Old 11-18-2010, 07:59 AM
batym batym is offline
Mein Auto: X5 11
'11 X5, doors don't close well?
Hi - took delivery of '11 X5, 5.0 and immeditely noticed that doors have to be slammed (sometimes several times) in order to close properly. Spoke with the dealer and he mentioned that car is new and need to settle in. This has been annoying, especially that I don't get warning that door not closed properly until driving 2-5 seconds.
Has anyone else experienced this?
Old 11-18-2010, 08:15 AM
swamyg1 swamyg1 is offline
Mein Auto: 2011 x50i on Order
I too have also noticed this! It's something I have to get used to I suppose. At least the indicator tells us which door is open, as long as it's not the baby's door I guess I'm ok haha.
Old 11-18-2010, 08:22 AM
Havelcek Havelcek is offline
Casual Fan
Mein Auto: 2011 X5
Yes, the doors on my new X5 need to be shut "enthusiastically".
Old 11-18-2010, 08:47 AM
Mein Auto: X5 11
I guess something I have to get used to. Also noticed that when trunk auto closes it slams it pretty hard. Quite a difference from japanese cars.
Old 11-18-2010, 08:55 AM
alex123 alex123 is offline
Mein Auto: 2014 F01 750ix CarbonBlck
+1
2017 G12 750ix MSport Carbon Black - on order
2014 F01 750ix MSport Carbon Black
2010 E90 328I Alpine White
Previous BMW's
2011 E70 50 MSport Carbon Black
2008 E60 550i sport Alpine White
2005 E60 530i sport Black Sapphire
Old 11-18-2010, 09:03 AM
Rosmoss Rosmoss is offline
Mein Auto: 2011 X5 50i M Sport
I was irritated by the fact that BMW Canada bundles soft close doors into the same package that includes things I actually wanted (pretty much the only standalone option on the 50 is HUD) but now I guess I'm glad I have them. If only there was a reason not to be irritated that I also had to get the roll up side screens....
Old 11-18-2010, 09:15 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Mine is the same, takes a good slam and 2 months later, it didn't get any easier, just have to get used to it I guess!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 11-18-2010, 09:57 AM
panic75 panic75 is offline
Mein Auto: X5d
Glad to know I'm not the only one to experience this! We picked up our new X5d on Tuesday and one of the first things I noticed was how difficult it is to close the doors ("enthusiastically" is a great way to describe it). Even the CA, while giving us the tour of the new ride, had to try a few times to get it to close completely. I'm also curious as to whether or not this might become easier over time.
Old 11-18-2010, 10:06 AM
SkipSauls SkipSauls is offline
Mein Auto: 2011 X5 xDrive35d
Open one of the rear windows a tiny bit and then try shutting the doors again. If they're easier to shut then it's likely that the tight seals on the X5 are the problem. I had a 2001 X5 with doors that felt very similar to the 2011 I just got. The 335i e92 that I traded in had frameless windows that made the doors easier to shut, but the sound that they made was far more unpleasant when someone slammed them.
You can train yourself to pull the doors shut without slamming them, but you'll find that most passengers will slam away no matter how nicely you ask them not to.
Old 11-18-2010, 10:11 AM
rtcage rtcage is offline
Mein Auto: X5 Soon
Yep, my guess is that is has to do with how air-tight the car is. Opening the windows and closing should confirm that. The benefit of this is the quiet ride.
Old 11-18-2010, 10:17 AM
Aqua Bliss Aqua Bliss is offline
Mein Auto: e92
C'mon ladies put a little muscle in it!
Old 11-18-2010, 10:19 AM
bobamoo bobamoo is offline
Mein Auto:
Hmmm..have not noticed this. Maybe I have been closing doors on other cars too hard?
Old 11-18-2010, 04:09 PM
Jim E.'s Avatar
Jim E. Jim E. is offline
Mein Auto: 99 M3, 11 X5d, 16 328d XT
Makes me happy i ordered soft close doors. I never knew this was an issue.
Old 11-18-2010, 04:46 PM
53K 53K is offline
Mein Auto: 2011 335i
I don't have this problem with my X5. The doors close very smoothly.
My previous car, e46 coupe, had a similar issue with the passenger door. It needed to be shut 'enthusiastically' and it never got any better during 8 years of ownership. My female friends almost always had to close it more than once. It would have bothered me quite a bit if it was the driver's side..
Old 11-18-2010, 08:15 PM
alexmish alexmish is offline
Mein Auto: 2016 X3 35i MSport
The car needs to "settle in" is a BS!!!! All that needs to be done is to adjust the striker - the "loop"-like looking thingy on your car's body frame, onto which the door lock's latches. It has 2 screws - loosen them up about 1/2-3/4 turn, and slide the striker outwards (toward the outside of the car) for about 1mm. Re-tighten the screw and try closing the door - you will see the difference. Make sure you dont "overdo" it, as the door then will rattle a bit.
I've done one too many times on just about every car I've owned. A 2-minute job. I also use masking tape around the striker to "remember" its original position, in case I need to move it back where it was.
Hers : 2015 328xi MSport Silver/Red
His : 2016 X3 35i MSport Silver/Mocha
Old 11-18-2010, 08:16 PM
micahmiles micahmiles is offline
Mein Auto: 2008 M5, 2008 X5
This is simply an "air cushion effect" due to multiple layers of seals in the doors as mentioned above. OP "doors don't close well" is misleading, the doors close very well and seal very tight, hence the extra effort to close when all other doors are closed with windows up. The issue you must be careful of is slamming the door with normal required force while another door is open when the "air cushion effect" is not available. If you are exiting the car the same time as your spouse, the last one out of the car will think you're angry because you slammed the door!
Old 11-18-2010, 09:45 PM
ard ard is offline
Resident Curmudgeon
I wonder if there is a trade off between closing force and 'pressure on the door seal' when closed.
There is a known issue with door seals causing noise which sounds like rattles... it could be making the door easier to close might lead to less pressure on the seal and more noises when driving...
Just thinking out loud...
A
Old 11-22-2010, 03:43 AM
Marlbro's Avatar
Marlbro Marlbro is offline
UK (ex-Pat)
Mein Auto: 2010 X5 3.0d M pack
A
exactly !
2010 X5 30d M Sport pack on 20 inch
In Space Grey, Panoramic roof, auto tailgate,
Privacy Glass, Comfort seats in Black?
Rear view camera
Old 11-19-2010, 05:51 AM
nyranger74 nyranger74 is offline
Mein Auto: 2011 BMW X5 50i M Sport
Soft close doors aren't available, only on the X5M
Sent from my iPhone using BimmerApp
Old 11-19-2010, 06:35 AM
Jim E.'s Avatar
Granted that soft close doors are not a standard option. That doesn't mean you can't get them because in fact i am. Same goes for individual wood and the individual sound system that is also on my order. Was also going to get the climate comfort windcreen but you can't get that with lane departure as it turned out.
Old 11-19-2010, 07:19 AM
I would have really liked the soft close doors. Oh well I guess I should have asked.
