Old 08-19-2010, 07:24 PM
TexasBMW's Avatar
TexasBMW TexasBMW is offline
Mein Auto: 08 X54.8 04X54.4 00E46CiC
Thumbs down 0-60 is N/A from BMW NA!!
According to BMW NA, they do not have a 0-60 or top speed on either the 535i or the 550i. The 528i goes 0-60 in 6.6 seconds.
I received the following from BMW NA:
Thank you for contacting BMW of North America, LLC.
At this time, we do not have any information to provide regarding your inquiry. We suggest staying in touch with the following product resources for updates:
Our website www.bmwusa.com contains information on our Concept Vehicles and Future Vehicles under the “All BMWs” section. Here you can catch a glimpse of the latest Ultimate Driving Machines scheduled to join the family. The sales team at your local authorized BMW center is available to provide you with product availability information. A list of our authorized BMW centers categorized by name, state or ZIP Code can be found on our website at under “Dealer Locator.”
I know the 550 should be under 5 seconds, but no official word... It would help me make a decision between the two 5ers and the 7 series. It's just amazing how much marketing BMW has for the launch of its #2 seller, but no 0-60 for a performance auto!!
2013 X5 5.0 Black 02/13
2008 X5 4.8 Space Gray/Tan/Dark Burl - Delivered 01.30.08
2004 X5 4.4 Silver. Acquired 02.12
2000 E46 Vert
2001 X5 4.4, Ret.
Old 08-19-2010, 11:30 PM
XDevil XDevil is offline
Mein Auto: 550i
The only result I have found online was 4.4 seconds. Not sure how reliable the source or result is.
Old 08-20-2010, 02:10 AM
enigma's Avatar
enigma enigma is offline
Fight On!
Mein Auto: BMW M3, Z4 M Coupe
Your purchase decision is based on the published 0-60 numbers?
By the way, 4.4 is very unlikely unless it was going down hill.
BMW CCA Member #xx4477
2006 Z4 M Coupe (e86) 6MT
2013 M3 Coupe (e92) 6MT
Old 08-20-2010, 04:35 AM
Feco Feco is offline
Mein Auto: E60 530i
According to BMW Brasil website:
535i - 0-60 mph ( 0-100 km/h) = 6.1
550i - 0-60 mph ( 0-100 km/h) = 5.0
http://www.bmw.com.br/br/pt/newvehic...ical_data.html
Old 08-20-2010, 06:39 AM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
BMW is typically conservative. I have not seen stats on 550 i yet but Car & Driver got the following numbers for the 535 i in their August 2010 comparison test that included the Audi and Infiniti:
0-60 mph: 5.4 seconds
1/4 miles: 14.0 seconds @ 100 mph
Based on those numbers I am guessing that the 550i should be in the high 4.0s.
Old 08-20-2010, 06:44 AM
tadtaggert tadtaggert is offline
Mein Auto: M6 F12
Autobild did some tests in the comparison of the 550i to the E550, S6 and the Jag.
550i came in at 5.0 for 0-100km/hr which is about 0-62mph. Puts the 550i at maybe 4.8, more like 4.9.
There was some reported testing on the Alpina B5, at just over 500hp the B5 came in at 4.7 0-100km/hr.
Old 08-20-2010, 09:26 AM
richschneid richschneid is offline
Mein Auto: 2015 i8 Tera World
I don't trust any of the "published" 0-60 times except for Car and Driver or Road and Track. In doing comparisons among vehicles I only compare numbers obtained by the same publication. I think C&D is a tick faster than R&T.
C&D tested the E60 550i at 5.0 seconds. The F10 weighs around 300 lbs more or an increase of 7.5%. The F10 has 407 hp compared to 360 for the E60 or an increase of 13%. So, the F10 should be faster. Even more important in low speed acceleration is low end torque. Here the difference is much more dramatic. 360 lb ft for the E60 at around 3400 rpm. 450 lb ft for the F10 at ONLY 1750 rpm! This is an increase of 25%! And at a much lower rpm. This will make the F10 MUCH faster 0-60 than the E60. If the E60 is 5.0 sec, the F10 should come in at around 4.6-4.7 sec in the C&D road test. The xDrive version should be around 0.1 to 0.2 seconds faster as it was on a recent comparison test between the 750i vs the 750i xDrive.
BTW, C&D tested my E39 M5 at 4.7 seconds and it weighed 4000 but only had 369 lb ft of tourque. So, the F10 550i should be about the same or a touch faster.
2015 i8 Tera World Protonic Blue
Old 08-20-2010, 10:09 AM
TexasBMW's Avatar
Nope, but it is a factor when deciding to spend between $60-110,000.
2000 E46 Vert
2001 X5 4.4, Ret.
Old 08-20-2010, 09:49 AM
solstice solstice is offline
Mein Auto: 2015 F80 M3
It's amusing to see people speculate using weight, torque and hp compared to other models and coming to conclusions of times down to tens of seconds. Have you forgotten that the F10 has a new tranny? Forget you calculations and wait for the tested numbers. The tested numbers of the F10 535i is the only one that could give you an idea. It will be faster but how much is a guess at best.
Old 08-20-2010, 10:16 AM
TexasBMW's Avatar
Thumbs up
Thanks guys, sometimes it's just fun to try to back your way in to an answer. Of course, this isn't a linear equation, but hey, it's always interesting to see if you are correct, or close! After all this, I'm going to guess 4.8s +/- .2s should cover it!
Thanks for the data - all great!
2000 E46 Vert
2001 X5 4.4, Ret.
Old 08-20-2010, 11:23 AM
jwrtiger jwrtiger is offline
Mein Auto: 2011 528i
Just an FYI when I picked up my F10 two weeks ago the CA gave me the new BMW 5-series brochure. On page 33 of the brochure they list some of the tech specs: 550i 0 to 60 mph in 5.0 seconds, 535i 0 to 60 mph in 5.7 seconds, and 528i 0 to 60 mph in 6.6 seconds. As pointed out I would only take this as a general guideline of performance.
Old 08-20-2010, 02:38 PM
An eight speed transmission will be faster 0-60 than a 6 speed. Check out the actual torque multiplication in first gear, ie the first gear ratio times the final drive ratio. It is quite accurate to do these calculations to do a COMPARATIVE analysis. It would not make sense to try to derive the actual 0-60 time from analyzing these variables. That's why I said you have to compare only those numbers from the same publication. C&D is almost always at least 0.3 seconds faster than the BMW published time. You also have to look for differences in the cars tested, eg tire size. But all things being equal this analysis almost always works.
Old 08-20-2010, 11:18 AM
Emilner Emilner is offline
Mein Auto: 2013 SL63
I would guess the numbers would be 4.7-4.8 for the RWD and a tenth or two quicker for the AWD just based on the E60 numbers and after test driving a new 550i....
Old 08-25-2010, 11:04 AM
TexasBMW's Avatar
Official Numbers
I obtained the below times from a "BMW Group University" which teaches SAs about the launch of the 5, and compares the 5 to the Mercedes E550, E350 and Audi A6 3.2. The print date was 4/1/10, so early produciton...
528i: 6.6 Seconds
535i: 5.7
550i: 5.0
550ix: only gave the RWD version of the car time
2000 E46 Vert
2001 X5 4.4, Ret.
Old 08-29-2010, 08:20 PM
bikerboy bikerboy is offline
Mein Auto: 2011 550ix Sport
Maybe this will help. Before my current 550i, I had a 2005 Mercedes E55. It had 470 hp. It seemed that everyone on the road wanted to race me. It was really quite amazing. Porsches, Corvettes, Vipers, a Ford GT. The only race I lost was the Ford GT. I knew he'd blow me away. But it was fun. Mind you these were not long races. Just your common street stuff. The car had huge torque besides the horsepower. I jumped ahead of everyone because of the torque, which was 450 lb.
If you get a 550i and have Dinan install the re map mod (approx. $2,000) this car will be faster than that E55. More horsepower AND more torque. So if speed is what you're looking for, there it is.
Old 08-30-2010, 01:44 PM
Mein Auto: M6 F12
Road and Track has a comparison of the 750i vs. LS 460, they quote the 750i as 0-60 in 4.9. I can't imagine the 550i not being at least a bit faster, so maybe it's faster than what I expected (which was about 4.9).
Old 08-30-2010, 03:41 PM
Thanks for the reference. In additon to the additional weight of the 750i over the 550i, the 7 was tested with the 6-speed transmission. The 550i has an eight speed. This should cut even more time from the 550i. So, the estimated 550i times should be around 4.6-4.7 seconds which is just about what my E39 M5 was, ie 4.7 seconds. The 550i xDrive should be around 0.2 seconds faster.
Old 08-30-2010, 04:51 PM
samsonitep samsonitep is offline
Mein Auto: BMW
how the hell is the x5 50i the same speed 0-60 as this v8 model?
0-60 5 series
