I enabled DVD in motion tonight - Bimmerfest - BMW Forums
Old 04-17-2011, 12:46 AM
mjr244 mjr244 is offline
Mein Auto: 2011 750li X-Drive
While some people are supposedly working on the LED angel eyes I bought and recommended (3 weeks and counting since any update....hmmmm....I'll stay quiet on that situation and that person).....I've been working on other stuff.
I bought a disc from dvdinmotion.com for $175 USD....SIMPLE install....just burn the file onto a CD-R and put the CD-R into your car....the program starts right up. It takes 2 minutes to do. Best mod yet.....NAV-TV wanted $600 for a module.....other vendors were trying to figure out how to do this......but now it's done.
Email Lucie at dvdinmotion.com.....she was very helpful. Mine didn't work at first....she recognized the problem....did a quick recode....and now it works fine.
You are all welcome.
Old 04-17-2011, 05:17 AM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
DIY approach
Very nice! If you have NCS Expert, there are 2 different ways to do this by yourself - very easy and straight forward. See the attachment posted in bmwcoding.com.
https://www.rapidshare.com/files/457...WCODING_v2.pdf
Old 04-17-2011, 05:18 AM
spyders 745li's Avatar
spyders 745li spyders 745li is offline
Mein Auto: bmw745li
Hey what dvd r using the nav or an add on
Sent from my X10a using Bimmer App
Old 04-17-2011, 02:47 PM
Yes, you guys may have coded the old E65 7 series.
No one has coded the F series cars unless you used a module that was $600-900. NCExpert doesn't work on F series cars.
Old 12-31-2015, 07:46 PM
paprmkr's Avatar
paprmkr paprmkr is offline
Mein Auto: 2010 BMW 750Li
i had my coded in. and for $100 i got DVD in Motion, fogs with highbeams, key fob control to open and close windows trunk and mirrors. eliminated side front marker, and speedo on the dash
other stuff that i can recall.
Old 06-14-2017, 10:26 AM
paprmkr's Avatar
i had mine coded pretty sure he used NCSexpert. not sure . but for less than what you paid it could of had lot more coding done. only positive i see is when car ever gets coded by dealer to do updates you have the DVD to do it again.
anyways i love the in motion. but lately i got a ipad holder that goes into my dvd slot and i see Netflix or Amazon Prime on road. where no service i view the downloaded movies i did before trip. screen brighter and bigger with iPad.
Old 06-14-2017, 10:31 AM
Boyzn Boyzn is offline
Mein Auto: BMW 740d sport
So is it can be coded by using esys without module?
Old 04-19-2011, 04:30 PM
mbworldz mbworldz is offline
Mein Auto: 2011 740i Blk/Blk
So with that dvd from dvdinmotion.com will enable the dvd in motion feature? No need to purchase any module and wiring ? That's awesome. I have been looking for one long time ago, but they all costly. I found this on ebay and seller sent me the installation pdf. It requires some welding ...etc. http://cgi.ebay.com/INTERFACE-TV-FRE...item53e5fffa34
Since you already enabled DVD in motion, is there a way to disable it through a button on a steering wheel or you can't disable it ?
Old 04-28-2011, 01:59 PM
CobraCabbage CobraCabbage is offline
Mein Auto: 2013 MCB M5
To disable it you just insert the installation CD and follow the same procedure as the installation. Takes 5 mins and its back to stock. I would recommend this to anyone. The valet guys love it .
2013 BMW M5
2011 BMW 750i M Sport w/ HRE 948R - Retired
2011 Infiniti QX56
'73 VW Dune Buggy
Old 05-11-2011, 01:38 PM
knkdlr knkdlr is offline
Mein Auto: 2011 750i
Did the dvdinmotion work?
Old 04-21-2011, 08:21 AM
mikeegez315 mikeegez315 is offline
Mein Auto: 750ix
So do you lose the nav while playing a dvd?
Old 04-23-2011, 11:57 AM
No you just put the screen in split screen mode. Then you have a small map and the movie takes up the main screen.
Old 04-23-2011, 05:17 PM
Mein Auto: 750ix
I guess the better question is where do you play the dvd from? Is the single disc player a dvd player? I was thinking you had to take the nav disc out but now that I think about it do we even have nav disc or is it software?
Old 04-23-2011, 08:02 PM
Its all software no nav disc needed. You can play DVDs from the single disk player.
Old 04-23-2011, 11:59 AM
Probably the best mod for the money. Thanks for this post I emailed Lucie as soon as I read this.
Thanks again...
Old 04-27-2011, 02:13 PM
Mein Auto: 750ix
OK Im ready to buy one ...anyone want to go in together. Looks like its cheaper if a few of us order at the same time?
Cobra did you get yours working already? Any issues?
Old 04-28-2011, 04:34 AM
Ok DVD in Motion is great and Lucie is extremely responsive. I will tell you its a bit of a mission and not to expect it to work on the first try. I probably burned and tried 8 different disks before it worked. So with the time delay and going back and forth it took me almost a week. But I think its well worth it and use it every time I'm in the car...
Old 04-28-2011, 08:25 AM
Mein Auto: 750ix
What brand/type of DVD disc and program did you use to get it to work. I know Sony's work for making Lexus Nav DVD's.
Old 04-28-2011, 01:34 PM
The best disks to use are Sony or Verbatim. I have a MAC so I used Roxio Toast.
Old 04-28-2011, 10:45 PM
repstein repstein is offline
Mein Auto: 2013 ML63 AMG, 2011 750Li
Worked for me on the first attempt. No problems at all.
You can play from the single disc or from the multi-disc changer if you have one.
Basically, it's the same as when you are parked, except now it works when you put the car into gear.
Randy
Current:
2013 Mercedes-Benz ML63 AMG Loaded
2011 BMW 750Li Carbon Blk Metallic, Oyster/Blk Nappa Leather, Ash Grain Trim, (Camera, Cold Weather, Driver Assist, Luxury Seats, M Sport w/20" Wheels, Premium Sound, Rear Entertainment Pkgs), Integral Active Steering, Instrument Panel w/ Leather, Ceramic Controls, Head-up Display, Smartphone Integration, Combox
2004 BMW 745Li Titanium Silver, Black Leather
Former: 2008 BMW 750Li, 2001 Audi A6 2.7T, 1998 Ford Expedition, 1993 Lexus ES300
Old 04-28-2011, 06:03 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
I'm actually angry at myself for waiting this long to read your thread!!!
Currently: 2015 Porsche 911 GTS and 2016 Cayenne S eHybrid
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 04-28-2011, 06:26 AM
SAMLAMBO SAMLAMBO is offline
Mein Auto: BMW, Mercedes, Ford
Pardon my ignorance but what is this DVD in motion? I have never played DVD in my car before.
2012 BMW 740i
2011 Mercedes E250
2007 Lamborghini LP670-4 SV
Old 04-28-2011, 08:28 AM
Mein Auto: 750ix
It lets you play a DVD on the nav screen and also while the car is moving. Atleast thats what I think it does. Can we play a dvd without this software? I am away from my car so I can't test it right now.
thanks
Old 04-28-2011, 01:32 PM
thanks
You can play a DVD without this software but once you put your car in drive "D" the video will disappear (at least it does in the US). This software allows you to play the DVD even while driving.
Old 04-28-2011, 01:49 PM
Mein Auto: 750ix
OK cool... I will order mine this week if no one else want to go in with me.
