Old 02-09-2011, 11:59 PM
Jared99740IL Jared99740IL is offline
Mein Auto: '99 740IL
99 740iL - Rebuild or replace engine
I have a 1999 BMW 740IL with a ruined engine (130k miles on the car).
BMW Technician said the engine couldnt even be used to rebuild.
everything but the engine looks new.
I got this car for free, and I have 5k-6k to mess around with,
and I have enough income to drop more on this later.
I cant find any rebuilt engines online that will work, nor can I find an
approximate price range.
Lastly, is there a way to fit a stronger v8 in here (say like from an m5)?
I'd hate to think my only option is buying a used engine and having that one
break down on me, and if I'm going to spend 4 digits, why not spend a little more
if a smarter option is available..
Thanks again guys.
Old 02-10-2011, 06:08 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
My 99 740IL had a broke engine with 137K on it and I was not so fortune to get it for free.
What happen with your engine? Timing chain broke because of the excessive sludge/gunk?
I'm just curious. That was my case and it was not worth to rebuild.
You can fit an M5 engine there, but with the M5 needs to come with the computer too. And that computer has a different software for the transmission and related sensors. Transmission and additional parts might need an upgrade too. And you car is much heavier than an M5 and I don't know if you really can enjoy100% the beast of an M5. $5000 for that conversion I think is not enough. This is just my opinion though...
For $5000 you can buy a nice engine with low miles for a reasonable warranty(90days?). Or you can buy for less ($1500?) a junk one and have that rebuild. And you are good for many miles.
My case : I did all the work by myself. spent $2500 for an engine with 90K. Changed water pump many seals and gaskets.Engine after 15K runs very good, only problem with it is that does have a Vanos tapping which many out there have, and it might need an valve seals replacement in the future. Without doubt this engine will last another 100K the way it is.
Anyway , shop around and see what you can find. Use car-part.com to find used parts.
Good Luck!
Old 02-10-2011, 10:07 AM
Jaap Jaap is offline
Mein Auto: e38
Any m62 will fit, physically
Any m62 will fit, physically. So a nice M62B46 or M62B48 would do niceley.
As joyism5 said however, you'd need to change all sorts of computers/ecu'd and sometimes even igintion mopdule + keys too.
Some people say you're better off putting in a an LS1 or something because it's way cheaper and (if you are a US resident) more experienced shops.
Old 02-10-2011, 10:30 AM
balance balance is offline
Mein Auto: 97 740iL
I wouldn't try putting an M5 motor as everything I've heard about that swap says that it is hard and complicated, and as far as I know, only one shop has ever done it. If I wanted a more powerful M62 motor, I'd get an M62 motor and supercharge it, but I'm not sure how much superchargers go for now, and I'm not sure how much money would be left over from the motor swap. I would think a supercharged M62 would get around the same power as a stock M5.
The first thing I would reccomend, is to use that money to fix all items in the car that need to be fixed, starting with the motor, then moving on to maintenance. Also, while the motor you are going to replace the blown one with is out of the car, that would be the best time to replace the many maintenance related items on the motor that are known to go bad, such as OSV/PCV systems, timing chain guides and tensioners, valve cover gaskets, valley pan gasket, motor mounts, front suspension items, etc.
Old 02-10-2011, 11:15 PM
Okay. So obviously Im not doing an m5 engine :P Supercharger seems cool, guys, but thats like an extra 8k with the engine, right?
So I think I should buy a decent, low mileage used engine... and do dinky stuff like cold air intake, exhaust, etc.
Can I buy a rebuilt engine somewhere? I dont see it on bavarian auto parts.. only used ones for like 2-3k
Also, my car is the IL sport.. does that make any diff? I heard its just a fancy word for bigger tires.
I seriously wish I knew as much as you guys do, and I appreciate all of your help. I want to learn a lot through this
adventure, and fall in love with BMW all over again. I thank everyone for their knowledge!!
Cheers!!!
Old 02-10-2011, 11:24 PM
Oh, and what happened to the engine? Bro I dont even know man. I lied when I said it was my friends, it was my dad (hes really ashamed.) and I didnt get it for free.. I gave him my 2011 Civic SI cause I hate the gearbox quite frankly, and I have the money to make chicken salad out of this chicken sh%.. =P
My dad shows up with it one night, mechanic said everything under the bonnet was a mess.
once you took off the engine cover, everything was unplugged/degraded. When you start it, it just pushes out smoke and bleeds oil.
I'll post some pictures tomorrow. I'm an auto detailer, so at least its a pretty, broken car now.. lol
Old 05-20-2011, 10:49 PM
ang3l729 ang3l729 is offline
Mein Auto: 99 740il
Question
have you done anything to the car yet? i made the mistake of trading in my beautiful 95 3000gt for a 99 740il withouth even looking under the hood, simply because i loved the way it looked. iv had the car a couple months, and it too is a mess!! when you crank it, it will shut off if you dont keep the accelerator lightly pressed, while pushing out a cloud of smoke the size of a mushroom cloud. when you try to drive it it will get forward gears and park, but no reverse, but after driving it a few seconds forward gears will stop working..it left me in the street the first second and third time im guessing the fail safe in the transmission engages and it wont crank unti it completely cools. it also reads codes p1519,p1522, and p0170, anyone have any ideas??l
Old 05-21-2011, 10:04 AM
joyism5's Avatar
P 1519 & P1522 = VANOS Malfunction : alignment to crankshaft position sensor, time to change timing
P0170 = Fuel System related : fuel trim limits (long therm & short therm) exceeded .
So , you have a timing issue, possible bad timing guides & tensioner, or (and) the VANOS units itself. Second group code (0170) could be related to the miss alignment, or MAF sensor.
Instead of replacing the engine with a used one I would go doing a heads removal/resurface and do a valve job, changing timing parts , Water pump system, and you'r all set with the engine. All this depends on the millage.
The transmission issue could be due to a charging issue (alternator or breakage in the cable somewhere) or transmission itself. It's hard to tel without a proper diagnostic.
Or all together could be due to a electric issue , possible in the ECM area?
Either way I would recommend to find a BMW specialist (not always a dealer) and get a proper diagnostic before throwing money here and there...
Good Luck!
JOY = BMW
Old 05-21-2011, 07:04 PM
Mein Auto: 99 740il
jaja luck isnt going to begin to cover the clean up ima have to get done. the previous owner supposedly had the timing replaced, and since my knowledge of bmws is limited to the b the m and the w. ...this looks like a decade long project. thanks for input, maye i'l get lucky
Old 05-21-2011, 08:25 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Get a second opinion. Consider the popular LS1 swap. My 2
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 05-22-2011, 09:08 AM
Mein Auto: 99 740il
it just that where i live mechanics have enought troule messin up domestic cars. n they wont work on bmws mercedes or lexus. i have to tow it about a 100 miles to get a decent opinion...and thanks for the pointing out the LS swap, im reading up on it now
Old 05-02-2012, 04:22 PM
trevelle trevelle is offline
Mein Auto: 740IL
1999 740il engine swap
my timming guide has broke in my m62tu, I bought a 1998 engine and was wondering how easy this swap will be...I have the harness computers aswell pleeeeeease help.
Old 05-03-2012, 04:22 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
@jared99740I'll - check out sites like http://www.bmrparts.com/
They have guaranteed engines. Get a dependable engine, do all maintenance on it prior to putting it in the car and save yourself a lot of headaches.
Big Boyz with Bad Toyz.
HTML code is Off
