MANY who 'suspected' the blower motor actually blew the FSU (in some cases, multiple FSUs).
For example, see this from a couple days ago (03-11-2011):
- Heater motor issues?
I have replaced the 'FSU' 3 times now. The garage says the 'FSU' is OK and that the 'heater motor' is broken and that the 'heater motor' destroys the 'FSU'.
In the the VERY best of E39 Links, you'll find more details:
- FAN CONTROL GOES HAYWIRE: poorly ventilated final stage resistor/final stage unit (FSR/FSU) modules that are practically sure to go haywire due to poor heat-sink design (1) (2) (3) (4) (5) (6) (7) (8) ... Autopsy (1) (2) often causing the battery to drain overnight (1) (2) (3) & how to isolate and replace the blower motor (1) (2) (3) (4)
Old 04-20-2011, 08:23 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
So is this BEHR product a good part to change the oem with?
Blower Motor Resistor (Final Stage Unit) for BMW vehicles
Zoom in
Name: Blower Motor Resistor (Final Stage Unit)
Part Code: 64 11 6 920 365
Brand:
Description: A/C Heater blower motor resistor (aka final stage unit).
Price: $64.90
Quantity: ******* style="WIDTH: 30px" id=ctl00_Zone1_tbQuantity value=1 maxLength=3 name=ctl00$Zone1$tbQuantity>******* style="BORDER-RIGHT-WIDTH: 0px; PADDING-LEFT: 10px; BORDER-TOP-WIDTH: 0px; BORDER-BOTTOM-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px" id=ctl00_Zone1_btnAddToCart alt="Add to Shopping Cart" align=absMiddle src="../App_Themes/default/Images/btnAddToCart.gif" type=image name=ctl00$Zone1$btnAddToCart>
Old 04-20-2011, 04:23 PM
^^^ Yes, the BEHR unit part # ending in 0365 is a good FSU.
Old 07-25-2010, 03:34 PM
maviduya maviduya is offline
Mein Auto: E38, E46, E92
starless,
i've replaced the fuse for the blower motor three times today and the only DIY that i did was to disconnect the power window motor on the front passenger side. i've checked all the wires in that door and none are exposed.
i'd like to confirm that a faulty blower resistor pack (aka FSU) would lead to multiple blown fuses...
more background material: the lights on the IHKA panel turn on with the key in the pre-ignition position...just no air from the vents...
thank you in advance!
mark @ san antonio
Old 07-25-2010, 03:47 PM
Originally Posted by maviduya View Post
starless,
mark @ san antonio
Not sure about fuses, mine never blew...
The IHKA lights working and no air is definitely the FSU. Is it only with the key in pre ignition? What about when the car is running?
Old 07-25-2010, 04:06 PM
akhbhaat akhbhaat is offline
In vino veritas
Mein Auto: German Civic
I performed this job in my old 323i, and this is really a top shelf DIY. The photos and description are excellent. Nice work.
Hopefully, you won't have to worry about this again. The FSU design was revised twice, I believe. All I can tell you is that my 2005 got the newest version of the part from the factory and has not once had FSU issues even at 5.5 yrs/62k miles, whereas my 323i had it twice in 7 years/75k miles (first at 2.75 years/20k miles, second at 7 years/75k miles). I do believe the part installed during the first repair was the same as the original, because I don't think it had yet been revised even once at that point.
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
Old 07-25-2010, 04:46 PM
both...
starless,
you asked: "Is it only with the key in pre ignition? What about when the car is running?"
answer: BOTH...the fuse blows when i turn on the A/C in pre-ignition AND when i turn on the A/C when the engine is running.
thanks!
mark
Old 07-25-2010, 08:02 PM
Is it fuse 28?
starless,
thanks!
mark
Mark, there is a BMW TSB concerning your problem. Here is the link:
http://www.bmwtis.com/tsb/bulletins/...p/B641005g.htm
So, I'd research the "e-box fan" version discussed in the document.
Also, read these threads on e46F:
http://forum.e46fanatics.com/search....rchid=15113165
One guy in the thread below claims that FSU solved his blown fuse problem:
http://forum.e46fanatics.com/showthread.php?t=687597
Keep us updated!
EDIT: In TSB I believe they are talking about part # 5 in this diagram:
http://www.realoem.com/bmw/showparts...=12&fg=35&hl=3
Part #5 cover with blower. There are 2 part #s, one for manual , second for autos.
And IF this is indeed the cause of the short, then this thread has instructions how to change the "e-box fan"
http://forum.e46fanatics.com/showthread.php?t=291383
Old 07-25-2010, 10:06 PM
jcatral14's Avatar
jcatral14 jcatral14 is offline
Running around in circles
Mein Auto: E46 ZHP
Thanks for taking the time to put this together Alex. Excellent DIY
Originally Posted by akhbhaat View Post
...2005 got the newest version of the part from the factory and has not once had FSU issues even at 5.5 yrs/62k miles...
Great news
2005 Imola Red 330i 6MT, ZHP, ZCW, Xenons
2014 Blue Water X3 xDrive28i ZCW, ZLP, LUCZ
Previous Bimmers
2007 Mystic Blue 530i - ED 12-15-06
2003 Grey Green 330i
2003 Electric Red 325iTa
Angular velocity is where it's at
-Jay
Old 07-26-2010, 03:12 AM
stupid mistake...
starless,
i discovered the reason for my problem...remember how i said that i worked on the passenger power window? the fuses that control window lift are #48 and #49. the fuse that kept blowing was #50.
#49 is supposed to have a 5 amp fuse and #50 a 40 amp fuse...
here's what happened: when finishing up with the DIY on the window, i transposed the fuses...i put the 5 amp fuse in #50 and the 40 amp fuse in #49.
i discovered this when, as a last-ditch effort before ordering the resistor pack, i checked each and every fuse for correct amperage.
THANK YOU for sticking this out with me and for answering my questions...
naturally, i feel really dumb...next time, i'll be more careful...
mark @ san antonio
Old 07-26-2010, 12:35 PM
Alex Phillips Alex Phillips is offline
Mein Auto: 2002 325CI
Starless,
I have had a problem with the AC/Heater air flow being inconsistent when the fan speed is in the middle range (not low and not high). The AC airflow seems to be like a rollercoaster almost shutting off and then revving up a little when in the middle range.
Could this be the blower motor resistor? If it is, I'd like to DIY. Your instruction guide looks very good. My car has almost 90k and is 8 years old.
Old 07-26-2010, 01:01 PM
Originally Posted by Alex Phillips View Post
Starless,
Alex, yes, this is your blower motor resistor for sure. Classical symptoms. Let me know if you have any questions how to diy.
