E90/E91/E92/E93 (2006 - 2013)
Old 04-01-2011, 06:00 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
My Reality Check bounced
Mein Auto: 09 328i 6MT Cabrio
Running Toward the Light
Over the past few days I think I've read every post available on the 'fest, on M3 Post and E90 Post regarding replacing the stock halogen angel eye bulbs. Now that I've done my research I have some questions:
1) It looks like there are two major ways to go - either replacing the halogen bulbs with bulbs that are blue coated to shed the "white" light. ie - GP Thunders and competitors
and
2) Replacing the halogen bulbs with an LED bulb ie Angel iBright - Lux H8 - Weisslicht.
I know that the LED replacements are a lot more expensive.
The M3 guys all seem to love the Angel iBright setup ($300), and from what I've seen in photographs, this appears to be a pretty close approximation of what I remember seeing last summer when they had an LCI E93 on display at the Welt.
Yet, when I read the fine print of the sigs around here, it seems like most of the E9X that have made this modification have done so with the GP Thunders. ($20)
1) Is cost the only reason people aren't doing the Angel iBrights?
2) Are the GP Thunders really that good?
ps: E92LIghting, JLeviSW and EAS - I know you all are going to show up here and try to sell me. I've already studied your websites and your products. What I am looking for here is real time - real data from the day to day users.
TIA
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|CDV Delete|Shark Fin Antennae Delete|Front Reflector Delete|LUX H8 Angel Eyes|No Bells|Few Whistles|Das Fahren im Freien| BMWCCA#445793
Old 04-01-2011, 06:27 PM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
Perhaps, I'm confused, but couldn't you just replace them with the OEM bulbs that now come standard on the LCI coupes? Those are white (and LED I presume). Or do those not work, or are they even more expensive.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 04-01-2011, 06:43 PM
Nordic_Kat's Avatar
Good question, C-Dub, but the answer is you can't. Apparently the LED's need a ballast and heat sink, which is part of the cost of the conversion kits. Amazing thing is that the Angel ibright system isn't even the top end of things. There is another system OSS which requires you send your headlight units to Florida for retrofitting.
(Cute avatar pic, BTW!)
Old 06-18-2011, 08:02 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Includes disabling lasers fitted to the adaptive lighting system. Teaches a good lesson to those rude, aggressive drivers.
That's what I have.
Old 04-01-2011, 06:39 PM
RaceBlood's Avatar
RaceBlood RaceBlood is offline
Mein Auto: 2007 335i Coupe 6MT
I am already confused....the light is too bright, with all my might, I will fight, it will be tight, but the thread will take flight, and be all right.
2007 335i|Space Gray|Coral Red Leather|6 MT|Sport/Premium/Cold Pkg|Logic 7|HK 300W|Xenon|Hankook V12's|M3 Rear Lip Spoiler|M-Tech Front Aero Spoiler| M-Sport Aluminum pedals| M-Sport Shifter| BMWCCA
Old 04-01-2011, 07:01 PM
cwinter's Avatar
Here comes trouble!
I knew you would have already researched that. I guess there is more to the white light than just a bulb change. Seems interesting that an LED bulb needs more heat management than the halogen brethren.
(Thanks.)
Old 04-01-2011, 07:17 PM
Nordic_Kat's Avatar
Yep. I'm not an engineer, but it does seem counter intuitive that the LEDs aren't cooler. Most peoples complaints about many of the options are that the outer rings are not fully lit and/or the after market solutions aren't bright enough.
Old 04-01-2011, 07:24 PM
pointandgo's Avatar
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
and
TIA
I think there's another question, Kat. Since your light reflector(s) are now perfectly matched to your OE bulb for an ideal beam pattern, will any replacement bulb be of the same size/dimensions, and not adversely affect your beam pattern.
Old 04-01-2011, 07:42 PM
Nordic_Kat's Avatar
I'm not sure I understand your question.
When you say reflectors, I am presuming you mean the corona rings (to use the proper BMW terminology). From what I understand in my reading, that is where many aftermarket solutions fall short.
There is one bulb that illuminated the inner ring and the outer ring is lit purely by reflection off the inner ring. If I correctly understand what I've read, aligning the bulb in the socket is critical to getting the rings to illuminate, let alone illuminate properly.
Apparently, the aftermarket bulbs are the correct dimensions, but we all know that just because its the right size doesn't mean it necessarily does the job properly.
Old 04-01-2011, 07:46 PM
pointandgo's Avatar
Like this:
http://www.expresstirecenter.com/doc..._schematic.png
having had a cadre of "yute" engineers who were constantly modding their cars, several of your words above ring true: "...many aftermarket solutions fall short."
Old 04-01-2011, 08:04 PM
Nordic_Kat's Avatar
I don't know if that is really an issue with the Corona rings. This modification would not affect the adaptive Xenon or the inner cornering lights. I don't perceive the corona rings as having a beam pattern so to speak.
Old 04-01-2011, 07:54 PM
Bcube's Avatar
Bcube Bcube is offline
Combat Commuter
Mein Auto: 2007 E93 335i
Is this an April's Fools or worse - on of the signs of the coming apocalypse? I thought you were dead set against any mod that didn't have BMW OEM stamped all over it.
Terry has an alternative that is priced right, I've thought of buying next time one of my AE lights burnt out.
http://burgertuning.com/BMW_Angel_Eyes_H8_Bulbs.html
-Brian
"Used cars are our entry cars." - Luca di Montezemolo
Old 04-01-2011, 08:11 PM
Nordic_Kat's Avatar
I thought I was dead set against any non OEM thing too. Then we went to the Welt last summer and I got to see the LED angel eyes on the E93 there and I fell deeply into lust.
Besides, it's kind of a para-OEM thing. BMW has already done it - I'm just thinking of freshening the '09.
That is why I've done so much research - trying to find the right color, the right intensity....
EDIT: The photo from Terry's website is a good explanation of what I would like to accomplish generically.
Old 04-01-2011, 09:44 PM
Inline Sixer's Avatar
Inline Sixer Inline Sixer is offline
smooth like butter
Mein Auto: 2011 E93 328i | 2010 X5
Next to the yellowish hue of the corona lights on my 2010 X5, the ones on my 2011 E93 appear bluish white. I really love how it looks. Was this "white light" an OEM "upgrade" for certain model years onward?
Old 04-02-2011, 06:26 AM
Nordic_Kat's Avatar
Yes, the LED angel eyes on your cabrio are part of the E92/E93 LCI facelift. Since I plan on keeping my E93 quite a while and I don't have to worry about turning it in on a lease, I thought improving the angel eyes to the updated configuration (or as close as I could get to it) might be a worthwhile thing to do.
From all my reading, the biggest reason I've been hesitant to jump into the bulbs like the GP Thunders is many people say they dim over time or aren't very bright in full daylight. Can/would you post a pic of your cabrio angel eyes in full daylight?
(ps: I thought about a thread title of "Blinded by the Light", but I knew that would definitely engender silly song response.)
Old 04-02-2011, 06:28 AM
guerilla twang's Avatar
guerilla twang guerilla twang is offline
I do my crosswords in pen
Mein Auto: OEM+ 330i
The only AE replacements that can offer that kind of intense brightness are OSS and possibly LUX.
Do you have first hand experience with them?
I have a friend in town that has them, yes. What would you like to know?
Old 04-02-2011, 06:42 AM
Nordic_Kat's Avatar
Interesting that you mention the LUX. From what I've read, Angel iBright are brighter than LUX. LUX is not quite as pricey. OSS way more pricey.
That is why I was really hoping to turn up someone who has done the Angel iBright to get their take on it.
GT, since you seem to run with a pack, do any of your friends have a new coupe that could be parked next to your friends car with the Mtecs and a comparo photo taken?
Originally Posted by andyffer View Post
get a new E93!
LOL. I just turned 11K yesterday - it is essentially a 'new' E93.
Old 04-01-2011, 11:56 PM
jocamryn's Avatar
jocamryn jocamryn is online now
Original *****
Mein Auto: '09 E90 LCI
These lymric threads never last....
OP,
I'm going to go with these
City Vision E92 H8 White Angel
these
LUX H8 E92/E93 M3 BMW V3 NEW
or these
GP THUNDER 8500K H8 PLASMA V2
Fc Bayern Deutschermeister ja so heißt er mein Verein,
Ja so war es und so ist es und so wird es immer sein
Old 04-02-2011, 06:02 AM
smooth like butter
I think the thread title set the stage for these poetic responses. I'm glad some responses were able to "shed light on the matter". arrgh. must. resist. puns...
Old 04-02-2011, 12:45 AM
tturedraider's Avatar
Freedom isn't free!!
Kat, I'm thinking that the Sylvania Silverstar Ultras might be an option. I would imagine they make an H8 Silverstar bulb. I'd like to do the same to my '06 E90.
I'm sure you've already done this, but here is a google search for h8 bulb - http://www.google.com/search?q=h8+bu...ient=firefox-a
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 04-02-2011, 06:23 AM
Kat, I know many people who have had great luck with Mtec V2's as well.
Nordic_Kat's Avatar
Old 04-02-2011, 06:33 AM
andyffer andyffer is offline
WTB - your E39 M5
Send a message via AIM to andyffer
Mein Auto: 02 530i, 09 335d
get a new E93!
Unencumbered by the thought process
If you're not a ******* at twenty you have no heart, if you're not a ************ at forty you have no brain.
lol andy..
Old 04-02-2011, 07:11 AM
DSXMachina's Avatar
Automaticallyparsinglinks
Let there (not) be light. In NH we have annual safety inspections, each vehicle is done in the month of the owner's birthday. Naturally we are required to check lights. To paraphrase to the best of my ability...
"All factory equipped exterior lights must function as intended. No lights of any kind may be added to the exterior. All bulbs must be of the same wattage, color, and type as those which were certified for the vehicle."
We could not issue a safety sticker for a car modified the way you intend Kat. We are not a high crime area, so yes, the State and local cops do stop and ticket cars for modified lighting. I know this because the owners come to me to sign off on a form saying that they reverted to the original (at least while it was at my shop)
TX; YMMV
Edit One of my techs went on to become a city cop. He works the graveyard shift and often is on call to twist wrenches if we get busy. He has said that he rarely stops cars just for a light infraction, but will give a ticket as an add-on for attitude. What all cops constantly stop for is window tint on the front door windows and windshield. They really dislike the stuff.
