Old 03-24-2011, 05:37 PM
mazzellaak mazzellaak is offline
Mein Auto: 2001 528i
2001 528i engine
My son ran his 2001 528i with a cracked radiator and ended up with a blown head gasket and bad water pump. The shop that looked at it said two of the head bolts tightened, but a third just spun so the engine is shot.
Is there a market to sell a beemer with a bad engine? It is very clean. Or, is there a reliable place to try to buy a rebuilt engine? Perhaps a BMW enthusiasts would like a project to work on...
The car is currently in the Seattle area.
Old 03-24-2011, 06:51 PM
02BMW530's Avatar
02BMW530 02BMW530 is offline
Mein Auto: 2002 530i
Part it out. I need a fuel door.
Sent from my iPhone using BimmerApp
Old 03-25-2011, 12:24 AM
This is so sad. It happens at least once a week judging from the posts we get (and you're not the first father to report that his son learned the hard lesson that the BMW cooling system is a time bomb that will ruin the engine pronto if not cared for).
See:
- What to tell people who overheated their BMW E39 engine (1)
Is there a market to sell a beemer with a bad engine? Or, is there a reliable place to try to buy a rebuilt engine?
A friendly suggestion, if you want to sell it to an enthusiast, call it a 'bimmer' because it's not a motorcycle.
See:
- What is the difference between a bimmer and a beemer and, um, yeah, a beamer (1)
In the thread I referenced above, there are places listed which will sell a rebuilt engine for the E39. You might want to price it out.
You can get the parts value and some reliable shops for advice from this link:
- BMWfans phantom diagrams (1) & realoem nominal prices by part number (1) & EACTuning prices by part number (1) labor rates by zip code (1) (2) (3) where to find a good mechanic (1) (2) joining BMWCCA (1) (2) & finding a reputable BMW indy in your area (1) (2) & the most often recommended parts suppliers (1)
Good luck. Let us know what you end up doing.
Old 03-25-2011, 01:56 PM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
Fair enough if a daughter did it because, no offense bee but women know f all about cars and they car just as much.
But for a boy to have the same 0 factor? Is it just me or are the younger generation of boys just caring less about their cars?
On the other hand man these lil aluminium blocks are weak as piss!!!
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 03-25-2011, 03:09 PM
02BMW530's Avatar
Truth be told.... If I didn't know E39 cooling systems were so prone to failure, I wouldn't know to pay any extra attention to it. Then again, I might not have bought it...
Old 03-25-2011, 06:07 PM
Joe@Bavarian Joe@Bavarian is offline
Mein Auto: Me - E39 5spd, Wife - E36
RE: mazzellaak
You can do a used engine with a 2-year warranty. If you decide to fix it let me know and i will discount it down for you. I'll be back in the office Monday.
-Joe
Old 03-26-2011, 01:21 PM
Hi Joe,
I'd like to add information from you to the recommendations in the threads.
Is there a specific web page listing options specific for E39 users who have blown engines (typically newbies to the forum) that I can reference them (other than the home page)?
Do you have an E39-specific linkable resource?
Bluebee
Old 04-14-2011, 04:20 PM
Hi Joe,
Bluebee
Sorry i just read this post, Thanks
BMW 528i 4DR E39 ENGINE - ASSEMBLY - Long Block -
Used
M52
1996 - 1998 BMW 528i 4DR E39
Used
 M52tu 1999 - 2000 BMW 528i 4DR E39
BMW 525i 4DR E39 ENGINE - ASSEMBLY - Long Block -
Used
  M54
2001 - 2003 BMW
525i, 525i Wagon E39
BMW 530i 4DR E39 ENGINE - ASSEMBLY - Long Block -
Used
M54
2000 - 2003 BMW 530i 4DR E39
BMW 540i 4DR E39 ENGINE - ASSEMBLY - Long Block -
Used
M62
1996 - 1998  BMW 540i 4DR E39
Used
M62tu
1999 - 2003 BMW 540i, 540i Wagon E39
BMW M5 4DR E39 ENGINE - ASSEMBLY - Long Block - Used
S62
1999 - 2003 BMW M5 E39
Old 04-14-2011, 11:28 PM
Thanks.
I peppered the overheat advice and engine-swap advice threads with the following table from you so that users with this problem have the information ready at hand.
Consider replacing the engine using one from the sponsors, e.g.,
Old 07-16-2011, 06:36 AM
Based on yet another overheated-engine-blown thread today:
- E39 (1997 - 2003) > Engine head
For the cross linked record, to help others in the future, I've compiled all the overheated-engine-blown threads I could into a set of comprehensive links as shown below:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) & how to test an engine for blown head gasket, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & a well researched reusable response to a particular user with a blown engine (1) & what questions to ask when severe heating-related damage is initially suspected (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what E39 engine swaps are most recommended (1) (2) (3) & how to lift & remove the engine (1) & where to obtain a new or rebuilt replacement short block or long block (1) (2) & why the E39 engines are so prone to heat-related damage in the first place (1) & real-world results from people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28).
Old 04-14-2011, 02:52 PM
jarhed1964 jarhed1964 is offline
Mein Auto: 1997 and 1999 528i
Go here: http://www.bavengine.com/
They are close to you and do a very good job on their rebuilt engines. Go with the 5 year warranty. Going to have to balance out whether or not it is better to finance another car or just put a rebuilt engine in this one and keep driving it. In this economy, my bet is on the rebuilt.
Old 04-14-2011, 05:06 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Hope the son won't be getting the car back anytime soon
I'd replace the engine. IMHO there's little that will replace an E39.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 07-16-2011, 10:21 AM
blz456's Avatar
blz456 blz456 is offline
Mein Auto: 2000 528i
I think it's true about the younger guys caring less about their cars... Three of my friends have had to have their engines replaced due to overheat, my girlfriend's brother doesn't know how to change a spare tire, and all my friends (and friends of friends) come to me with all their car troubles because they don't know what to do and don't wanna pay for a shop.
I'm 19 and I've had my 2000 528i since I was 15 and have put almost 70k miles on it (got it at 100k miles) and i do all the work myself on my car and enjoy every bit of it. Maybe thats why everyone comes to me for problems... I dunno... Sorry for ranting
2000 528i steptronic
Blacked out
Old 07-16-2011, 06:51 PM
We were all young once ...
Old 08-23-2012, 07:19 PM
Another overheated leaking cylinder #3 today:
> E39 (1997 - 2003) > Cylinder 3 Misfire
Originally Posted by epremsoft View Post
I think I found the problem... its head gasket! there is a leak on cylinder 3, so it taking coolant and it mixing it with the oil! How much do you guys think its gonna cost me?
Old 08-29-2012, 09:24 PM
I stopped referencing the blown-engine threads in the bestlinks at 50 threads, but, one thing interesting about this thread today is that one person's catastrophe is another person's boon!
> 5 Series > E39 (1997 - 2003) > ENGINE R&R help...
Originally Posted by proheader View Post
Grabbed a 1999 BMW 528iT wagon over the weekend. Bought it for less than most people make in one day with average wages......
Head gasket is FRIED, so thinking of doing an engine swap. I notice that the 99 has an aluminum block and the double VANOS timing system......
I put some want ads out there and I get some replies about the 328i engine will work if I switch the oil pan, then another reply said stick with the exact engine......
Old 09-08-2012, 10:35 PM
Another blown engine:
> E39 (1997 - 2003) > SES light
Originally Posted by jvonhorn View Post
Well I ha sveome bad news to report. The shop say that there is no compression in one cylinder and 2 are around 60. He thinks that putting money into the engine maybe a bad idea. A used engine is 2500 online and repairing the whole thing would likely run me 4K....
Old 11-29-2012, 03:33 AM
Bigset3102 Bigset3102 is offline
Mein Auto: 528i
Get and older 528 engine put in I have a 1998 and it doesn't have the aluminum block
Old 12-04-2012, 11:08 PM
For the record, another user with a blown engine today is seeking advice so I pointed him to the canonical set of replacement engine advice links, one of which is this one:
Originally Posted by canam8 View Post
I'M LOOKING FOR INFORMATION OR DIY ON AN E39! 2002 BMW 525i WITH THE SPORTS PACKAGE AND AUTOMATIC TRANSMISSION. WOULD BE GREAT TO ALSO HAVE SOME KNOWLEDGE OF REBUILD KITS, PRICES OR WHERE I COULD OBTAIN THEM FROM! VERY MUCH APPRECIATED IN ADVANCE. I have a cylinder w low compression and before I started pulling it apart to find out exactly what's wrong was hopin to get an idea on direction of other possible things to check to narrow the problem down a little more and a heads up on prices for things like cam valves rings gasket kits etc.....
cyl. 1,2,3,5,6 are 220 after 6 rotations. cyl 4 is 85 after 6 rotatiions!
EDIT: I also suggested these PDFs from the bestlinks:
BMW_E53_X5_M54_Engine_Training_Manual.pdf
M54_technical_information.pdf
Old 12-13-2012, 04:27 PM
Looks like another Bimmer bought today with a blown engine.
At least I hope these guys get 'em cheap.
Originally Posted by BlackMax540 View Post
I bought my 1999 540i a couple weeks ago and i still cannot get it to start. The engine turns over and have been consulting the bentley. I have tested the fuel pump to make sure it is running and with a jumper wire in the relay slot 6 and 2 the pump does come on. There is no check engine light on at all ... i have tested all the coils and checked the coil connectors with the multimeter with no problems found. However i believe the rear main seal is gone because there is oil coming out from the hole in the bellhousing of the transmission close to the crankshaft speed sensor( which appears to be new) also i noticed there was possibly some oil around the exhaust manifold at the back of the head. Does anyone have any ideas ... i really would like to be able to get this car running so i can experience it... I have never got to drive it yet...Where is the best place to buy parts and or for quality used engines. Please help me! Any help would be truely appreciated. Also is there anyone here from close to Myrtle Beach, SC?
EDIT:
Another blown engine today:
Originally Posted by ironman27 View Post
I just had my second diagnosis on my car and it has a blown engine. Looking to sell as i dont have the money to pay for a used one. Excepting reasonable offers. The car is located in New Jersey.
Old 02-24-2013, 01:56 PM
Another one, reported today, about to blow:
Originally Posted by flight203 View Post
I have let the car sit for a month now. I checked the oil and it is milky, meaning coolant in the oil. But the car does run great it dose not over heat at idle for hours. I drove the car to my fathers house 15 miles and it did not over heat but the temp did rise at red lights ?
