BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
Recently bought a new 2011 335d and during the past 4 months of driving, I have the "Service Engine Soon" check engine light come on three times already with less than a total of 5000 miles on the engine. The first check engine light came up at only 2000 miles!
Each time the dealer says it is a #4D35 fault code from the Reducing-agent metering valve. The first time they cleaned it out to clear the code. The second time they replaced the valve, but the code still came back 6 weeks later. The third time (this weekend), the dealer cleaned the valve again. What is going on??? Seems like the 335D is a lemon with some major design issues with the diesel system. Anyone else have this problem? I'm starting to regret getting the 335d.
It is your choice how to proceed. I know from personal experience that if you have the requisite number of failed repair attempts and have met the written notification requirement, the CA Lemon Law will produce results. |
Johnson,
The 335d is in no way a "Lemon". You however may have an isolated problem that I am sure a competent dealer service department should be able to resolve to your satisfaction. I agree with AN above. If you feel the service folks are just not "getting it", try another dealer in your area. Very few of us have experienced any issues with our DEF system thus far. A few were never properly filled up from the delivery. Good luck and hope you can get it resolved so you can enjoy the car. |
I had that code few times but only once it trigger SES (dealer checked the valve - and no parts were replaced at the time). As any code it needs to be there for number of cycles - if it clears itself indicating not present condition over allowed amount of cycles it will not trigger SES. 4D35
AnE934fun is absolutely right about un-experience of some dealers.
T ![]() 2010 335d e90 Flickr300, LCAD, ZPP, ZSP, 2XA, 302, 465, 494, 4B9, 609, 655, 677, 6FL, 6NF |
335d
if they change the delivery module, they will keep the car and drive it and then check it again. They put 100 miles on my car. Hmmm!
Definitely try another dealer, most of my piss poor experiences with this car are 100% related to dealers not knowing how to work on it.
--Aaron |
For lucky best wash use Mr. Sparkle. 2010 335d |
7800+ miles on my 2011 335d and not a problem one---- except--- how to wipe this **** eating grin off my face every time I put my right foot down!!!
11 335d 2010 S1000RR 08 K1200GT 08 WR250R |
I have a new 335d and have started working with the check engine light problem. This thread is very helpful. Has everyone finally solved the DEF problem?
4D35: metering valve is clogged/partial clog due to crystalized DEF. Dealer should check the valve to see if its work. They will flush it with warm water, if doesnt work then they would do warranty replacement of the SCR Metering Valve. Part # 18-30-7-807-206.
Copying this info from another 335d owner met him on dealer service bay who also had same issue and his work order said this info Last edited by bimmerdiesel; 11-28-2010 at 07:42 AM. |
Where is the metering valve physically located? Is it something we can easily replace ourselves, post-warranty?
2011 BMW 335d, Space Grey/Black, Sport, Premium, Cold Weather, Convenience, Nav, Harman Kardon/Sat, iPod 2010 Audi A4 2.0 Quattro P+ 6MT (Wife's car) 2004 BMW R1150RA |
Post-warranty on a 2011 335d? How could that be?
he meant after 4yr/50k miles
I was just reading earlier today on a MB forum that with their DEF systems they are supposed to be topped off I think it is every 10k miles and then flushed every 20k miles. The stated reason for the flushing though was to break out or avoid any crystalization issues. Wonder how valid of a reason that is and if it is valid then why they stopped draining and refilling the DEF during oil changes for these cars and now only top off.
--Aaron |
Updated SIB160109 does not require purge of DEF anymore and don't see any reason why BMW dealers would do otherwise unless some other condition requires it.
See, the one oil change I got is back when they always drained and refilled. So now I wonder if next month they will do the same since that will be the second oil change for the car
--Aaron |
Flush or just drain
Need to check up my invoice again what they did. I assume they should do flush else its no point.I got drain-refill on 2nd oil change so you too should get same for your d. |
When mine was done it was a drain-fill and not a flushing of any sort. At least when the process was explained to me, that is what I was told.
--Aaron |
NOPE no written confirmation. I tried searching varios SIB but nothing concrete. What i said is partially my speculation and my SA's word. During my 2nd service (not aware of new service rules) I blindly thought they would do drain and refill. Then someone in another thread mentioned under new service rules he got top off on 1st service. My invoice said they did drain-refill. To confirm I called up my SA if they bypassed rules to make more money. He said they do drain-refill on 2nd service and my speculation is that they will do it on 4th service as well.
335d needed a new delivery module and metering valve cleaning for check engine light at 7000 miles
#25
335d
great car to drive and great mileage
