Valve & Timing Cover replacement - Bimmerfest - BMW Forums
Old 04-15-2011, 10:29 AM
HerbP HerbP is offline
Moderator
I am ready to change my valve & timing cover gaskets. After reading TIS, I am concerned about removing & installing the servomotors. TIS says to use diagnostic equipment to remove. I am guessing that it is referring to DIS?
Has anyone done this, that can provide me the correct way to remove & install the servo motors. I am only nervous about the servo motors, the rest will be a aggravating. I expect an 8 hour job!
Old 04-16-2011, 07:52 AM
Moderator
Anybody know?
Old 04-16-2011, 08:35 PM
Moderator
I just want to give everyone with leaking valve covers, to do this yourself will be no fun! I have spent 6 hours getting everything apart. There is not an easy way to do this. Tommorow I will remove the upper timing covers, to change these gaskets also. The only good thing about this will be, is easy access to the spark plugs! I am taking plenty of photo's, so that I can hopefully do a DIY.
Thanks to Yorgi for some help!
Old 04-16-2011, 08:47 PM
Route 66's Avatar
Route 66 Route 66 is offline
Mein Auto: 2001 740i
I can understand why indy shops charge $500.00.
Old 04-16-2011, 09:03 PM
Moderator
I wish I could have found one that cheap!
