Old 01-31-2011, 07:34 PM
Kelley71 Kelley71 is offline
Mein Auto: 2000 E39 540IA Sport
M62TU Head gasket/ Timing guides journal
Does anyone have any tricks for removing the heads on a 540i.
I have everything unbolted. I twas told I could remove with the exhaust manifolds in place but I am having trouble wrestling this out because the timing rails are in the way to get the angle correct.
Any tips would be appreciated. There is not much room to remove exhaust manifold bolts.
Thanks in advance.
Old 01-31-2011, 08:02 PM
I looked in the the VERY best of E39 Links and only saw related M54 links:
- Replacing the M54 head gasket (1) & M54 cam shaft (1)
So, when you find a good link let us know which were best so we can add them to the best links thread for future users.
Old 01-31-2011, 08:15 PM
I will let everyone know. This has been a job! I am almost to the halfway point.
I am replacing both head gaskets while I have the motor tore down.
I have to buy a tool to hold the crank. I am going to replace the rails while I have it down.
The problem is this car SPECIAL TOOLS you to death.
Old 02-01-2011, 09:49 AM
wyowolf wyowolf is offline
Mein Auto: 2004 545i Six Speed
according to ALLDATA the Ex will have to come off. You will also need the tools to retime it all, but you already know that... also looks like you have to support the Engine to remove the exhausts... strange.. but thats what the book says.
Old 02-01-2011, 06:34 PM
Well, I got the heads off today.
The passenger side head came off with the exhaust manifold on very easily.
The driver side head, well that with swivel sockets and 2x4's to help adjust the head to get to bolts, I got the exhaust manifold off. Will be a PITA to put back on.
Tomorrow morning they will go the the machine shop.
I posted some photos of the block. The motor had a lot of sludge. The previous owner said he changed the oil when the computer told him to with only synthetic oil. Yuck!!
ID:	264823   Click image for larger version
Old 02-01-2011, 08:55 PM
JBono333 JBono333 is offline
Mein Auto: 530i
Bluebee,
You are the man when it comes to snarffing up these threads. Tanks for all the help you geiv the members
JBono333
Old 02-02-2011, 11:21 AM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
you've been here long enough that you have had to have seen ketchup's sludge thread yes? That is what they are talking about, oil sludge built up in the engine.
Old 02-02-2011, 12:58 PM
I put this in the bestlinks thread long ago:
- Why sludge in the oil cap is an indication of a failing CCV (aka PCV)
But, the pictures look nothing like the sludge there:
I thought, in the pictures, there was a "mechanical" problem shown.
Is it just the 'brown sludge' from a failed CCV that is what is being referred to as potential neglect?
Old 02-02-2011, 01:45 PM
Past Sponsor
Mein Auto: e39 5
well I suppose then it's all in the eye of the beholder. I can see the sludge build up plain as day in the OP's pics.
Old 02-02-2011, 05:31 PM
I can see the sludge build up plain as day .
I guess I need to look closer!
Old 02-02-2011, 06:21 PM
Well today it was 19 degrees in Houston with the wind blowing at 25 mph.
So I dropped off the heads at
David's Automotive Machine Shop in Houston, TX. They do great work. I have been using them for a long time.
I ordered all my parts. Spent the rest of the day CLEANING parts in the shop.
I need to get the Jesus bolt out. If anyone in the Houston area has a counter hold tool or anyone has an idea building one. Let me know.
When it warms I will drop the pan, break the Jesus bolt and clean the rest of what I can on the motor getting the sludge out.
ID:	264945   Click image for larger version
Old 02-04-2011, 07:48 AM
Yesterday was the fight with the Jesus bolt and I lost. I made a tool holding 2 bolts and I broke a piece of the hub away.
My father and I are making a good tool now.
See photos below. We are almost finished. We just have to attach something to hold now.
This tool will be top class.
ID:	265142   Click image for larger version
ID:	265143   Click image for larger version
Name:	crappy toolresult.jpg
ID:	265144   Click image for larger version
ID:	265145   Click image for larger version
Old 02-05-2011, 02:04 PM
My new tool worked awesome. I have to go to work now though....
Question??
I removed the lower pan, all 8 bolts to drop lower timing cover. Removed Power steering. All front cover bolts that I could find and this lower cover WILL NOT BUDGE...
Any suggestions?
Old 11-04-2011, 06:39 PM
windsmith windsmith is offline
Mein Auto: 1999 540iT
I know that this is an older thread, but I thought I'd share my experience.
Back in 'the day' , with American cars, I'd just put a socket and breaker bar on the bolt, lay the end of it atop the frame on the driver side, and bump the starter. Worked every time. Can the crankshaft on the BMW handle that?
Old 02-06-2011, 12:45 AM
first540i's Avatar
first540i first540i is offline
my first bmw
Mein Auto: e39
did you remove the water pump for the lower timing cover?
theres another bolt in there
Old 02-06-2011, 04:25 AM
Jason5driver's Avatar
Wow!
Old 02-06-2011, 09:10 AM
Yesterday we finished building the counter hold tool. I will say my tool kicks BMW's A**. My father is a genius when it comes to manufacturing. We welded a steel plate and machined out so a one inch breakover bar will fit. I rested the breakover bar again the frame and the Jesus bolt (center crankshaft pully bolt) broke loose easily. This tool you can do it alone.
I dropped the lower pan. Found the retaining clip to one of my cam to cam tensioners. I removed the 8 bolts under the front of the upper pan.
Old 02-06-2011, 09:38 PM
Today I removed the guide rails (glad I did now), cleaned the surfaces, installed new valley pan and cover, and finished the deck of the motor.
Now I am waiting on my heads, Vanos tools, and will have my valve covers powder coated.
Tomorrow I will change motor mounts.
See photos, thanks for all the insight from all you guys!
ID:	265509   Click image for larger version
ID:	265510   Click image for larger version
ID:	265511   Click image for larger version
ID:	265512   Click image for larger version
Old 02-08-2011, 03:06 PM
Update,
Exhaust valve guides needed to be replaced on both heads. This set me back a day because no one in Houston stocked the guides.
Everything is clean awaiting reassembly.
A head gasket / timing guide job while working two jobs was more than I expected but a great sense of accomplishment when this thing is done.
Changed motor mounts today. Driver side was definitely shot .
ID:	265716   Click image for larger version
Old 02-08-2011, 04:16 PM
I'm jealous!
Old 09-09-2011, 09:27 AM
Flug540's Avatar
Flug540 Flug540 is offline
Mein Auto: 1998 BMW 540i 6-spd
Kelley, I may need to go through a similar exercise soon. I read TIS and in order to remove the lower timing cover it wants you to drop the upper oil pan as well, which is a major pain. I see you got away without removing it, which I like very much, but a bit concerned about sealing of the lower timing cover with the upper pan after installation. Did you do anything special there to ensure a good seal, have you noticed any leaks?
Old 02-08-2011, 04:32 PM
jamesthebikeguy jamesthebikeguy is offline
Has RETURNED
Mein Auto: 2000 540i/6
Ugh, that engine sludge is like no other in their eh?
Would dropping a can of sea-foam in the oil loosen any of that up you think?
Sea-foam worked wonders on the egr, and ccv on my old Mazdaspeed3
Old 02-09-2011, 11:01 PM
Today I spent the day waiting for UPS and Fedex. No one stocked valve guides so my head will be ready at 10:00 am CST.
But my valve cover were finished being powder coated.
I was told the valve covers must be baked at 400 to release any gases before powder coating. BMW uses epoxy to fill in any imperfections and powder coating has to be bare metal. But for 95 dollars my valve covers look great.
Tomorrow weather permitting I can reassemble the top half until I get my timing tools.
ID:	265940   Click image for larger version
Old 02-10-2011, 09:45 AM
Has RETURNED
Who did your powder coating? was it local or mail-order?
Old 02-10-2011, 09:48 PM
Powder coating was done by Advanced Powder Coating and Blast Services in Houston. Took 2 days. 95 dollars.
Today I got my heads back and are on the car!!
Note: Exhaust manifolds can be installed on the bench and put on the car with the heads.
Drives side you have to loosen all motor mounts the car and jack the motor up. I installed a bare head to save weight and gave me more room to maneuver. This saved a lot of time!!
Total cost of heads 533.00 for valve job, new valve seals, new exhaust guides, pressure testing and resurfacing, and cleaning.
ID:	266130   Click image for larger version
ID:	266131   Click image for larger version
ID:	266132   Click image for larger version
ID:	266133   Click image for larger version
