Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 11-04-2010, 11:32 PM
Nickh Nickh is offline
Mein Auto: Corvette, 740iL, 328i
Windshield trim
The windshield on my 01 is still good, no wind noise, no leaks.
But the black rubber/plastic trim surrounding the windshield (esp the top, near the roof) has cracked & has chunks missing, gaps.
Question is that can I just go to any glass store (auto glass) to have them replace the trim at a reasonable price, or do I have to go to BMW dealer to have the whole windshield taken out to replace the trim?
Thanks,
Old 11-05-2010, 04:15 PM
dseemgoblue dseemgoblue is offline
Mein Auto: 2000 740il
Nickh
Please post when you resolve as I have to do the same with mine. I get the most annoying buzzing sound around 65mph coming from the windshield.
Old 11-07-2010, 11:15 AM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
You can buy that rubber strip & replace it yourself. It just pulls out & the new one (maybe with a little help from a slight amount of soapy water) pushes back in without removing the windsheild.
I know there is at least one write up on the e38 forum of BimmerBoards. Not to difficult to do.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, Alpine DVD changer with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 11-07-2010, 10:40 PM
Do you know where to buy that rubber strip?
How much?
Link?
Old 11-08-2010, 04:22 AM
smilford smilford is offline
Mein Auto: '07 328Xi, '89 325ix
I bought one a couple of months ago from our local BMW dealer. With the BMWCCA discount, it was $37 or $38 as I remember. Haven't gotten around to putting it in yet, but there are a couple of DIY's on the topic and it does not look too hard - although I'm afraid I'm going to suffer from some complications related to an improperly installed windshield. We will see.
Old 11-08-2010, 09:11 AM
Thanks,
Just called my local BMW dealer parts dept, Yep, they have it in stock, part #51317172022, cost $33. He says it's double sided tape, peel & stick. He's not sure about whether we can do this ourselves, or have the dealer install it... Does anyone know? It just sounds too easy...?
Old 11-13-2010, 12:43 PM
Replace the upper trim on my windshield and I am still getting a lot of wind noise and it is getting worse. There are crackes in the lower trim as well. Could this be the cause? Is it something I can replace? I read a post on bimmerboard and it talked about the winshields on these cars are very tempermental and must be positioned with exact measurements. There is even an 11 pages of instructions on how to do it that they advise giving to the installer. I would love to be able to fix without replacing windshield. Any ideas??
Old 02-27-2012, 09:19 PM
tresk tresk is offline
Mein Auto: 2001 BMW 740iL
replace windshield upper molding
Hi guys,
I just replaced this upper trim on my 2001 740iL. Picked up the piece from my local BMW dealer for $45 or something like that. Took me about an hour to finish the whole job. I put the instructions with photos on my site - hope it doesn't get filtered out: replace windshield trim
Old 02-28-2012, 04:52 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Well the trims upper and lower are just finishers. It is known that if a replacement screen is not postioned correctly, then you will get wind noise...
Old 11-25-2012, 01:33 PM
utfootball4 utfootball4 is offline
Mein Auto: 325i
Good stuff....
Old 11-25-2012, 04:00 PM
seamus2154 seamus2154 is offline
Mein Auto: 2001 740I Sport
I have a 2001 and just before I bought it the PO had the windshield replaced. Top trim is new and the sides look pretty new also. 11 pages of instructions?? I have wind noise but have no reference point as i bought it with the new windshield. The side strips are up off the glass with a gap. is that normal or is it supposed to be flush to the windshield??
Old 12-02-2012, 11:37 AM
DIYs for the windshield trim to solve noise problems:
- The main causes of bimmer wind noise, from the BMW TIS on missing jack pads (0) (1) (2) (3) or from a crumbled windshield cover molding gasket (1) (2) (3) or from a badly replaced windshield (1) or from the door weatherstripping (1) or from the cabin air filter housings (1) or loose sunroof drainpipes inside the A-pillar (1) and how to test window glass wind noise by taping the windows (1) (2)
Old 12-06-2012, 05:16 AM
wattbmw wattbmw is offline
Watt
Mein Auto: Black, 2000, 740i
Just ordered the trim. Thanks for the part number. Will post photos of installation.
Old 12-09-2012, 09:33 PM
Watt
Installed my windshield trim using Nickh's posted instructions. Using the petroleum grease truly was a major help as I tried without using it first. I have not drive the car yet to see if noise is reduced. Next big task is changing the filters under the dash, but that is a different post. Thank God for my fellow BMW enthusiast.
