E46 (1999 - 2006)
Old 01-29-2011, 04:14 PM
joh99077 joh99077 is offline
Mein Auto: 323i
Question Shaking when I accelerate and check engine
So I was at a stop today and everything was fine. I started accelerating and everything started shaking and the check engine light came on. I went to Autozone to have them run a diagnostic. It came up with the following codes:
P0305 - Misfire on cylinder 5
P0441 - No purge flow detected
P1250 - PRC Solenoid Circuit Malfunction
P1478 - Evap small emission leak
What could be the problem and is it an expensive fix?
2000 323i, Manual Transmission, 105k miles.
Old 01-29-2011, 05:21 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/94 530i
I would say the biggest problem to tackle is the misfire on cylinder 5. That, however, could be multiple things- spark plug, coil, or injector. There are DIYs on how to find out which problem it is, just do a search. I cannot give any insight on the other codes... there is a chance that they may have been stored codes as well. Did you have them reset the codes?
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - LOADED
Old 01-29-2011, 08:35 PM
Mein Auto: 323i
Where is the best place to buy coil packs? Which spark plugs would you recommend? and I plan on putting some sea foam through it to clean the injectors unless someone can recommend something better.
Old 01-30-2011, 06:25 AM
Manualaholic
Check Pelicanparts, Autohausaz, Bavauto for coil packs. There are also several vendors that endorse this site that you can try looking into. When I replaced my spark plugs, I went with NGK. Once you enter year year and model on Pelicanparts or Autohausaz it will give you only plugs that will fit your car. Check out ebay for used coil packs too, sometimes people are selling stock ones after an upgrade.
I would run some Lucas fuel and injector cleaner through the system as opposed to the Seafoam. I have used Lucas and Chevron Techron before and I like Lucas just a little bit better. This may not solve the issue though- when my 5er starting throwing a misfire code, I ended up pulling the fuel rail and you couldn't even recognize the injectors from underneath all the carbon that was built up in it. I hope it's not too bad for you
Old 01-30-2011, 06:53 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Check to see if gas cap is tight
Check for vac leaks on intake tract
Change fuel filter
mujjuman
check engine light, misfire, problem, rough idle, rough when starting off
