6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
Uneven rear tire wear common?
Bought my 08 w 11k miles and during the wheel swap I noticed uneven rear tire wear - these tires are almost shot on the INSIDE. Is this common or were the wheels mis-aligned at the factory? Thanks in advance for anyones replies.
08 Stratus Gray Cream Beige/Dark Wood HUD/Night Vision Lane Departure Passport 9500CI w/GPS Resonator delete & added "X-Pipe" Current Toys: Sea-Doo RXT-X aS 260 (supercharged, intercooled, Fox Shock Remote Res suspension) handles chop like a dream! Ski-Doo Renegade X ETEC800 & MXZX 800 Kawasaki Brute Force 750i 4x4 26ft Hurricane w/twin Yamaha 150 Outboards Toy-Hauler Ford F250 QuadCab Previous Toys: 2004 M3 SMG 40 foot Mainship Sedan Bridge Yamaha GP 1300R waverunner Last edited by incorrigible; 04-16-2011 at 07:14 AM. |
Run-Flats?
Yep - usual issues! Get rid, save 50% and more life in each tyre and better ride! |
I wouldn't call it normal. It's more of a tire pressure issue. I got great life out of my tires.......only changed the rears and that was around 35k if I remember correctly. Turned the car in at 39k..........Phil
2011.5 Dinan ///M3: SSII DCT Comp Pkg Conv Pkg Premium Pkg 2 Heated Seats Enhanced Premium Sound Black Kidney Grills BMW M Performance Steering Wheel BMW Carbon Fiber Performance Spoiler BMW Aluminum Pedals Dinan Exhaust Dinan Mid Racing Exhaust (x-pipe) Dinan Carbon Fiber Intake Dinan Racing Middle Exhaust Software Dinan Pulley Kit Dinan CH-R Wheels Dinan Carbon Fiber Strut Tower Braces Arkym Front Lip Carbon Front Reflectors Lux H8 V3 Brembo 365mm BBK |
It is normal but preventable. The camber on the 6ers needs to be adjusted to factory specs, quite often(6months-year) or you'll go through tires like water...just another preventive maintenance thing.
Sent from my iPhone using BimmerApp
6 series - Sapphire Black w/ 22" Beyern Mesh wheels
I would get an alignment and also check the condition of the bushings in the rear suspension. When bushings start to wear you can bad toe-out during acceleration which will give you a narrow band of tire wear like in your pics.
Straight lines are for fast cars...turns are for fast drivers '04 M3 - track '06 650i Cab - daily driver '02 Highlander - kid hauler '01 330Ci - winter beater
Dealer says I need a $350 " dynamic balancing " ??????
I know this is an old thread, but thought I would add: I've replaced my rear Bridgestone Potenza Run Flat's 3 times in the last 2 years, getting almost exactly 8,000 miles out of each set. Classic BMW in Dallas performed the alignment when the tires were changed. I took it to a non-BMW german service garage, and they said the camber was adjusted correctly, but the toe was drastically out and was causing the tires to wear one inch of the inside down to the threads while the rest of the tread remained. He corrected the toe and said he feels confident that he's fixed the tire wear problem. We're going to check it in 3,000 miles.
I called Classic BMW who told me that the factory setting for the toe is aggressive for good handling and that's the way they set it. I was told "Some M cars are having their tires replaced every 7,000 miles". Well, I suppose that's great for Classic BMW's tire sales. I made my tire wear concerns known, and they still set it to max tread wear. I'll try to come back and update whether the new alignment cures my tire wear problem. |
