Anyone have info/advice for DIY head gasket repair on 2003 525i E39?
I'm looking for an itemized list of parts for a head gasket repair job. Also,
the PEARLS of the job, if you've done it before. 2003 525i |
Aluminum block.
You are better off with a "new" engine. |
Hi Cam,
I tried to figure out which engines had not only aluminum blocks but non-ferrous cylinder liners - but I had to give up: - What is the metal for the E39 short block, cylinder liners, & camshaft head (1) Why, specifically, is the OP better off with replacing the engine if he has the aluminum short block?
More of the latter as the cost of a total engine repair is usually more than that of replacing with a used engine. Since aluminum expands faster than iron, it causes more damage faster. Pistons and valves can sustain more damage faster with an aluminum block. Cam seizure is a possibility. If you have blown your head gasket, you have likely contaminated your main bearings with coolant. Some distortion of the block may also be permanent. Just usually too much damage to fix. But an inspection should be performed to ascertain the cost of a repair before making a decision. |
Look at this thread:
- My E39 overheated & I need a new head gasket (1) Specifically this post: Quote:
"blown gasket" is a misnomer. Usually it is a crack in the head.
Almost every single engine that I have pulled apart due to overheating has had a cracked head and a warped block. I have only had 1 engine out of over 20 that was rebuildable.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
I've added it to this specific reply, which I hope to become canonical (over time) so that we can refer anyone who asks about a 'blown head gasket' to it, to get them started on the right footing. |
I think I would install an M54 3.0L....
That's an interesting point.
If someone were to have an E39 with a 'blown' engine due to overheating, do they have the option of 'upgrading' the engine? If so, for future reference, do we have a table which shows what engines are plug-and-play fit'able into the various E39s as upgrades? |
I have installed a 3.0 into a 525i. I used the existing intake manifold, exhaust manifold, etc and it worked just fine. If you want to use the 3.0 accessories, you will have to buy a lot of extra parts like airbox, maf, engine computer, and align the DME to the key so it will start.
Here is a list of what can be done without a problem to the e39 1999-2000 323i e46 to 2001-2003 525i 2001-2005 325i e46 to 2001-2003 525i 1998-2001 Z3 2.3i e36/7 to 2001-2003 525i 2004-2005 525i to 2001-2003 525i 1999-2000 328i e46 to 1999-2000 528i 1996-1998 328i e36 to 1997-1998 528i 2001-2005 330i e46 to 2001-2003 530i 1999-2006 X5 e53 3.0i to 2001-2003 530i 2001-2002 Z3 e36/7 3.0i to 2001-2003 530i 2004-2005 530i e60 to 2001-2003 530i 2000-2003 X5 e53 4.4i to 1999-2003 540i 1999-2001 740i e38 to 1999-2003 540i You can upgrade your engine, but you cannot easily go from single VANOS to dual VANOS, you have to stay with what you have. If you have a 2001 525i, you can upgrade to a 3.0, but you have to use all of your existing 2.5 accessories if you do not want to go with the hassle of getting your DME aligned to your key. If you have a 528i, you cannot really upgrade unless you swap over the wiring, engine computer, transmission, transmission computer, and get the electronics aligned to your car. It is doable, but not really worth it.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 Last edited by Jimmys 530i; 03-13-2011 at 06:07 PM. |
- What engine combinations are known to work in the E39 when the need arises to replace |
Anything is possible, the question is if it is worth your time and money. I have seen someone swap an engine out of a 2006 M3 into a 1989 M3. Was it really cool and fast? Yes. Was it really worth spending almost $20k for it? No. For that kind of money he could have built up an impressive euro S50 and blown away his current setup.
