6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
05' 645ci convertible Logic 7 Amplifier Replacement
Hello
i come from Germany-Berlin I got a 645ci and my sub from left, rear side are sound like he blowing up its the amp 100% but now i tryed to open the plastic trunk cover but there's one problem: I removed all screws etc,,, but theres 1 fiber cable that hold the cover? how i remove him??, and DOES Somebody have a nice guide how to replace amp????? this would be nice!!!! gretting's from hauptstadt berlin Last edited by ragal; 04-18-2011 at 08:33 AM. |
Please could someone help me!!
I used the search function but only found 1 thread and there's no guide how to replace :/
BMW Fanatic |
Here are the TIS instructions: Online TIS Logic 7 Amp Removal
I'll go take a few screenshots of the missing first 2 steps. I'll need to get those from my local copy of the TIS. Here is a step by step set of instructions, no pictures but it explains that you need to unplug the fibre optic cable. coug60's Logic 7 amp install DIY
Straight lines are for fast cars...turns are for fast drivers '04 M3 - track '06 650i Cab - daily driver '02 Highlander - kid hauler '01 330Ci - winter beater
Make sure you reattach all the way, this has something to do with the convertible top if memory serves me correctly. EDIT: On a side note, the TIS program also has a special warning you should be aware of. When removing and installing the Wheel Arch Cover take extra care and confirm that the convertible drain hose is still attached. It is easy to knock it off and then you will have water ruin your electronics in the trunk. Last edited by tampamark; 04-18-2011 at 08:00 PM. |
Here are a few more TIS instruction pages. First 2 on how to remove trim and last is how to remove the amp.
Hello,,
Omg, Thanks to all who help me!!, it helped me allot! This is the best helpful forum in the world for Beamers Thanks again... EDIT: Now i removed the whole cover (trim or w/e) , And Removed 5 Screws But the Amp Dont move a bit!!! Now i Explore , Behind the Amp are 2 screws more But how the hell i get the screws removed?? my fingers are fat and even with the pincers i cant get it drilled Here i tryed to show u what screws i removed: ![]() I'm now @home I will make later a Photo with my M-O-B-I-L-E P-HoNE Sry for my bad english =)
BMW Fanatic Last edited by ragal; 04-19-2011 at 07:11 AM. |
hmmm, I have never gone so far as to have to pull the amp out. I had removed the back carpet and arch for another issue so I am no help there. There must be something you are missing, perhaps you do not need to remove those behind the amp? The TIS shows some releases in the front.
Good luck. |
![]() ![]() ![]() ![]() NVM I Fixxed the problem was i dont removed the plates under the amp Now the amp is removed and i try to fix this by a local hifi dealer Thanks to all!
BMW Fanatic |
