E36 (1991 - 1999)
Old 02-23-2011, 02:29 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Change valve cover gasket due to small seep?
I have a very small oil seep that leaves maybe a drop or two a day. I know that it's pretty normal to have this, but my dad is annoyed by the oil stains in the driveway and garage. I am pretty sure that it is the valve cover gasket, it seems to be coming from that area. I have taken out the ignition coils, but I don't notice any significant oil in the spark plug wells. I only notice some slight wetness. Should I go ahead and take off the valve cover to check it, or should I move on to checking other parts of the engine for the seep? Will I need to replace the gasket just by opening the valve cover?
Thanks in advance.
-CJ
Old 02-23-2011, 02:54 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yes, by removing your valve cover, you will automatically need to use a new gasket. I'd just replace it. I just replaced mine at 103k miles, and it had basically turned from soft rubber to hard plastic. Who knows how old yours is. Mine broke out of the valve cover in hard little pieces. Be sure to buy the valve cover retainer nut seals, too, and use 02 sensor safe valve cover gasket RTV in the correct locations. Also, be absolutely certain that you use a torque wrench when tightening down the valve cover. The studs can strip very easily. Here is the DIY I used - worked very well.
http://www.dvatp.com/bmw/diy/valve_cover_gasket/
1998 BMW 328is
1966 Pontiac GTO
Old 02-23-2011, 03:02 PM
cj.surr's Avatar
some kid
Ok, thanks for the advice. Would you recommend changing all of the valve cover retainer nut seals, or just ones that are damaged? I hate to cheap out, but it costs 15 bucks for all of them on Pelican.
-CJ
Old 02-23-2011, 03:38 PM
ethereal45's Avatar
ethereal45 ethereal45 is offline
Send a message via AIM to ethereal45
Mein Auto: 1998 328i
Change all 15 of them. They are not reusable, especially if your car is a '93.
Also, ZeGerman, where did you get yours from? I need to grab another one for a friend's E36 but I got mine from the dealer here and they are so insanely slow, looking to avoid them.
1998 328i
Koni Sport Suspension
Old 02-23-2011, 03:52 PM
ZeGerman's Avatar
Warm Leatherette
I purchased my valve cover gasket and 15 retaining nut seals from Pelican Parts.
1998 BMW 328is
1966 Pontiac GTO
Old 02-23-2011, 03:53 PM
ethereal45's Avatar
What brand did you get? I saw a few on there, I did mine about a month ago and got an OEM one. I'm not sure who the OEM supplier for these is....
1998 328i
Old 02-23-2011, 04:09 PM
ZeGerman's Avatar
Warm Leatherette
The VC gasket(s) and retaining nut seals I bought were made by Elring Klinger, which is OEM BMW.
1998 BMW 328is
1966 Pontiac GTO
Old 02-23-2011, 04:11 PM
ethereal45's Avatar
Good to know. I've heard a few stories about people going with cheaper non-OEM makes of VCG's and they often times run into leaks/seepages very soon after replacing.
1998 328i
Old 02-23-2011, 04:13 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, there's no point to getting anything other than OEM in this case, since the off-brand parts aren't significantly cheaper than the OEM parts.
1998 BMW 328is
1966 Pontiac GTO
Old 02-23-2011, 04:24 PM
cj.surr's Avatar
some kid
Are you sure that there are 15 of them? Pelican says that you need 20.
http://www.pelicanparts.com/cgi-bin/...ndividually%20
-CJ
Old 02-23-2011, 04:44 PM
ZeGerman's Avatar
Warm Leatherette
My M52 required 15, and I'm pretty sure it's the exact same layout as the M50 in your car. Someone correct me if I'm wrong.
1998 BMW 328is
1966 Pontiac GTO
Old 02-23-2011, 05:30 PM
cj.surr's Avatar
some kid
The valve cover gasket set says to use fifteen, so I'll go with that. Thanks for your help.
-CJ
Old 02-23-2011, 05:47 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, I'm 99% sure it's 15 for both the M50 and M52.
1998 BMW 328is
1966 Pontiac GTO
Old 02-24-2011, 10:52 AM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
I'm confused here... Pelican says that I need one (using the above link) for a 93 325 Sedan w/ M50, and you guys are saying 15? Guidance? Thanks
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 02-24-2011, 10:55 AM
cj.surr's Avatar
some kid
It's definitely not one. The pelican parts gasket kit says 15, so that's what I would trust. Also, Karl said that he need 15 for his m52, so it's probably the same for the m50.
-CJ
Old 02-24-2011, 11:56 AM
ZeGerman's Avatar
Warm Leatherette
You need one retainer nut seal for EACH valve cover retainer nut. Count the number of valve cover retaining nuts - that's how many you need. There are 11 that go around the perimeter of the valve cover, and then four more down the center of the head. That adds up to 15 people...
1998 BMW 328is
1966 Pontiac GTO
Old 02-24-2011, 04:07 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Ok, thanks I'm replacing a valve cover gasket for a friend with an M50, and somehow Im responsible for parts, so I gotta make sure
Old 02-24-2011, 04:16 PM
ZeGerman's Avatar
Warm Leatherette
Cool. Make sure you use a torque wrench on the retaining nuts - especially if you're working on someone else's car.
1998 BMW 328is
1966 Pontiac GTO
Old 02-24-2011, 04:29 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
I plan to. 89in LBS, correct?
Old 02-24-2011, 04:38 PM
ZeGerman's Avatar
Warm Leatherette
I forget the exact number.
1998 BMW 328is
1966 Pontiac GTO
Old 02-24-2011, 04:46 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Pelican says 89, so thats what I'll go by How long did it take you to do yours Karl?
Old 02-24-2011, 04:56 PM
ethereal45's Avatar
89 inch pounds -- make sure you get a special smaller torque wrench. While some big ones go down this low, they aren't accurate that far to the bottom end of their range. A good rule of thumb is to avoid going within 10% of the top end or bottom end of a wrench's range.
Oddly enough, we follow that same rule of thumb with micropipetters in chemistry lab.
1998 328i
Old 02-24-2011, 05:02 PM
ZeGerman's Avatar
Warm Leatherette
I didn't time myself like I usually do when I do car projects, but it took me somewhere in the ballpark of 1.5 hours doing it for the first time (i.e. super carefully). Now that I know my way around it and have some familiarity, I could probably do it in well under an hour.
1998 BMW 328is
1966 Pontiac GTO
