Old 02-05-2011, 07:50 PM
littleE46 littleE46 is offline
Mein Auto: 2002 330ci conv
DIY Complete X3 Cooling System Overhaul
I was planning on doing this as preventative maintenance in the spring but the X3 had different ideas. It started leaking coolant, luckily the engine never overheated.
Here's the parts list for a 2004 X3 3.0 automatic and the prices I paid. Total was $846.89.
11-53-3-400-207 Coolant Hose $34.58
17-12-3-413-819 Coolant Hose $57.02
11-53-3-400-205 Coolant Hose $24.33
17-11-3-400-013 Radiator $179.75
17-13-7-787-039 Expansion Tank/Coolant Reservoir $37.76
17-11-1-742-231 Radiator Cap/Expansion Tank Cap $10.82
17-11-1-712-788 Coolant Bleeder Screw; Brass $3.66
17-11-1-707-818 Water Drain Plug $4.75
17-11-1-437-361 Radiator Drain Plug $3.50
17-11-1-437-360 Radiator Drain Petcock; Adjusting Screw $5.43
17-11-1-437-362 Expansion Tank Thermostat $53.25
17-11-7-506-601 Coolant Level Sensor $17.76
13-62-1-433-077 Temperature Sensor $16.50
11-53-7-509-227 Thermostat $60.64
11-51-7-527-910 Water Pump; (Stewart High Performance) $176.70
11-28-1-706-545 Serpentine Belt/Ribbed Drive Belt $18.15
11-28-7-512-758 A/C Belt Tensioner $56.00
11-28-1-748-131 Adjusting Pulley $17.25
11-28-7-516-847 Belt A/C Compressor $24.00
11-28-7-512-762 Belt A/C Compressor $9.75
07-11-9-963-200 Engine Drain Plug Crush Washer $1.28
82-14-1-467-704 BMW Engine Coolant $31.82
Distilled Water $2.19
Most of the parts are pictured below. I'll follow up with separate posts for each section of the job.
Name:	1 - Cooling System Parts.png
Old 02-05-2011, 08:29 PM
Tools Used
Here is a list of all the tools I used for the project.
Torque wrench
Floor jack and 4 jack stands
Breaker bar
Extension bars
Speed handle
3/8" universal joint
1/2" to 3/8" adaptor
Magnetic pickup
Small pry bar
Plastic mallet
Sockets
8MM - Engine splash shield
10MM - Water pump, thermostat bolts, air box
13MM - Thermostat bolt to engine hook
16MM - Alternator tensioner pulley,
17MM - Wheel nuts
19MM - Wheel nuts with locks
22MM - Radiator adjusting screw
25 Torx - Radiator
35 Torx - Intake ducts
45 Torx - Water pump tensioner pulley, alternator deflection pulley
Might have been a few other odds and ends that I can't think of.
Old 02-05-2011, 08:49 PM
Step 1 - Jack up the car
First loosen the lug nuts on the front passenger wheel. This is the only wheel you need to remove.
Then jack up the front and put jack stands under the front jack pads. This was much easier than my E46 because there is a central jacking point at the front in the middle of the plastic engine splash shield.
Jack the back end up using the cross member INFRONT of the diff and put jack stands under the rear jack points.
Unscrew the 9 bolts holding the plastic engine splash shield using an 8MM socket. Then using a small pry bar remove the plastic expansion bolts at the back of the shield.
Name:	2 - Jacked Up.png
ID:	265302   Click image for larger version
Name:	3 - Splash shield bolts.png
ID:	265303   Click image for larger version
Name:	4 - Splash shield expanding rivets.png
Old 02-05-2011, 09:09 PM
Step 2 - Drain the coolant
Make sure the engine is cool before proceeding. If it's warm go have a break and come back in a couple of hours.
Turn the ignition on without starting the engine. The turn the heat all the way up with the fan at the lowest setting.
Remove the expansion tank cap and the bleeder screw on the upper rad hose. Put your drain pan (forgot that in my tools post) directly under the expansion tank and unscrew the two blue radiator drains. Wait until the coolant stops flowing.
Next you'll need a 13MM socket on a universal joint with several extensions so you can get to the engine drain plug behind the passenger wheel. Use a breaker bar to start the bolt then you can remove it by turning the extensions by hand. I used a magnetic stick to grab the drain plug. Put the drain pan underneath before you remove the bolt, but be prepared to move the pan as it splashes around when it hits the skid plate.
Don't forget to retrieve the drain plug.
Name:	5 - Heat up .png
ID:	265305   Click image for larger version
Name:	6 - Bleeder screw.png
ID:	265306   Click image for larger version
Name:	7 - Rad drain plugs.png
ID:	265307   Click image for larger version
Name:	8 - Engine drain plug.png
ID:	265308   Click image for larger version
Name:	9 - Breaker bar.jpg
Name:	10 - Magnetic stick.png
ID:	265310   Click image for larger version
Name:	11 - Drain coolant.png
ID:	265311   Click image for larger version
Name:	12 - Retrieve drain plug.jpg
Old 02-05-2011, 09:33 PM
Step 3 - Remove air box
Next remove all of the plastic air intake parts so we can get at the cooling system.
Start by removing the four torx bolts for the plastic intake duct at the front of the engine compartment. Remove the intake duct to get to the four torx bolts for the air duct. Before removing the air duct you need to undo the 5 clips holding the top of the square air box and the two clips holding the mass air flow sensor to the air box.
With the air box loose you can separate it from the air duct and remove both of them.
Using a 10MM socket remove the two bolts holding the bottom of the air box down. Separate the wire connector at the back of the air box and then remove the air box by easing it out from the back, lifting up and out.
Name:	13 - Remove intack duct.png
ID:	265313   Click image for larger version
Name:	14 - Air duct top bolts.png
ID:	265314   Click image for larger version
Name:	15 - Air duct front bolts.png
ID:	265315   Click image for larger version
Name:	16 - Separate air box .png
ID:	265316   Click image for larger version
Name:	17 - Air box bolts.png
Name:	18 - Mass air flow sensor.png
ID:	265318   Click image for larger version
Name:	19 - Air filter.png
ID:	265319   Click image for larger version
Name:	20 - Wire connector.png
ID:	265320   Click image for larger version
Name:	21 - Remove air box.png
Old 02-05-2011, 09:51 PM
Step 4 - Remove the radiator fan
Now we need to get the electric radiator fan out of the way. Luckily this one is electric, I was thinking automatics had one with a fan clutch attached to the water pump pulley.
Start with the torx bolt to the left of the fan. Then unclip the electric connection to the fan right beside it. On the right hand side use a small pry bar to remove the plastic expansion bolt. Once you remove the F AUC sensor on the top right of the fan just pull the fan straight up and out. You might have to jiggle it to get around the expansion tank.
Name:	22 - Radiator fan.png
ID:	265322   Click image for larger version
Name:	23 - Torx bolt.png
ID:	265323   Click image for larger version
Name:	24 - Electric connector.png
ID:	265324   Click image for larger version
Name:	25 - Rad expansion plug.png
ID:	265325   Click image for larger version
Name:	26 - F AUC sensor.png
Name:	27 - Rad fan .png
Old 02-05-2011, 10:16 PM
Step 5 - Remove belts
With the rad fan out of the way there's enough room to remove the belts.
To get the a/c belt out, remove the cap on the lower deflector pulley, use a 45 Torx with a large breaker bar to remove the tension then ease the belt off the pulleys.
To get the water pump belt out, use a 16MM socket on the tensioner with a large breaker bar to release the tension. If you have a short thick nail, insert it when the holes align on the tensioner to keep the pressure off. Remove the cap on the tensioner pulley if your replacing the pulley.
Also remove the cap on the deflector pulley if your replacing that one.
Name:	28 - Belts and pulleys.png
ID:	265328   Click image for larger version
Name:	29 - A:C deflector cap removed.png
ID:	265335   Click image for larger version
Name:	30 - A:C belt tight.png
ID:	265336   Click image for larger version
Name:	31 - A:C belt loose.png
ID:	265337   Click image for larger version
Name:	32 - Water pump deflector cap.png
Name:	33 - WP tensioner.png
ID:	265339   Click image for larger version
Name:	34 - Clip for tensioner.png
Old 02-05-2011, 10:40 PM
Step 6 - Disconnect wiring
Next remove the wiring connected to the parts we're replacing. Disconnect the thermostat, pulse generator and vanos connectors then move that wire bundle out of the way. Near the bottom of the lower rad hose is the temp sensor connection.
At this point I would have also removed the coolant level sensor connection on the bottom of the expansion tank. However, the suspension on the X3 won't really allow access from below like an E46. I left this one until later, but it wasn't that easy.
Name:	35 - Themostat.png
ID:	265341   Click image for larger version
Name:	36 - Pulse generator.png
ID:	265342   Click image for larger version
Name:	37 - Vanos.png
ID:	265343   Click image for larger version
Name:	38 - Temp sensor.png
Old 02-05-2011, 11:07 PM
Step 7 - Remove hoses
With a flat head screwdriver (missed that in my list) popup the wire connectors that fasten the various hoses to the expansion tank, radiator, thermostat and engine block. Wiggle the upper rad hose away from the expansion tank, I used a large flat head screwdriver in various places to pry them apart. Then you can wiggle and pull the upper rad hose off the thermostat and remove it. Wiggle and pull down on the lower rad hose to separate it from the thermostat, then you can pull the hose away from the radiator.
Now look down just to the left below the expansion tank and you'll see the oil heat exchanger. There is a clip with a tab in the center at the top. Pull up on this to free it then wiggle the three connections loose (I think I used a screwdriver to pry this off). Just leave the heat exchanger resting on the suspension parts below.
Carefully pull the heater hose away from the expansion tank. Assuming your not replacing this one be very careful. I can't see an easy way of replacing this hose without removing the intake manifold so careful, you don't want to damage the plastic end.
Now you can separate the coolant hose that connects to the engine block. I would have also removed this from the expansion tank but again there is little room to get at this from below.
Name:	39 - Upper rad from expansion tank.png
ID:	265345   Click image for larger version
Name:	40 - Upper rad from thermostat.png
ID:	265346   Click image for larger version
Name:	41 - Lower rad from thermostat.png
ID:	265347   Click image for larger version
Name:	42 - Lower rad from radiator.png
ID:	265348   Click image for larger version
Name:	43 - Oil heat exchanger clamp.png
Name:	44 - Heat exchanger.png
ID:	265350   Click image for larger version
Name:	45 - Coolant hose to heater core.png
ID:	265351   Click image for larger version
Name:	46 - Coolant hose to engine block.png
Old 02-05-2011, 11:21 PM
CleanKM's Avatar
CleanKM CleanKM is offline
Bee Em UU
Mein Auto: 2014 328d
Fantastic write up! Thanks!
Current: 2014 328d Black Sapphire Metallic, Black Interior, Nav, Xenon
Past:
2011 328i SA SULEV Black Sapphire Metallic, Dakota Beige, ZPP, Nav
2007 X3 3.0si Black Sapphire Metallic, Grey Nevada, M Sport Package, Premium, Cold Weather, Navigation, and Xenon.
Prod Date: March 2, 2007
Old 02-05-2011, 11:43 PM
Thanks man. I'm not done yet and it's almost taking me as long to write up as it was to do the job. This was my second M54B30 cooling system overhaul. This time I kinda just jumped in and did it from memory. I like taking all the pictures because it slows me down and makes me think about every step. Less likely to make mistakes that way.
Old 02-07-2011, 07:51 AM
CleanKM's Avatar
Bee Em UU
I figured you weren't, but wanted to get my thanks in! Really appreciate you taking your time to do all that.
Past:
Old 02-27-2011, 08:33 PM
szee1 szee1 is offline
Mein Auto: 2 2004 X3's
Great write up, just replaced the water pump, expansion tank etc. Easy job and actually pleasant to work on.
Old 02-27-2011, 09:30 PM
Thanks...I hope this helped. The X3 has been running great ever since. It's snowing here now so I'm leaving the head gasket/spark plugs/compression test until spring when it's warm again.
Old 02-06-2011, 12:14 AM
Step 9 - Remove thermostat and water pump
To remove the thermostat there are three 10mm bolts and one 13mm bolt, with the bolts out give the thermostat a clockwise twist before pulling straight out.
The water pump is a little more tricky. If you forgot to loosen the four bolts on the pulley before removing the serpentine belt, like me, then you'll probably have to put it back on to put some tension on the pulley. With the pulley removed, start by removing the four 10mm bolts on the water pump. To get the pump out you need to take 2 of the long 10mm bolts from the thermostat and thread them into the two threaded holes provided on either side of the pump. Tighten the two bolts evenly and this will begin to force the water pump out of the engine block. Once you can see the large O ring, you should be able to slide the pump out.
You can see in the pictures the lousy plastic impellers from the original stock water pump. The high performance Steward replacement is a much better design for maximum peace of mind. I'm not sure how easy it is to remove all the pieces when a plastic impeller implodes inside the engine.
Anyways, that's about it for removal...except for replacing the tensioner pulleys. The next step is rebuilding the radiator.
Name:	51 - Thermostat.png
ID:	265360   Click image for larger version
Name:	52 - Water pump pulley.png
ID:	265361   Click image for larger version
Name:	53 - Water pump.png
ID:	265362   Click image for larger version
Name:	54 - Water pump.png
ID:	265363   Click image for larger version
Name:	55 - Water pump.png
Old 02-06-2011, 01:03 AM
Step 10 - Remove parts from old radiator
With the old rad out we need to remove the parts we need.
Unbolt the torx screws that hold the mounting plate to the radiator. Use a large flat screwdriver to separate the expansion tank from the mounting plate. Slide the cooling water collector out of the mounting plate. Finally unclip the black plastic mounting strip on the bottom of the radiator.
Name:	56 - Expansion tank mounting plate.jpg
ID:	265368   Click image for larger version
Name:	57 - Coolant hose.png
ID:	265369   Click image for larger version
Name:	58 - Expansion tank.jpg
ID:	265370   Click image for larger version
Name:	59 - Expansion tank.jpg
ID:	265371   Click image for larger version
Name:	60 - Cooling water connector.png
Name:	61 - Black plastic on bottom.png
Old 02-06-2011, 01:13 AM
Step 11 - Attach mounting plate
To attach the black mounting strip to the bottom of the new rad, place the front edge (towards the front of the car) of the strip in first. Then squeeze the clips on the back edge to force the strip in place.
Next slide the mounting plate into position making sure the top edge fits over the lip at the top and the bottom edge fits under the tab in the black strip.
Replace the thermostat...wait...WTF...now there's your problem. My old thermostat had self destructed, I wonder if that cause the leak...hmmm.
Replace the two torx bolts that hold the mounting plate to the rad.
Name:	62 - Front edge first.png
ID:	265374   Click image for larger version
Name:	63 - Press clips on back edge.jpg
ID:	265375   Click image for larger version
Name:	64 - Thermostat, now there's your problem.png
ID:	265376   Click image for larger version
Name:	65 - Top edge mounting plate.png
ID:	265377   Click image for larger version
Name:	66 - Bottom edge mounting plate.png
Name:	67 - Bolt mounting plate on.png
ID:	265379   Click image for larger version
Name:	68 - Second mounting plate bolt.png
Old 02-06-2011, 01:21 AM
Step 12 - Replace the cooling water connector
The cooling water connector has the blue drain plug for the expansion tank. Unscrew this completely then pull hard on it to remove it from the connector. Replace with a brand new drain plug, for $3 it's not worth doing this job and leaving in the old one. Then slide the connector back onto the mounting plate.
Make sure the clamp for the oil cooling heat exchanger is in the released position to help when reinstalling the rad.
Name:	69 - Cooling water connector screw plug.jpg
ID:	265381   Click image for larger version
Name:	70 - Cooling water connector.jpg
ID:	265382   Click image for larger version
Name:	71 - Oil heat exchange clamp.jpg
Old 02-06-2011, 01:31 AM
Step 13 - Install new expansion tank
Next step is to install the new expansion tank. First attach the expansion tank clamp from the old expansion tank and make sure the clamp is in the released position. Now position the tank so the hook on the back is aligned with the slot on the mounting bracket. Push the tank back towards the rad and down onto the thermostat. Push the clamp in place to hold the tank.
Install a brand new coolant level sensor, insert it in the bottom of the tank and twist counter clockwise into position.
Name:	72 - Expansion tank clamp.png
ID:	265384   Click image for larger version
Name:	73 - Expansion tank hook.png
ID:	265385   Click image for larger version
Name:	74 - Expansion tank clamp.jpg
ID:	265386   Click image for larger version
Name:	75 - Coolant level sensor.png
ID:	265387   Click image for larger version
Name:	76 - Twist sensor.png
Old 02-06-2011, 01:43 AM
Step 14 - Replace rad drain
The new rad came with two different radiator adjusting screws, a short one for standard and a long one for automatics. For me the long one was right.
Install a brand new blue plastic drain plug in the adjuster and push the adjuster into the bottom of the rad. Note that for this particular radiator there was one side of the adjuster with a notch cut out that fit a notch on the bottom of the rad. There are also two notches sticking out of the adjuster that fit into to slots in the rad. You need to push the adjuster in very hard so I gave it a few taps with a plastic hammer. Once its all the way down use a 22mm socket to give it a twist and lock it in place.
Name:	77 - Rad drain plug.jpg
ID:	265389   Click image for larger version
Name:	78 - Rad adjusting screw.png
ID:	265390   Click image for larger version
Name:	79 - Rad adjusting screw.png
Old 02-06-2011, 01:50 AM
Step 15 - Hose assembly
Finally, install a new temperature sensor in the new lower rad hose and a new drain plug (I like the brass ones better) in the new upper rad hose.
Oh yeah. Don't forget to replace the crush washer on the engine drain plug with a new one. Not much point in doing all this if it's going to leak from the engine.
Name:	80 - Temp sensor.jpg
ID:	265392   Click image for larger version
Name:	81 - Bleeder screw.png
ID:	265393   Click image for larger version
Name:	82 - Engine drain plug.png
Old 02-06-2011, 02:00 AM
I don't have any pretty pictures for the reassembly. At this point you're all ready to start replacing everything we removed. It's pretty smooth from this point on as long as you have a good torque wrench and the specs.
Here are some of the spec's I gathered up as I was putting it back together. I used the chart in the front of the E46 Bentley manual to calculate torques.
A/C tensioner pulley 10mm 8.8 class = 47Nm using 16mm socket
Water pump tensioner pulley 8mm 10.9 class = 34Nm using 45 torx socket
Deflection pulley 8mm 8.8 bolt = 24Nm using 45 torx socket
Water pump nuts m6 nut 24Nm (from Bentley) with 10mm socket
Water pump pulley m6 bolt 10Nm (from Bentley) with 10mm socket
Thermostat m6 8.8 class = 10Nm with 10mm socket
Thermostat M8 8.8 class = 24Nm with 13mm socket
That's everything I've got...probably could have shown more of the reassembly but I needed to finish before dark. More tomorrow.
Old 02-06-2011, 07:42 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Outstanding write up! Takes me back to the "olden days" when I was doing stuff like that on my cars. Now I know why I stopped and let the professionals do it. Reading between the lines it sounds like the problem was your thermostat self destructing. Never mind it was good to do the rest and now you will not have to worry about that crummy water pump (why BMW can't put a decent pump in I just don't understand, it can't cost them that much more) and the rest of the "plumbing" for as long as you keep the car. Thanks for some great memories!
Old 02-06-2011, 09:19 AM
Thanks bud. For me in the "olden days" I would have always taken it to my mechanic. I didn't even change my own oil until I picked up an E46 Dec '09. Mostly because I had a mechanic that I really trusted. He did a great job and would never do any unnecessary work. When I got the Bimmer it was gonna cost more cause he would have to learn about BMWs to do the work. Besides parts for BMWs up here in Canada are outrageous.
I decided to try a few basic things myself, always ordering parts online from the US (Pelican Parts, Autohausuz...) using a Bentley manual (awesome) and DIYs on E46Fanatics. It's been so easy I'm determined to do everything I can possibly do myself. Last year I replaced the seals on my Vanos and it made such a difference in my 330ci, that was very satisfying.
For me its been far better to DIY rather than take it to a BMW Steelership where I feel like I need a shower afterwards to wash away the feeling of being raped.
Honestly I can't believe how easy these cars are to fix. The biggest reason I bought an X3 for the wife was because I new that I could work on the engine. I think BMW has done a great job for their mechanics to charge an arm and a leg for jobs that are really simple.
Old 01-15-2017, 11:57 PM
Salzar Salzar is offline
Mein Auto: 04 X3
I agree! I am a 27 year old female who is on her tenth car and i actually care to do stuff myself now and to take care of my car because I love it. I have done the expansion tank and AT Thermostat, replaced the plastig gear inside the transfer case actuator because I was getting ABS Brake 4x4, am about to replace the belts and tensioner pullys tomorrow, few other things, and mostly by myself with the help of research, youtube, and maybe a hand or two from a family member who had the muscles to pop under for a second and loosen a bolt or hold a bar here or there. Im pretty happy with the car as I only paid $7,400, it had only 113k miles, and I get loads of compliments on it.
