Clicking Noise when I brake or Accelerate
I drive a 3 series, E46 2002/03. When I am stuck in a stop/start traffic, i hear a clicking noise on the passenger side's front wheel when i brake. Similarly, when i accelerate, I get the same clicking noise front the front passenger side as well as the back passenger wheel.
The click is only once though. For example, if i was to brake, i will hear the click, and if i take my foot off the brake and then brake again (without touching the accelerator), i wont hear the click again. Any ideas what this could be? |
Check your brake pads and the caliper pins. Everything "floats" and if they are sticking, you'll hear a clicking sound. The fix is to loosen then up so they slide. If you pull off the wheels, and begin to remove the calipers and pads, you'll see how they are installed and you'll probably be able to feel the sticking and hear the clicking. gordo
300ZX StgIII (360 rwhp@16 psi) // '97 Jag XK8 - Luxor Cruiser // 325xit - Best Balance of Ride & Handling Last edited by gordo325xiwagon; 01-18-2011 at 06:33 PM. |
Does the car pull at all at highway speeds when you just barely apply pressure to the brakes?
E9 One Day It Will Be Mine |
What marinekilz means is, when at highway speeds, if you touch lightly on the brakes, does it pull to one side or the other? If it pulls to the right, then the right side is likely grabbing earlier than the left and should be where you start.
well correct, I was thinking thrust rod bushings being worn causing the noise. but checking for a sticking caliper or something in the brake system is also a good direction to go like someone else suggested
Cheers for clearing that up. It doesnt seem to be pulling any side really. I was on the motorway/highway this morning doing about 80mph and didnt feel anything when i pressed the brake pedal.
It might be your fuel economy gauge, I have a similar noise. The faster you accelerate the faster the clicking? Watch the gauge when you change throttle.
| Tags |
| accelerate, brake, click, noise |
