F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
K&N Air Filters
Hi,
I plan to replace my F10 air filter with K&N air filter.... does anyone know where can I locate the air filter on the F10?! http://assets.clickmotive.com/ail/st..._050.jpg?w=530 THX |
Curious...what are you hoping to gain?
Exactamundo!
Been there....done that! Not worth the effort with respect to any slight gain and as stated previously ...poorer filtration
2011 535I Dark Graphite, Sport, P 1&2, Cold, 8spd, CA |
http://www.knfilters.com/filtercharger.htm My brother uses 2 K&N air filters in his Infiniti FX50S, and he loves them....he says he will never go back to his OEM filters. So.... anyone knows where can I locate the F10 air filter?
That being said, with the new strict CAFE requirements on mpgs it is hard to imagine there would be a way to just bolt on an airfilter in an existing box to gain hp and mileage. It was certainly true a decade ago, but since then the manufacturers have aggressively wrung those easy to find hps and mpgs out of the cars. That is why todays filters are so much bigger and often have 2 vs 1 filter. You also run the risk of filter oil clogging the sensors which do void engine malfunctions when they are proven to cause the problem.
2012 650i convertible, titanium silver, vermillion red, M sport, IAS, ARS, premium sound w/B&O, cold weather, drive assistance, luxury seating, 20's, leather dash, ceramic controls, BMW apps. 2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... 2010 Escalade ESV Platinum nuff said.... 2011 550ix (gone) |
OEM stuff are not optimal so you keep getting back for replacements it already compared OEM with KN http://www.knfilters.com/dynocharts/33-2970.pdf the filter is not about power, but better ventilation and air flow ...it's also more $$ than the OEM, and you dont' need to change it for life |
Also the cost of the K&N over stock makes the "save money change it for life" argument, mute, since it would take you 10 years to be on the + side of that monetary equation. Assuming you keep the car that long. |
![]() But BMW covers the replacements for the first 4 years or 40,000 miles.??? I get that you want to change your filter, and good for you it is after all your car - but don't make the argument that BMW cheaps out on air filters or that "Use it for life" saves you money. ![]() (BTW - Agree with the post - if you don't know where its at - maybe you shouldn't change it yourself. Also be careful that when you take your car in for scheduled maintenance they don't check the air filter and ding you for non-oem) Now can can anyone tell this guy where he can find the air filter?
2013 535i Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD Redelivery-12/14/12 Last edited by miamiboyca; 01-28-2013 at 08:20 AM. |
2011 550ix Alpine White, Black, 775, ZSP, ZDH, ZP2, 2TB, ZCW 2013 X5 35i Premium, Conv.pkg., Prem. sound, multi contour seats, cold weather pkg. Porsche 997 GT3 Porsche 993 Cab Porsche 996 Turbo (Ruf 550) gone but not forgotten . |
There is always "some Power" to be gained by this method regardless of Turbos or Naturally aspirated. Last edited by johnbmw6; 11-04-2010 at 11:19 AM. |
An ECU re-map will, especially on a turbocharged car produce HP/Torque gains but will void your warranty.
Perhaps one who is unable to locate the air filter should not be replacing same?
Just a thought. My advice... Stay away from K & N filters, you're just asking for trouble.
"Money is a strange business. People who haven't got it aim at it strongly. People who have it are full of troubles." -- Ayrton Senna BMW CCA Member |
Oil from the filter (if over oiled and not properly dried) will damage the mass air flow sensor. Be careful.
I did use the BMC filter on the M3 and it did give some BHP about 4BHP and increased the induction noise, it did sound nice with the remap. I will not go this route with the 550i M sport though
Dinan wont void warranty and adds 95hp. 100 ftlb torque its 3000
Sent from my Nexus One using BimmerApp |
Are you saying that BMW supports the Dinan modifications. If you can get that in writing then go for it.
Emimix,
Did you end up buying the K&N air filter? if so, did you notice any gains or better air flow? I believe in K&N as i used to have it in my Accord back in the day. It definitely breathe better.
2012 535i Alpine White | Oyster Black Dakota Interior | Dark Wood Trim | M-Sport Pkg | Premium Pkg | Tech Pkg | Heated Front Seats | SAT | BMW Apps | Born on 1/30/12 Gre8tW8LL Last edited by Gre8tW8LL; 01-27-2013 at 01:43 PM. Reason: grammar correction |
I tried K&N once a long time ago. I did used oil analysis, too. The ppm silicon (dirt) in the used oil analysis nearly tripled after the K&N - - almost to the labs condemnation point around 20+ ppm IIRC. I never used one again. The K&N does reduce the inertia of the air column in the intake track (removing the filter altogether does, too) which gives you a feeling of a more sensitive throttle response, which in turn is mistaken for more power. But it's all smoke and mirrors, pure illusion.
By the way, BMW does recognize DINAN. Many BMW dealers are also DINAN dealers and DINAN warranties their mods/software. If the dealer updates your factory software/ecu when you have the car in for service (which they do all the time and which will wipe your DINAN), and if they're a DINAN dealer, they will reload whatever DINAN performance stage you have at no charge - - it's part of the DINAN warranty. Don't think other mod houses do this. Last edited by m6pwr; 01-27-2013 at 02:16 PM. |
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats |
I was thinking about it, but I know from Mercedes and now apparently BMW, K&N filters don't do much except add more risk and throw the "balance" off, per-se. Seems these motors are engineered to a degree where a K&N won't help at all (maybe hurt?). I wouldn't mind extra induction noise especially from a Turbo, though. At the same time, I love the quietness of this car where you hear some deep engine noise around town (subtle and "pleasant"), but only "truly" hear it when you get on it, nice balance IMO.
'13 F10 BMW 535i ///M Sport : Jet Black/Black-Anthracite : Premium & Technology Packages/Sport Auto Trans/Camera/Park Distance Control/Heated Seats/Tinted Windows/Blacked Out Markers/Performance Spoiler. Ex M-B's: '11/'10/'06 E350's w/ AMG Sport Package, '02 S500 w/ Every Option.
#25
back in my C5 A6 days putting in a K&N was a no-no due to problems with sensors, like MAF.
i can't see sticking one of those in and incredibly expensive machine like at 550. nake oil imo.
12 550xi Dark Graphite Metallic II. Convenience, Cold, Driver's Assistance, Premium Sound, Sport, BMW Apps Previous BMWs: 11 535xi 11 328xi 08 535xi 08 335xi 07 525xi |
